Question about RCA Universal Remote Control
Pioneer cu vsx085 - RCA Universal Remote Control
Pioneer cu-vsx104 do you have a manual for this model
Try this http://www.schematicsunlimited.com/p/pioneer
Nov 21, 2015 | Pioneer Audio Players & Recorders
PIONEER REMOTE CONTROL CU-SD092
HAVE A REMOTE FOR MY PIONEER SD-P5185 PROJECTION TELEVISION. THE TV IS ABOUT 10 YEARS OLD OR SO. REMOTE CONTROL IS MODEL CU-SD092. DOES ANYONE KNOW THE STEPS TO SEARCH CODES TO PROGRAM THIS TO WORK TV. IT WORKED BEFORE BUT TOOK THE BATTERIES OUT AND NOW I HAVE RESET IT AND DON'T REMEMBER HOW TO REPROGRAM
Feb 02, 2014 | Pioneer Televison & Video
I have a pioneer usx-405 reciever for a PDf407. It used to work just fine but recently whenever I power it on in keeps flashing "muting". I looked it up online and a forum said I need a remote...
You mean Vsx 405, right? Model numbers are senseless enough without typos.
Are you saying you DON'T have a remote? How did you ever set it up? There are several CU-VSX105 remotes available on eBay, one at $9.99 and expiring in a few minutes (17:12 PDT). If you get this in time you could snipe it at the last 10 seconds.
http://cgi.ebay.com/Pioneer-CU-VSX105-Remote-Control-Receiver-/170642335146?pt=LH_DefaultDomain_0&hash=item27bb1365aa
Many a Pioneer receiver will come up MUTING if it powered down Muting. It's not clear if you have been experiencing unwanted shut-downs. Unwanted Muting or any other command could well originate with an unintended remote control source. Mask the receiver so it can't see other I/R sources.
May 21, 2011 | Pioneer VSX-405 Receiver
Where can I buy a pioneer remote CU-S0084?
Tries websites like Remotes.com,Tvrepairworld.com to buy the tv original remote.
Apr 24, 2011 | Pioneer Televison & Video
What are specs for a ported subwoofer enclosure for a 12" pioneer champ series
TS-W307D2
Design and Specifications
12” Dual Voice Coil (DVC) Subwoofer for Enclosure applications 1,200 Watts Max. Power Handling 400 Watts Nominal Rating Qts = 0.44 Xmax = 8.7mm Fs = 33.9 Hz Vas = 42.2 litres Frequency Response : 18 ~ 500 Hz. Efficiency : 89 dB Impedance : 2 x 2 Ohm (Total 1 or 4 Ohms) Delivered with “jumper link”: ready for 4 Ohm use f0 (Lowest Resonant Frequency) : 33.9 Hz. Recommended Sealed Enclosure : 24 ~ 49.6 Litres RECOMMENDED sealed enclosure, not Ported. 24 Litres = 1464.569 cu. inches 49.6 Litres = 3026.777 cu. inches
Nov 23, 2009 | Pioneer TS-W307D2 12" 1200 Watt Champion...
I need Pioneer AXd7248 remote control manual that I can download.
I have your solution! We were having trouble with this too. As you may have known, the Pioneer AXD7248 came with a receiver, the Pioneer VSX-D409 / VSX-D509S. If you look up the manual for the receiver, you will find how to program the remote on page 23 of the manual and the codes starting on page 53.For the convenience of everyone else who googled AXD7248, here's a direct link to the page to download the manual: http://www.retrevo.com/support/Pioneer-VSX-D509S-Receivers-manual/id/385ci970/t/2/
Jun 25, 2009 | Televison & Video
Building a box, need to know best dimensions for box and port
Hello dirt_digger6,
The specific sub you are asking about would seem to be the TS-302F which is the only 12" 800W Pioneer I have located.
Directly from Pioneer's support knowledgebase:
TS-W302F = Ported: 2.5 Cu.Ft. F3 = 39HzPort: 4  x 6.5 tuned @ 37 Hz with 12 % port noise.
An enclosure 16X18X21, constructed from 3/4" MDF will yield 2.69 Cu.Ft., allowing .19 Cu.Ft. displacement for the sub and port.
There's an excellent "box calculator" located here on the12v.com web site. You can measure the space you have to put the box and fiddle with the dimensions to get close to your ideal volume. There are also calculators on the12v.com which will allow you to calculate a port length based on port diameter (or width/height), enclosure volume, and desired tuning frequency.
Hope this helps.
May 07, 2009 | Car Audio & Video
Televison & Video Logo
65 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
