Question about AOpen DUW1608/ARR (914ID37204) Burner
AOpen DUW1608/ARR - DVD Problem
I am able to read and burn cd's ok, but when i insert a dvd, nothing happens, and the drive changes from DVD RW Drive to CD Drive when i check in My Computer also the green LED flashes, i have tried disabling drive via device manager and unistalling driver then rebooting but is still then same, i have also downloaded drivers/firmware and installing them but i still have the problem! Can any one help as i am losing hair rapidy!
    President:
  • 2,961 Answers
It's a classic drive failure problem where the laser can no longer burn or read dvd's, and show rhr writer as a cdrw, but may still be able to read or write cd's only. You will have to replace the drive, they are quite inexpensive, and very easy to fit.
Posted on Aug 11, 2007
My DVD Burner will not open but it shows a red light which leads me to believe that it works but there is a problem with how it is connect or maybe it is an internal problem.
Hi there, you should probably try to open the burner manually, to do so, usualy there is a small hole on the from that you should push with a pin and this will open the dvd. Sometimes the dvd can get stuck if it is not centered perfectly. Thanks.
Mar 09, 2011 | AOpen DUW1608/ARR (914ID37002) DVD±RW...
AOpen DUW1608/ARR firmware flash failed and now it thinks it is a ricoh uploader2 . How can I reflash this drive with the proper firmware?
you will need "flash magic" software, a device to provide 12V power supply to device, one cable to transfer data,download the working firmware for you device and save it to your device.
Mar 01, 2011 | AOpen DUW1608/ARR (914ID37204) Burner
My dvd drive starts and then stops and the light keeps on blinking.Can anyone help me with this?.....(AOpen DUW-1608/ARR Chameleon 16x4x16x DVD+R/RW 8x4x16x DVD-R/RW 42x32x42x CD-R/RW 2.4x DVD+R DL Dual......
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Dec 30, 2010 | AOpen (DUW1608/ARR) (914ID37202) Burner
My dvd player starts then stops and the light keeps blinking.Can someone tell me what's wrong?(AOpen DUW-1608/ARR Chameleon 16x4x16x DVD+R/RW 8x4x16x DVD-R/RW 42x32x42x CD-R/RW 2.4x DVD+R DL Dual......
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Dec 30, 2010 | AOpen DUW-1608/ARR Chameleon 16x4x16x...
It is not detected as a DVD it is only labeled as a standard CD thought DVD's can be read but burnt, how can i fix that problem?, i already tried downloading drivers from AOpen.com but everything remains...
Have you checked how the drive is listed in device manager? You may need to find the Firmware for your model of drive and Flash it. This usually isn't as hard or scary as it sounds. :)
Jul 17, 2010 | AOpen DUW1616/ARR DVD RW Dual Layer Burner
Drive Can't Burn DVDs
If it is a combo drive then you cannot burn DVD's with it.
A combo drive can burn CD's and play DVD's
If it is a burner, then install Nero and burn DVD's with that. But as above, if it says it's a COMBO drive, then it can't.
Apr 21, 2008 | AOpen DUW1616/ARR DVD RW Dual Layer Burner
READ DVD
if u got a cd with ur DVD RW u neet to install the drivers and then reboot the pc
Oct 12, 2007 | AOpen DUW1616/ARR DVD RW Dual Layer Burner
Aopen DUW1608/ARR Problem
Right click on my computer>properties>device manager>hardware and look for line saying cd/dvd drives and highlight your dvd burner. Right click it and click uninstal. Restart your pc and Windows will automatically re install it. See if this works, if not either needs a lazer clean disc or you need to replace it they are cheap these days.
Nov 02, 2006 | AOpen DUW1608/ARR (914ID37204) Burner
Won't burn
Check which flate cable do you have for its connection. AOpen recommendation is for 80-wire ATA-66/100 cable. In case this is not the cable you have, you should replace it. (The ATA/66/100 IDE cable is made from 80-conductor wire with 40 pin connectors, providing the superior ground spacing required by the ATA/66/100 specs, and allowing the full 100 Mbps burst transfer rate). Another AOpen recommendation is to configur the unit as a "Master" and not as a slave. Good luck
May 05, 2006 | AOpen DUW1608/ARR (914ID37002) DVD±RW...
AOpen DUW1608/ARR (914ID37204) Burner Logo
127 people viewed this question
Top AOpen Computers & Internet Experts
Alun Cox
Jim Goldsmith
Jim Goldsmith
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
