Question about GE Profile TPX24PBDCC Side by Side Refrigerator
How do I replace the wood door panel on a Profile TPX24PR side by side
3 Suggested Answers
erpaalai
  • 999 Answers
SOURCE: Ge Profile Stainless Steel Refrigerator panel replacement
You can replace the doors but you will think you bought a new frig when you see what they cost. Most come as an assembly and are very expensive.
Eric
Posted on Jun 29, 2009
DeBruce
  • 145 Answers
SOURCE: Can I get a replacement door for my GE Profile Refrigerator
Warners Stellian in Minneapolis can help.
For cleaning DeBruce Polish is the answer.
DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is perfect on stainless steel, glass cook tops, polished granite marble and more. We buy DeBruce at debrucepolish.com.
Posted on Mar 05, 2010
What are the different types of cabinet doors?
wikipedia provides a good explanation, quoted below:
Frames
. In the U.S. solid wood frame and panel construction, using either mortise and tenon or cope and stick jointed frames, is traditional, with maple, cherry, oak, birch, and hickory among the most commonly used species. Mortise-and-tenon frames, with their greater strength and permanence, are more costly to produce and less commonly used as compared to cope-and-stick frames. As an alternative, miter joint frames, which may be identifiable by face-surface relief that follows continuously around the frame, have become popular. Miter-jointed frames typically employ embedded metal fasteners to secure frames elements (stiles and rails) cut at a 45 angle. Captured within frames, panels may be either solid or veneered engineered wood (either particle board or medium density fiberboard). Laminates, including those designed to resemble hardwood, can typically be identified by a more rounded appearance associated with the minimum bending radii necessarily entailed by the manufacturing process of applying laminate to an underlying substrate. By comparison, solid surfaces, and solid hardwoods in particular, can be milled with more sharply defined corners, edges, or grooves on either a panel or frame.
  • Panels. Panels used in frame-and-panel kitchen cabinet doors may be fashioned either of solid wood or covered by paint, veneer, or laminate in which case they are fashioned of engineered wood. The panels are typically not fastened with glue or nails but rather "float" within the frame to accommodate seasonal expansion or contraction of the wood frame.
  • Solid-door construction. Doors may be fabricated of solid material, either engineered wood (particle board or medium-density fiberboard, but not typically plywood) or solid wood. Engineered wood panels may either be used as slabs or may be shaped to resemble frame-and-panel construction. In either case, engineered wood panels are generally painted, veneered, or laminated. Solid wood panels are typically formed of multiple boards of the selected wood species, jointed together using glue and may either be painted or finished. Solid wood construction offers the possibility of refinishing in case of damage or wear.
  • Decorative panels. Cabinet doors panels can be used decoratively on cabinet sides, where exposed, for a more finished appearance.
  • Glass door construction options. Doors may have glass windows constructed of muntins and mullions holding glass panels (as in exterior windows). Other designs either mimic the divided-light look of muntins and mullions with overlays, or may dispense with them altogether. Cabinets using glass doors sometimes use glass shelves and interior lighting from the top of a cabinet. A glass shelf allows light to reach throughout a cabinet. For a special display effect, the interior rear of a cabinet may be covered with a mirrors to further distribute light.
Jan 30, 2013 | Hardware & Accessories
Fridge light does not work.
Some appliances have electrical schematics on the back of the fridge, some are hidden behind rear cover. Wire,Switch or fuse..not much else it could be.
Aug 24, 2012 | GE Refrigerators
I have a new GE Profile dishwasher and granite countertop. How do I attach it so it doesn't tip. I can't use the tabs at the top as the granite is right there. Any help?
Open door and look for removable hole cover along left and right side, several inches down from the top. Use a wood screw to secure the side of the dishwasher to the cabinets there, then replace the hole covers.
Mar 21, 2011 | GE Profile PDW9880NSS Stainless Steel...
Need to replace s.s. panel with a wood door to match kitchen, need instructions on removing panel
Depending on the type of dishwasher there should be screws on the side of the door that can be removed on one or both sides to remove the frame surrounding the old panel. If your dishwasher door seems to wrap around the sides, you may have to order a custom panel from the manufacturer or you can check out ApplianceArt.com and see if they can help with a magnetic or vinyl cover that would goo over your existing panel.
Oct 12, 2010 | Asko D3531XLHDSS Stainless Steel Built-in...
I have a ge Profile side by side refrig model TPX24PR or BR or BI or SI. When we call for water or the ice maker calls for water, I can hear a hissing sound coming from the front right corner and then...
That hose actually ran Through the floor of your refrigerator on your model. so the leak is most likely under the floor of the fridge in the line coming from the water reseviour to the outlet.
Jun 10, 2010 | Refrigerators
I need to remove the wood door panels on my sub zero to repair a door handle
I have subzero 642 but it should be the same. Remove 2 screws on the top edge of the door. The screws attach a metal track to the top of the door and the track needs to be loosened to allow the front wood panel to slide out. Next on the side edge of the door are 3 metal strips. The middle one is held in place simply by magnets and slots at the top and bottom edges of the door. You can remove the middle strip by lifting it out in the middle with a small screwdriver and pulling it off. This will expose 3 or 4 screws that hold a metal track to the side edge of the door. Remove these screws and the metallic track on the side edge of the door. You can then slide the wood door panel out enough to expose the 2 screws that the door handle attaches to. Good luck!
May 16, 2010 | Sub-Zero 632 / S
Eric
Jun 29, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
X5 Door Panel Removal
there are 4 torx T-15 screws, one in the rear map pocket, one under the air bag logo plastic clip, one under the wood trim (pry the trim off carefully), and one holding the door handle assembly (also revealed when you remove the wood burl cover). Pick up a pry tool at autozone, about 5 bucks to pry the clips out without breaking
Jul 14, 2008 | 2001 BMW 5 Series
GE Profile TPX24PBDCC Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
