Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony Wega model # KV-36FS12 it doesn't work can u help me?
When i turn on the television the screen turns purple with lines going across it.
    New Friend:
  • 76 Answers
This is due to humidity in your area. Due to moisture content screen control section getting corrosion. cleanit and adjust the screen control to get the normal picture.
Posted on Aug 24, 2007
TV TURNS ON,LINES ACROSS SCREEN THEN TURNS OFF BY ITSELF
sounds like a vertical problem, usually you'll see one white line across the screen, but one I worked on would come on and the bottom half of the picture was gone and there were lines across the top of the screen.
If you know how to solder & can find the vertical output chip then you could try resoldering the pins. If this doesn't fix it then it needs new parts.
Mar 08, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
6 horizontal lines
I would look for a Vertical circuit failure. Most likely is the vertical output IC and or open resistor off the hv transformer. Definitely look for any loose solder connections around the Vertical output IC.
Hope this helps,
Skyassoc
Jun 16, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
2001 Sony KV-36FS12 black screen problem
replace ic355 part number is 8-752-098 / or a cxa2131cs is the generic part number.
regards,
daniel.
Jan 13, 2009 | Sony KV-36FS12 36" TV
I GOT A SONY THAT I BOUGHT LAST JUNE OF 2004 NOW I CANNOT POWER IT'S JUST SAY STANDBY
1. Will it turn on at all?
2. How many times does the standby light blink? Is it consistent and continuous?
3. Did the screen do anything strange before this happened (did it turn pink? Any lines across the screen?
Answer those questions and I'll try to help you.
Nov 18, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
GREEN AND PURPLE LINES ACROSS THE SCREEN
This is a symptom of the circuit failing.
it will soon be much worse.
You need a tech.
you can verify it is the tv circuit.
remove cable or input another signal such as dvd
bring up the TV' menu. does it have the lines.
Jan 15, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony trinitron kv-36fs10
dear misskona, I suggest that if you have any technical knowledge the first thing you do is to increase the screen voltage and see if there is a bright line across the screen solder the vertical I.C or remove and fix another working one.if that do not solve the problem there is scat board solder some dry joint.
thanks
Dec 21, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony trinitron 32
Hi, tubes getting tired, band-aid fix you can do is remove back of set and turn up(clockwise) the screen control( small black plastic control mounted on side of flyback transformer, do not turn the knob marked focus) until you see a whole bunch of white lines across the screen, then turn same control counter-clockwise until all the lines go away, try several different channels to be sure all the retrace lines are gone, you`ll get up to 1 year more use out of it, than she`s done, good luck, BMW Rider
Dec 10, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Poor picture
In CRT board isolate RGB input. Check plain retrace lines appears in white colour. Then jungle ic failure. Otherwise problem in crt board. Maybe dry soldered.
Aug 18, 2007 | Sony KV-36FS12 36" TV
Hello im having problems with my sony wega
It sounds like you have a loss of green. This could be caused by the green gun in the picture tube opening up or the drive circuit for the green gun gone bad. Stargazer
Aug 10, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
116 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
