Question about NetGear DM602 ADSL-Modem
My Mdoem's ethernet and usb lights are off
My modem's power light and internet light are on but eithernet and usb lights are off. My computer is also not detecting a lan network, saying lan cable is unplugged but in reality the cable is attached. Seems the modem's router function is not working. Any tips ?
    Scholar:
  • 85 Answers
Assuming you using ethernet to connect the pc to the modem: how about checking your ethernetLAN card on the pc if it's integrated with the motherboard you can enable it from the bios settings if it's an expansion card it sounds like you need the most up to date driver which can be downloaded from the card manufacturer's website if you have access to internet on another pc. assuming your pc is connected to the modem via usb: reinstall the driver for the modem . another thing you can do is buy a usb to ethernet adapter which are available for under $5 on the market one end connects to the usb port on your pc and the other end is ethernet and this should work .
Posted on Aug 11, 2007
PC link light is off while Internet and cable activity lights' are solid. Can not connect to the internet. Can it be fixed? If so, how?
The PC link light is your indicator if there is a device connected to the modem through the ethernet port. If its off, then you may need to check the connection once again whether it be a PC connected hardwired to the modem or a router. Replacing the ethernet cable can also help because it might also be a defective ethernet cable. As long as the internet and cable activity lights are both solid, its ok because that means your modem is receiving the signal from your provider.
Sep 17, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Tip
Troubleshooting DSL Modems
Ever look at your DSL Modem and wonder what all those lights mean? Why do some flash, while others remain solid? What if your lights are different colors? How do you tell if your DSL Modem is working correctly?<br /> <br /> Each light on your DSL Modem represents a function. The light is an indication of whether that function is working properly. Sometimes the placement and title of each function can vary by modem manufacturer, but they are pretty standard in interpetation. If you look closely your modem, you might find that each function is labeled in small print to help identify them.<br /> <br /> A standard DSL Modem has a light for power, internet, ethernet, link and wireless connection. A healthy DSL Modem will have a steady green light that does not blink or flutter for all features other than internet, ethernet and wireless. A flashing or fluttering light indicates movement and useage. When you are connected to your DSL Modem wireless, the light for this feature will blink indicating a connection and/or active useage. If the internet connection is working properly the color of the light will be green. If the connection is working but experincing a problem the light can turn to yellow or orange. If the connection fails, the light on the DSL Modem can be red or absent depending on the problem causing the trouble. If your service is turned off by the provider, more than likely the light will be "off".<br /> <br /> If your lights turn a different color, are absent or your internet connection fails try power cycling your modem before reporting the trouble to your provider. Power cycling helps the DSL Modem to reset its connection and repair your internet services.<br /> <br /> If you are using a DSL Modem alone to connect to the internet (no additional router) you can power cycle it by first turning off your computer and then unplug the modem itself from the power source at the wall. Wait for 1 to 2 minutes and then plug it back into the power source and wait for the warm up to finish before rebooting the pc.<br /> <br /> The DSL Modem should go through the normal warm up procedures of blinking lights, making them all stable and solid green ect. You will know when its finished warming up when the features are set at solid green (other than eithernet, internet and wireless connection as explained above). When the modem finished the warm up, reboot your computer and check your internet connection.<br /> <br /> Power cycling your DSL Modem can help keep your connection healthy and running at optimal speeds.<br />
on Mar 30, 2011 | Computers & Internet
My D-Link DI-524 will not reconize my IP address. What can I do? I reset the box and the lights continue to flash when they should have stop blinking.
remove all the cable conencted to your D-link except for the power cable of course ^_^ if the lights stops from blinking then possbile one or more of the ethernet ports on your router is malfunctioning try connecting the modem to your router by trying all the ethernet ports on the router until you see the lights stop from blinking if the lights stop blinking then that port is still usable on the router but in any case it also may be the routers settings you might need to set your router to the modems settings depending on your internet if it is DSL and you are using PPPOE there must be a user name and password that you need to input in the router for a calbe modem no need but since your situation is as we speak I do not think you have a cable modem for your internet, you might need to call your Internet service provider as well for further info for the user name and password the mdoem has unless you know how to get the user name and password from the modem ^_^ as far as I can go that's all
Jun 04, 2010 | D-Link AirPlus DI-524 Wireless Router
Net Gear Adsl DM 602 modem ether net inter net and usb port
unplug modem for 30 seconds and re-plug if that fails do a hard reset ( button).
Sep 17, 2017 | NetGear DM602 ADSL-Modem
Vista desktop won't connect to internet cable modem eithernet
power down cable modem, router, and computer. Connect ethernet cable from modem to router/ and connect ethernet cable from router to PC. Power up cable modem first, after modem shows connectivity, plug in router. After router shows internet connectivity, start computer. Be sure that you LAN card operable
Apr 15, 2009 | Acer Computers & Internet
Cannot connect ot xbox live my ip address test fails
if you dont have a router, you can either have the xbox or the pc conneted to the internet, not both. you have to have an eithernet cord or a usb 2.0 high speed usb chord that goes directly from the xbox to the modem. you cannot go from the modem to the computer then to the xbox.
Jan 24, 2009 | Microsoft Xbox 360 Console
No connection when installing WGT624 Netgear router
Plug an ethernet cable into the wan port of the router from your virgin modem... then plug ethernet cable from computer into a port on the router....that should solve your problem.
Jan 09, 2009 | NetGear WGT624 Wireless Router
Connecting a wireless router to Tiscalli broadband connection
  1. USB modem is connecting a PC USB port with a DSL phone line: CANNOT be connected to a ROUTER LAN (ethernet NOT USB port).
  2. Wireless ROUTER is NOT a modem and it CANNOT connect the Internet (or WAN) LAN port to any "phone line"
  3. Connect the Router Internet (WAN) port to Modem (you need a LAN MODEM = a modem with a LAN/ETHERNET port)
  4. Be sure your internet is running before strting ROUTER configuration with Router Company CD
Jan 05, 2009 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
DSL modem connected but no internet
Have you installed DSL filters on all your phones and make sure you don't have on on the line for your modem?
Jun 28, 2008 | Westell Wirespeed LiteLine 6100...
NetGear DM602 ADSL-Modem Logo
292 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
