Question about Ovens
Smeg SA708X Oven symbols have rubbed off the entire oven.
Can you please provide a pic and can you please provide a manual.Thank you
4 Suggested Answers
TaPuna
  • 70 Answers
SOURCE: smeg oven model SA708X--Clock faulty
hi, if you have a faulty clock it is likely the relay in the clock is stuffed you could try to repair it but i think you are better off just buying a new clock, clocks are expensive thou, so bypassing is a good choice
Posted on Sep 09, 2008
SOURCE: SMEG SA708X oven's symbols have rubbed off, wioul
Here's a picture of the panel... BTW does anyone know the wiring / have a wiring diagram for the door switch as mine was swapped around by an oven guy just to get it running but now I have a new switch and can't remember how it all goes!!
Posted on Jun 01, 2010
SOURCE: Symbols have rubbed off for the Smeg SA708 oven
I Have The Same Problem Have You Managed To Work Yours Out??
Posted on Dec 01, 2011
Help! I have a Smeg oven Model Number: SA410X-5. All of the symbols have come off. I have just moved in to a new place with this oven and have no idea what the symbols are meant to be! Im urgent need of...
here is the manual
Smeg Multi Function Built In Oven Operation Manual
specs
Description
Smeg 60cm Stainless Steel Single Oven. Model: SA410X-5
  • RRP: $1,490. The RRP is supplied by the manufacturer and is based on a brand new item, not used. It is accurate as at 1st April 2010
  • Dimensions: 595mmh x 596mmw x 567mmd
  • Smeg thermosealed, fan forced, six function, 60 minute timer
  • Capacity 66.4 litre gross, 56.1 litre net
  • Installation underbench or wall (column), fascia: flush or proud mount
  • Thermostat variable 0 -250 Celsius
  • Multifunction five cooking functions plus defrost, timer 60 minute max, variable count down timer
  • Part number: 9842 (SN:SA410X-5) (145924-2)
Spares and schematic
SMEG SA410X 5 Parts List BigWarehouse Spares
New Fascia Stickers for 15.00GBP
Smeg SA410X facia stickers for worn fronts
Apr 03, 2018 | Smeg Ovens
Fixed fan element, but can't remember how to put it back together again
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Jun 22, 2012 | Smeg Ovens
SMEG SA708X oven's symbols have rubbed off, wioul appreciate a photo of the left hand (have only managed to find the dial template for teh right side dial)
Feb 26, 2010 | Smeg S1100MFX5 Electric Single Oven
Dials of our smeg oven have rubbed off
You need to disclose the model for any help.
Mar 06, 2017 | Smeg Ovens
Aug 31, 2009 | Smeg S1100MFX5 Electric Single Oven
SMEG SA708 oven's symbols have rubbed off.
The oven symbols have rubbed off my electrolux oven. It's not even 3 years old. Please can you help?
Jul 26, 2009 | Smeg S1100MFX5 Electric Single Oven
Meaning of symbols on oven setting.
i would know them if i were looking at it but hope this helps
line at top - top element only
line at bottom - bottom element only
line at top and bottom - conventional oven ie top and bottom elements on
wavy line - grill element
pic of fan - fan only with no heat
pic of fan with a line as well - fan oven
youi may not have all of these depending on oven.
best to use i find is fan oven - i do a lot of cooking!
Nov 05, 2008 | Smeg SE250XUK Stainless Steel Electric...
Smeg oven model SA708X--Clock faulty
Sep 08, 2008 | Ovens
SMEG SA708X Oven Heater problem
thermostat must be getting a blast of cold air from the door being opened.
Sep 06, 2007 | Ovens
Ovens Logo
13 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
