SOURCE: skagen mesh band shorten
just solved the mystery...U probably have too ..by now....but just in case..
here is a fun link to the solution by an actual user....was actually inspired by him...coz like I said I had mispaced the manual...
http://www.amazon.com/review/product/B0000C9ZBX/ref=dp_top_cm_cr_acr_txt?_encoding=UTF8&showViewpoints=1
I just used my nail file and lifted the locking mechanism and moved it forward...Now I can sleep better tonite....!
Mrs Martin
SOURCE: How to adjust Skagen watch band.
You may have
arrows inside bracelet.Arrows are pointing the way the pins must come
out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws.
If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx.
size of pin end diameter using any sharpening stone or sandpaper. Get
an old towel and fold it to make a soft base for work (like small
cusion). As you don't have a special bracelet holder you will need a
pair of helping hands to hold the bracelet steady upright. You will
need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make
sure that the grooved pin ends are facing towel, not the needle and
hammer!!!
Now place the watch on the folded towel, take that needle and smallest
hammer you have and start driving the pin out using light blows. Do Not
hit hard, as you will brake the needle, scratch your watch or even
injure yourself. Watchmakers are using 45 gram hammer, so, calculate
your strength of blows.
After a few blows check if the split end is coming out and when you see
that the end is long enough to grab it with pliers, pull the pin out
with pliers. When pulling, do NOT turn pliers, as pins tend to brake
when twisted. Use firm grip and your strength to pull the pin without
twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY
the same way as they came out- the blunt end first in the hole and the
split (grooved) end last. Before doing that check remaining pins in
bracelet to make sure that you put them back from the right side of
bracelet.
It is recommended to use plastic hammer to drive pins back in or you
will scratch or damage bracelet. If plastic hammer is not available use
an old toothbrush handle (or some plastic item) as an absorber. Simply
put pin into the hole as deep as you can with your fingers, put the
toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
SOURCE: Where can I buy a replacement watch band for a
hi..you can buy it from the following place.
http://www.amazon.com/Skagen-Mens-Titanium-Watch-396LTTM/dp/B000ETU7M8
check it out..
thank u..
rate me..
SOURCE: Skagen ladies watch mesh band coming apart
As SKAGEN have their own traiding rules you will not be able to get watch band in shops or even at the dealer otlets.
All I can do is to give you a link to send to Skagen a required part doc:
http://www.skagen.com/service/home.fx
When the page is open click on PARTS REPLACEMENT FORM and give all the details asked.
Rate, please.
SOURCE: Cannot find Skagen watch band for model 433LSLB
Follow this link and find what you are looking for:
Rate me, please.
