Fix 37hfl5581/27 philips
Wont turn off with remote or on tv goes off for a second then comes back on
SOURCE: TV not turning on.
Mine was doing that and I ordered a replacement power supply board for it and now it work. It's fairly easy to replace.
http://www.partstore.com/GetModel.aspx?MfgName=Royal+Philips+Electronics&BrandName=Philips&ModelNumber=37PF7320A37&page=16
Posted on Mar 27, 2008
  • 476 Answers
SOURCE: cant work my freeview
The [A/D] button on the remote control switches between analogue and dgitial TV.
If this doesn't work you can restore the TV to factory settings as follows:
Press and hold the [Menu] button on the TV (NOT on the remote)
The picture / sound / features menu will appear.
Continue to hold until this menu clears.
Release the [Menu] button and wait for about 90 seconds.
The TV will go blank and eventually return to the original install menu.
Install the TV as you did from new.
This will clear ALL analogue and digital TV channels and install again from scratch.
This should be used if the TV ever freezes on digital, or if any of the channels appear in the wrong place or not at all.
Posted on May 08, 2008
  • 44 Answers
SOURCE: i have a 42 in philips tv that wont turn on green light comes on
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 25, 2009
  • 367 Answers
SOURCE: TRUTECH PLV16190 wont stay on keeps turning off.
Open the back of the TV,and look at the can shaped items called capacitors on the circuit boards.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
Posted on Jun 28, 2009
  • 556 Answers
SOURCE: Menu Screen keeps popping up, interrupting cable stream on tv
You have it in the demo mode go into menu and turn it off.
Posted on Aug 06, 2009
Why does my Philips 40" flat screen tv shut off 15 seconds after I turn it on?
The symptom you describe suggests power supply failure. It is still working but fading fast
Mar 24, 2013 | Philips 40pfl3706/f7 Lcd Flat Panel Tv
Wont stay on when cold
This sounds like a power regulator issue. Check the site www.TvRepairKits.com for a "shrinking and expanding" video kit for your model. It also fixes the random off/on when the tv is cold
Mar 06, 2013 | Philips Televison & Video
I have a Philips 52PFL7422D/37 52" TV. For the last year now the TV will make a clicking sound like it is turning on but never does. After a couple of seconds to a minute the TV makes another...
I have the same model and the same problem... I am told the power display board is is the issue and may need to replacing. New board costs around $80,or a bad capacitor depending on your paitence.
Nov 23, 2010 | Philips 52PFL7422D/37 TV
The TV keeps going to the MENU on it's own...When you exit to TV it goes back to menu within 5 seconds
Hey djames1971 - did you ever get this resolved? My Philips is doing the same exact thing now; sooooo annoying. If I keep monkeying with the exit setting it eventually goes to the TV and stays there, but it doesn't fix it by any means. Next time I go to turn it on I have the same battle with it.
Jun 15, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 32'' when turned on picture goes off after 5 seconds
hello. ok try this. first take the remote's out of the room the tv is in.!!! yes both of them. then i want you to turn the tv on with the power button on the front of the set. and tell me what .? happen's..and please dont try to turn thechannel or any thing else !!! .just turn it on.!!! "am" waiting
Jan 03, 2009 | Philips 32PT6441/37 32" TV
I have a Philips 50 inch TV.
May be related to a faulty IC. Check www.magnavoxhelp.com for a fix.
Jun 05, 2008 | Philips 50P8341 50" Rear Projection...
Tv wont turn on
TV STARTS UP AND GOES BLANK SOUND NO PICTURE
May 16, 2008 | Philips 32PF5321 32 in. HD-Ready LCD...
TV not turning on.
Mar 14, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
60P8341 Rear Projection - Remote does not work
Your TV needs the part 313501707611 - it's the keyboard that's the cause of your problems - but here's the catch... Philips does not make that part anymore... they say that you need to either find someone to fix the keyboard (which I've had no luck on) or buy a new Television from them... hmm, a $2000.00 TV that needs a $20.00 part now becomes a plant holder in my living room because Philips wants us to purchase a new TV from them.
Oct 06, 2007 | Philips 60P8341 60" Rear Projection...
Philips 42PW9982 TV does not turn on
The most common issue i find with Plasma TV's acting like this is a failed power supply in them, usually due to leaky/failed capacitors. About your only option is to find someone with the know-how to repair it, as its almost impossible to find a replacement board. I fix more TV power supply boards then anything else these days.
Jan 01, 2018 | Philips 42PW9982 TV
Televison & Video Logo
152 people viewed this question
Top Televison & Video Experts
