Question about Schwinn Cycling
Schwinn S40 dsx Derailleur bent.
While on my ride up a 15 degree grade hill. it bent and twisted the derailleur and hanger. Is there a replacement part for this?
4 Suggested Answers
  • 4 Answers
SOURCE: Schwinn S40 DSX part name
Forget new guide wheels. A new rear derailer is the real fix. You will need to order a new one by the number of gears on the rear gear cluster. How the derailer is mounted, Which way it moves when by the spring direction etc... By the way, get a higher quality one than the one you have got. If you go megawheel on the lower guide wheel; which I recommend, you might need a couple more segments in your chain. Yes, you need a new chain. If you wore out a part on you derailer, your chain is getting old. I recently bought a new rear derailure for my wife's bike for 29 bucks at a much better quality than the old one. It does not have problems of getting between gears, clicking etc... like the old one did new.
Posted on Jul 08, 2009
dunnbiker
  • 8546 Answers
SOURCE: where can i get a new rear derailleur cable for my
Take it to Local Bike Shop. They'll evaluate the problem and install it for you, plus new cable housing if necessary.
Posted on Mar 23, 2010
Coachphil
  • 347 Answers
SOURCE: my sram x-7 derailleur hanger
You need to replace the main pivot bolt, something (most likely a tab) is broken. This one is best taken to your local bike shop for inspection. There may be something your missing like a crack in the body or another broken part. Link to Manual.
You can also contact the SRAM customer service for support, but they will refer you to a shop to take care of the problem and order any parts on this type of problem.
Posted on Dec 14, 2010
My chain slipped, the part attached near the back wheel... "the two small wheels that rotates the chain I believe that it shifts the gears" it has fallen off and bent doing the time it was...
Ask a local Bike Shop. Derailleurs for that bike are cheap. Evaluating the bike for a bent derailleur hanger and fixing it is a job for the pros. Word to the wise. Never pedal backward or roll the bicycle backward if it is the rear derailleur is not precisely aligned with a gear. It WILL rip bend or the derailleur right off.
Aug 11, 2011 | Schwinn Bikes 26 Womens Southport Cruiser...
Mongoose Maxim 26" mens bike-
If it's "broken" or even bent it will have to be replaced. Your frame or derailleiur hanger may also have taken a fatal hit.
You should consult a Bike Shop.
If you still want to DIY you'll need to obtain some specialized tools and skills.
http://www.parktool.com/blog/repair-help/rear-derailleur-hanger-alignment
http://www.parktool.com/blog/repair-help/chain-installation-derailleur-bikes
http://www.parktool.com/blog/repair-help/categories/derailleur-systems
Jul 09, 2011 | Cycling
Mongoose 21speed spear derailer is bent. bought at yard sale 60.00 dont want to put much money into. what is the best way to fix this. how much? Want to use as spare bike. it is rideable but how long....
A new Rear Derailleur may cost more than you paid for the bike. But is IT bent or is it the derailleur hanger?
Search the web for "fix bent derailleur"
Steel frames can be re-formed but not most other materials.
Someone in your club should know how to deal with it and maybe even have an old derailleur hanging around.
Jun 30, 2011 | Cycling
Plate That Derailleur is attached to is bent. How do I unbend it. Where do I find wrenches/srcrewdrivers if I need to remove derailleur from plate.
If you mean the frame member/dropout to which the derailleur is attached, CAUTION!!!!
A real Bicycle Shop will have the tools necessary to straighten and align it.
Read this:
Or you could just wing it and use this procedure...
http://www.utahmountainbiking.com/fix/rhanger.htm
As far as where to get tools??? Special tools can be found at a Bicycle Shop.
May 07, 2011 | Pacific International Schwinn Southport...
I need a derailleur hanger for a Schwinn S-25 dual suspension mountain bike. I don't have the hanger. Is there a part or model number for the hanger so that I can order a new one?
Most bike shops can match up the broken pieces. If that doesn't help check this link to see if you see one that looks like yours.
http://www.jbimporters.com/web/advanced_category_result.php?CatOneId=DERAILLEURS&CatTwoId=REAR+SMALL+PARTS&CatThreeId=WHEELS+MANUFACTURING&dfadfkawe45d9drh=3
In case you are not aware Schwinn folded in 1999, The name is now being used by Pacific Cycles. If all else fails you might be able to order one from them. Good luck.
Dec 20, 2010 | HP Vs17 17" LCD Flat Panel Monitor
My sram x-7 derailleur hanger broke and i bent the derailleur. I've replaced the hanger and re alligned the derailleur but i went to bolt the derailleur back onto the hanger but the bolt doesnt seem to be...
Dec 14, 2010 | Sram X7 Mountain Bike Rear Derailleur
Where can i get a new rear derailleur cable for my Schwinn S40 DSX bike?
Mar 23, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
The chain is rubbing on the rear tyre when its free wheeling. what do I do?
You may have too large a tire on the back for the bike. However, if the derailleur hanger is bent, this could also cause the problem. Flip your bike over onto the bars and seat and make sure the derailleur alignment is good (vertically and longitudinally straight). If the derailleur hanger is straight, then you will have to use a narrower tire in the back.
Jun 30, 2009 | Mountain Shimano Tourney 6/7 Rear...
Cycling Logo
102 people viewed this question
Top Schwinn Cycling Experts
Tony
michael
michael
jasiel murphy
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
