Question about Sony KP-61HS10 61" Rear Projection Television
Sony kdf-e50a12u rear projection lcd bravia. red shadows
Hi there .. i have the above mentioned tv .every thing is ok when i am watching my sky hd, there is no shadows, but whenever i turn on my ps3 or hd dvd player i get red red shadows to the left hand side of items on the screen like a ghosting. i have tryed new hdmi cables and still nothing changes. sometimes when i go to turn on my hd dvd player it wont turn on until i disconect the hdmi cable, but once i put it back in it works ok but still the shadows. even when i watch a dvd through my ps3 it still has the shadows... please help........ thanks 4 your time
  • joerogangolf Sep 06, 2007
    thanks for your advice. will just keep on playing and try to ignore the shadows. they are not really that bad. thanks 4 taking the time to offer me advise......CHEERS & happy gaming
    Sergeant:
  • 279 Answers
This *CAN* be fixed. This TV has a problem with running in the 60 Hz range with default factory settings, but it can be adjusted to remove the shadows. Be careful, though, the wrong setting in the service menu can really mess up a TV. Here's how you do it: To bring up the "service" menu, put the TV in standby mode, then press in sequence : Onscreen Display ( the little screen with the i+ in it ) 5 ( channel number 5 ) Volume Up ( upper end of volume button ) Analogue ( middle top button ) The TV should switch on and when it's warmed up, you should see a screen with lots of big green lettering on it. Press the "menu" button ( middle bottom ) Use the direction dial to move down to "LCD Drivers" and press right on the dial to enter this menu. Move down to "S H Pos Reg R". It should be "10", change it to "11". ( Left/Right to adjust ) Move down to "S H Pos Reg G". It should be "10", change it to "11". Move down to "SHPos Reg B". It should be "10", change it to "11". Press the menu bottom to drop out of the menus, and the standy button to drop to standby. Switch back on, and hopefully your ghosting will be gone.
Posted on Sep 21, 2007
    Sniper:
  • 133 Answers
This is due to you having a projection tv, some projection tvs are really bad for game playing and especially if you have a hdtv. even in the p23 manual it says that you shouldnt use with a projection tv cause it can damage your tv's screen permanently. I personally still play mine but, thats likly the problem.
Posted on Sep 06, 2007
  • Anonymous Sep 14, 2007
    please repost and rate this solution thanks!
3 Suggested Answers
6ya staff
SOURCE:
dockterok
  • 603 Answers
SOURCE: ghosting on hdmi channel on my sony bravia
With HDMI there should be no ghosting. And being a Sony Bravia it should be no ghosting. My 52" Sony is great.
You've got connection issues.
Posted on Nov 25, 2009
Anonymous
SOURCE: Sony kdf-e50a12u rear projection lcd bravia. red...shadows
try this http://www.avforums.com/forums/showthread.php?t=459681
Posted on Oct 02, 2007
Picture all blurred when playing bluray
Connect the blu-ray player into the HDMI port that currently has sky on it. Does it work then? if so the port you were using has failed. If not the blu ray player has failed.
Dec 28, 2013 | Sony Televison & Video
I have sony lcd hd ready 50inch rear projector tv model number KDF-E50A12U tv comes on after couple minuets tv clicks off to stand by then red light in stand by flashs 3 times gos back to green repets
Hello
Three blinks of standby light to Sony TVs indicates that the regulated voltage output from power regulator board is above thatn normal. The problem is with its power supply regulator board. Replace all the electrolytic cpacitors on that board with new ones. Replace all of them including small and large ones, at one time. OK.
Feb 04, 2012 | Televison & Video
Hi i have a sony lcd projection kdf-e50a12u and as i turn it on the green light flashes for a few minutes untill it turns to red along with the light next to it and stays red?
Sir check the lamp of your projection if already damage, if damage replace the lamp and reset also the lamp hour meter. Remove the screws to open the panel labeled "lamp" on the back of the Sony TV. Remove the screws that hold the lamp in place inside the TV. Pull the lamp out. Let me know what is your observation to the lamp so I can guide you. Good day and best regards.
Sep 15, 2011 | Sony KDF-E50A12U 50" LCD HDTV
Sony bravia KDF-E50A12U rear projecion tv wont turn on
Hi it sounds like it could be an issue with board that powers the lamp ,it's called the ballast.When you put a new lamp in the ballast has to provide more power ,when it starts to go weak it will not light up.Sometimes you can put your old lamp in and will work fine.Try partstore.com they might have it right there.Hvae a blessed one!
Mar 02, 2010 | Televison & Video
Fuzzy picture
You can't make SD look like HD thats why HD came out, the best you can do is adjust the picture controls to get the optium picture
Apr 11, 2008 | Sony KP-57WS500 57" Rear Projection...
Shadowing on screen
You should get a good surge protector. Sometimes some areas have a spike in the power. That will cause interference in the TV signal coming from your PS 3. Try out different surge protectors that should solve your problem.
bimmerhp
Jan 23, 2008 | Sony Playstation 3 (PS3) Console
Aug 11, 2007 | Sony KP-61HS10 61" Rear Projection...
Sony KP-61HS10 61" Rear Projection Television Logo
288 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
