Question about Frigidaire GLMV168K Microwave Oven
Frigidaire Microwave Model GLMV169DBB
Turned on the microwave and a large pop/explosion came from the top right of the unit behind the louvered black fan area. Any ideas? It sounded pretty bad, (enough to make me jump at least 6 inches) and of course it is just out of warranty. Please advise. . . .
  • Anonymous May 29, 2008
    TURNED ON AND SOUNDED LIKE THE 4TH OF JULY. FIRE AND SPARKS BLOWING OUT UNDERNEATH NEAR THE EXHAUST AND LIGHT BULBS. SO SEVERE THAT IT BLEW OUT EVERY UNIT LINKED TO THE FUSE BOX. MICROWAVE IS SHOT.
  • 725 Answers
All the good stuff is on the right side so it could be a lot of problems... most likely it is a the high voltage capacitor. does the microwave work at all? let me know and I maybe able to help?
Posted on Aug 18, 2007
SOURCE:
Change interior light In my ge pvm1870sm3ss microwave
have to take the outer shell off to access the light .
Mar 09, 2016 | GE Microwave Ovens
How do i get the air vent cover off, so I can clean grease from the top.
Good Afternoon Friend,
I understand you are trying to the air vent cover off your Frigidaire microwave, model# PLMV169DC, so you are able to clean the grease from underneath the top cover. Please follow these instructions:
1. Disconnect power to the microwave oven at the circuit breaker panel or by unplugging.
2. Remove the louver mounting screws.
3. Pull the louver away from the unit.
4. Change the charcoal filter.
5. Carefully push the louver back into place and replace the screws removed in step 2.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 18, 2014 | Frigidaire PLMV169DC Microwave Oven
FGMV205K cover removal
I understand that you want to know how to remove the cover on your Frigidaire microwave, model# FGMV205K. There are two different covers that you are able to remove for access to two different light bulbs.
If you are trying to change the Microwave Oven Light for inside your microwave:
    1)To replace light bulb, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
    2)Remove the louver by removing the three Hood Louver Screws.
    3)Push in the upper tabs and pull the louver away from your appliance.
    4)Remove the light bulb and replace with a new 20 watt light bulb. DO NOT USE BULB LARGER THAN 20 WATTS.
    5)Close the Oven Light Cover by carefully pushing into place. Push the louver back into place (engaging both the bottom and top tabs) and change to hood Louver Screws.
    If you are trying to change the light bulbs underneath your Microwave:
      1)To replace light bulbs, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
      2)To open Light Cover, remove the screw on the light cover.
      3)Replace the light bulbs with new 20 watt light bulbs. DO NOT USE BULBS LARGER THAN 20 WATTS.
      4)Close the Light Cover and secure with screw removed at step 2.
      If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
      -Best Regards-
      WP
Jun 07, 2014 | Frigidaire Gallery FGMV205K 2.0 cu. ft....
GE spacemaker profile xl 1800 moving vent will not close
I'm betting your base model number is JVM1860, JVM1861, JVM1870, JVM1871, JVM3660, or JVM3670.
That's the automatic louver you're having trouble with. There are micro switches in the louver assembly which tell the controller when the louver is open or closed.
If one of those switches or the louver motor fails, the louver will not work correctly.
Did your cooktop lights recently fail?
Sometimes the surge from them shorting will cause damage to the circuit board, which can be repaired.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 03, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Where are the fuses located on a samsung electric range oven FTQ3521WW model #
Hello
Fuses can be located behind the microwave door or behind a panel either on the interior wall or an exterior panel. Often the fuse will be behind a panel located under the louver vents on top of the microwave
Oct 04, 2011 | Microwave Ovens
Hello
Fuses can be located behind the microwave door or behind a panel either on the interior wall or an exterior panel. Often the fuse will be behind a panel located under the louver vents on top of the microwave.
Ss25 microwave no power fuse in plug ok, where is internal fuse.
Hello
Instalation Instructions for Frigidaire Over the Range Microwave 850 Watt Model #FMT118EPB
HI,
Frigidaire makes several over-the-range microwave models that are all installed in the same manner. To install correctly, you must have at least 45 1/2 inches from the bottom of the top cabinet to the cooking surface of the stove to provide enough clearance for the microwave. The top cabinet must also be at least 30 inches wide and 12 inches deep. Find someone to help you, then follow the steps below to install your Frigidaire microwave.
Things You'll Need:
  • Stud finder or hammer
  • Screwdriver
  • Drill
Instructions
Pull your range away from the wall so you can work comfortably. If this is not possible, cover it with a drop cloth. Find and mark the locations of the studs in the wall behind the range. They will be either 16 or 24 inches apart.
Follow the instructions on the wall template to mark the location of the mounting bracket and the four anchor holes on the wall and the bottom of the cabinet. Drill the anchor holes. Follow the instructions on the top cabinet template to mark and drill the two holes in the bottom of the cabinet.
Attach the mounting bracket to the wall studs using the six wood screws included with your microwave. Screw the toggle nuts onto the toggle bolts and push one through each of the four drilled holes. Screw each toggle bolt until the nut is snug against the inside of the wall.
Pick up the oven with your helper. Plug the oven into the outlet and slide the oven onto the mounting bracket arms. Push the oven back against the wall. Tighten the two screws on the microwave faceplate to fasten the microwave to the mounting bracket arms.
Attach the louver to the top of the microwave with the three provided screws. Insert the two top cabinet screws and washers from the top cabinet into the microwave and fasten tightly.
Take care.
Jun 16, 2010 | Frigidaire Microwave Ovens
Have whirlpool gold accuwave micro hood combo model# GH51884XPS5
The inspector is correct, air should be coming through the top louvers, although you sometimes will have a little air coming from the sides and back. Drop the microwave and see which way the blower is rotated, towards the louvers or towards the back or top. Some units also have a panel that blocks the venting from going the wrong way. Good Luck, Appliance Specialists
Dec 15, 2009 | Whirlpool GH8155XJ Microwave Oven
Frigidaire GLMV168K Microwave Oven Logo
355 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Ekse
Marvin
Marvin
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
