Question about Mitsubishi WD-73638 DLP TV
Screen flickers after the tv warms up i lose the blue
LCD TV - INTERMITANT BLUE SCREEN
Fault in the main board. You have to replace the main board. As it's have SMD components is would be difficult to repair.
If you wish to get some more details then check the following link.
http://electro-medical.blogspot.com/
Jul 13, 2016 | LG 37LC7D 37 in. LCD HDTV
Why is my Mitsubishi flat screen flickering green and blue
if it is starting to flicker green and blue that is a good sign that it could be going out. had a tv just like yours that started just flickering blue. about a month later it stopped working.
Jul 30, 2015 | Mitsubishi Televison & Video
Samsung SP47W3HFX tv blue flickering curved line..
If the lines are slightly curved and stationary on about 2/3 of the screen its either the Blue CRT or the Blue CRT drive board which is having the problem.
Dec 19, 2009 | Televison & Video
Flickering blue sceen
If it's a Gateway XHD3000, I may be able to fix it for you
I believe the problem is in the same board that causing the full strobing screen problem.
Cost is 150 to repair the problem board if it is fixable. No charge if not fixable.
You will have to pay round trip shipping for the monitor and power supply to Pennsylvania.
Ebays bammbammfran
Oct 04, 2009 | Gateway XHD3000 LCD TV
36 inch tube tv - Screen flickers
my problem is don't sound in my mobile LG CE 0168 please help me.
Aug 17, 2009 | Toshiba Televison & Video
Blue screen with flickering horizontal lines
Sounds like the 1000uf capacitors on the FMT board need replacing. This is a common symptom with that chassis. There are three 1000uf caps that fail on that PC Board
May 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Losing picture color on TV
Screen flicker can also be a bad dynamic black unit. Do you hear a low pitch growl when it flickers?
Dec 30, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Tv flickers when people walk in the room
Check for lose connections at the cable in thw rear of the television. Or look for a damaged wire.
Jan 05, 2007 | Panasonic CT-27E13 27" TV
Mitsubishi WD-73638 DLP TV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
