Question about Canon DR-7080C Flatbed Scanner
Jam indicator won't clear
Have gone through machine and cleaned all areas i can without pulling it all apart.Still says Jam every time i try a restart.
PA8558
  • 28 Answers
SOURCE: i860 False Paper Jam Message
Check the back of the printer. There should be door at the bottom. Your paper jam could be there.
If this helps you, please rate me. Thanks, Patty
Posted on Dec 30, 2007
  • 153 Answers
SOURCE: Machine thinks there's a paper jam
ok what you have done is when you have pulled the paper jam out you have either still have a small piece of paper over the sensor or you have broken the sensor itself it sounds like the later, most people tend to pull out the paper backwards against the feed rollers and sensors just below the feed rollers and it causes the sensor to fall out or break i have seen this so many times,
canon tech
Posted on Apr 14, 2009
mohanchennai
  • 490 Answers
SOURCE: dr 5010c feeds one to five sheets, then stops
Clean the rubber rollers (pickup and ******) with a damp cloth, loosen the papers to be scanned. Clean all the rollers in the scanning path. What is the eror that is displayed? Download the user manual from this site http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2341&modelid=11293 (5010um.pdf). Change the rollers if they are old.
S. Mohan, Chennai, India
Posted on Apr 17, 2009
  • 256 Answers
SOURCE: Rear Paper Jam - No paper present.
Look for a small piece of paper that may be stuck in the switch indicating a paper jam.
Posted on Jun 01, 2009
roit
  • 28 Answers
SOURCE: "Clear paper jam" error, but there is no jam!
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-23
Posted on Sep 04, 2009
Printer won't print after clearing a paper jam
I use to have an HP All-In-One Laser Jet printer that, for reasons unknown to me, wouldn't print after clearing a paper jam until I replaced the ink cartridge.
Jan 13, 2013 | Canon IMAGECLASS MF-6530 Multifunction...
Babylock Esante stopped. Just makes loud noise but won't move even manually.
You probably have a jam. Start digging under the bobbin area.
If you get it all cleaned up under there... and it still won't move. Time for service by a pro. Could be something horrid like a bent shaft.
Good luck
Nov 03, 2012 | Baby Lock Sewing Machines
My ricoh aficio 1035 shows a paper jam and it is cleared. There is nothing in the pathway. It continues to say there is a paper jam. What can I do? I've taken it apart in the area of the jam and...
There is an actuator type sensor between 1st paper tray and reg sensor.sometimes a piece of paper gets stuck there. Open the door on right dude and shine s torch down u may c a piece there. If not go into service mode and do an smc print and identify sensor with jam and test it in input mode.
Sep 13, 2011 | Ricoh Aficio 1035 Copier
My printer says it has a paper jam, even though the paper jam has been cleared. It won't print. Any ideas?
Hi, Try pulling out the plug for 1 hour and then try again. Pulling the plug may reset the printer.
Good luck.
Jun 27, 2011 | HP DeskJet 3740 InkJet Printer
Minolta Di3510 indicates paper tray jam. I check the tray and open all jam clear areas but find nothing. Close everthing back up indicator goes away and when system starts to print again the machine...
Paper feed clutch is bad. I see this all the time. You can get the machine running by opening slightly the drawer that the machine is trying to feed from. Delete the current job and let the machine use the other drawer until you get it repaired.
The feed clutches in this series are small electromagnetic clutches and they do fail from time to time. Part# 9322-1500-12. Don't pay more than around $60 for the clutch. Here is a pic.
Good Luck and Thank You for using Fixya.
Apr 19, 2010 | Office Equipment & Supplies
Xerox workcentre xd105f
It is entirely possible you have a small piece of paper that got ripped off somehow and it is now blocking the sensor leading the machine to think it has a paper jam.
Follow your jam clearance instructions again and pay close attention and rotate all movable parts in the jam area many times, then reboot the machine multiple times and allow the machine to completely come up before rebooting again, it may be necessary to reboot the machine 3 or 4 times to clear this error, each time following the jam clearance, if this doesn't resolve then you should have an expert take a look at the machine.
Oct 19, 2008 | Xerox WorkCentre M123 Copier
How to clear internal paper jam on CLX-3160FN Samsung Multifunction Printer
Get rid of it. Your problems will only get worse. Mine is going to the landfill.
May 18, 2008 | Samsung CLX 3160fn All-In-One Printer
Fax fixable? error msg
We call the moose method of clearing paper jams, the RCMP method, cuz they only know how to shoot to kill. You did good. Except, there is no such thing as "Bending" anything. The term is "re-form."
Dec 21, 2007 | Brother IntelliFax-2820 Laser Fax
PAPER JAMS
Does the fault clear when you open/close? If it does you probably don't have a jam.
Does the machine begin to try to make copies, then stop-if so it has probably failed to feed off the tray, hence the jam message.If this is the case, pull out the paper tray, check for obstructions, clean feed rollers and try again.Are there "skid marks on the paper(indicating the rolls have turned?) If so rolls could be dirty/worn. If no skid marks, can you determine if the rolls did in fact turn? Go from there
Nov 11, 2007 | Office Equipment & Supplies
Canon DR-7080C Flatbed Scanner Logo
47 people viewed this question
old marine
old marine
