81418784532&item=281418784532">G1900 Kubota, the glow plugs are energized when the keyswitch is moved halfway to the start position. Also the glow plug indicator light is illuminated when in this position. I hold the key in that position until the glow plug light goes out, and then crank the engine. On really cold days I repeat the glow plug cycle several times before cranking.
You can get the unlock code for your Samsung Galaxy Pop (G1900) from Simpleunlocking.com and remove the network lock with the network.You can get free unlock instructions from Mobileunlockguide.com.
LETS SEE BATTERY GOOD! STARTER GOOD? BATTERY CABLES GOOD? CONNECTION FROM THE BATTERY GOOD! CONNECTION FROM THE STARTER TO THE BATTERY GOOD!
WIRE FROM THE STARTER TO THE IGNITION SWITCH GOOD???
IN THIS WIRE THERE IS A FUSEABLE LINK CHECK IT
IF YOU CAN SHORT THE SOLINOID OUT ON THE STARTER AND THE CAR TURNS OVER THE FUSEABLE LINK IS BAD
IF EVERYTHING IS GOOD CHECK TO SEE IF THE MOTOR IS GOOD
You'll have to take your DS apart to make sure that the battery hasn't exploded. Even if the DS says the battery is good that's not always true.
If the battery appears to be good you might want to send in your DS for repair. If the battery seems to be broken you can buy a new one on Ebay or anywhere else on the internet.
The clicking you hear usually indicates a poor battery or battery connection. Have your battery load tested first. You may have a bad cell in it causing it to be weak enough not to be able to supply the amps needed to turn the starter. If you haven't had the battery load tested then it could be bad. My guess is that the battery is bad. Good luck.
