Set clock jenn air oven w241 non digital
I'm trying to set the clock. All manuals show it to be digital but it's not. Can you give me the instructions to set the clock for a radio dial oven. Thanks.
SOURCE: Set Clock
This clock has 2 alarms to set Alarm 1, switch alarm 1 to the "set" position and make sure alarm 2 is pushed to the "off" "radio" or "cathedral" position, press and hold the "alarm" button on top while pressing the "f.fwd" or "rev" button to set the alarm....to set Alarm 2, do the opposite of the set buttons and repeat...to set the time just hold the time button down while pressing "f.fwd" or "rev"...hope that wasn't too confusing.
Posted on Jan 25, 2008
SOURCE: Instruction Manual for Timex Alarm Clock Radio T309T
Here is a website for the manual:
http://www.timexaudio.com/product_manuals.asp
You have to find the product number, located on the bottom. EX: T-309
Posted on Nov 19, 2008
SOURCE: jenn air 88370
I have a similar Jenn Air oven approximate date 1982. It has a catalytic liner (colored a kind of dark charcoal  with paler flecks), so it is a continuous clean oven during normal cooking.  However, it also has the Accel Clean setting on the control knob. This increases the oven temperature to maximum and also runs the convection fan to burn off cooking residues. This allows the catalytic lining work at high efficiency, and burn off stubborn residues that are not removed at normal cooking temperature. The oven may emit smoke through the top door vents as the food residues burn off, so watch that you do not set off your smoke detector. I switch on the cooker hood fan and also put a fan in the kitchen window (blowing air out of the kitchen), to avoid setting off my kitchen smoke detector if I use Accel Clean.
Posted on Feb 28, 2009
SOURCE: operating instructions for timex t311t radio/alarm clock
You can acces a PDF file of the manual at the following site: http://timexaudio.com/media/uploads/product/files/T311IB57574_35.pdf
Posted on Mar 04, 2009
MAD ICE
  • 52 Answers
SOURCE: Jenn-Air double oven door seal W241
it is very simple if you look at the back of the oven there is part number and serial number yet there is the model number and you can search it on the internet i i changed mind simple but i change the window of the oven it had 4 screws and i took it out and in put in withen 20 mins . without the manual how ever if you still think cant do it look a the model of it and see what does it need to be removed you are smart good thinking changing by your self then sending to repaire and yet not alot of people will do what you do..
Posted on Apr 21, 2009
Jenn-Air W241-C wall oven
Unless you can find one in a used oven, I don't know. Jenn air website says they are discontinued and offers no substitute part.
Jul 17, 2014 | Jenn-Air Ovens
Jenn-Air Range displaying Error F1-8
Did not find an error code "F1-8"
I did find these. Seems that about everything that can go wrong with a Jenn Air is related to the clock.
https://www.repairclinic.com/RepairHelp/FaultCodes/26/Range-Stove-Oven
Sep 22, 2017 | Jenn-Air JES8850AAS Electric Kitchen Range
JDR8895AA Jenn-Air Double Oven free standing. Power was shut off during goutside generator maintenance; that was a week ago. No lights / noise on contol panel and 3 sec push on clock button doesn'
Not to be a smart aleck but have you checked the breaker box to see if the breakers are on also the standby breakers? Not sure how your'e wired though.
or reset to factory.... 1. Press and hold upper oven Keep Warm and Upper Cancel pads for 3 second. Should get a single beep. Then clock will show 12:00.
per repair manual Jenn-Air Repair-Manual-JDR8895AAB-JDR8895AAS-JDR8895AAW
Mar 06, 2018 | Jenn-Air JDR8895AA Dual Fuel (Electric and...
We have a Jenn-Air electric slide in oven, model W131. It appears to work fine in all respects except that it doesn't come up to the set temp even though it tells you it has. Set at 350, it notifies...
if you changed the sensor most likely it will be the clock assy.it's not just a clock it also has a computer board built into it.you're missing a few letters off of the model number so when you call your parts store give them the full model number so they will sell you the right clock assy. i believe your board is around 150 dollars.if the elements are good and a new sensor all that's left is the board or clock assy. good luck with your stove.
May 23, 2011 | Jenn-Air SVE47100 Slide-In Electric...
Apr 21, 2009 | Jenn-Air JJW8230D Electric Double Oven
Jenn air oven
More then likely your electronic clock control board is going bad. After turning the power off, you can also try cleaning the connectors on the clock board and make sure the connectors are tight.
Mar 23, 2009 | Jenn-Air JJW8230D Electric Double Oven
Oven digital lighted display is dim
mY 27" WALL jENN air blows cold air out the vents when on cleaning cycle. The red buttons aren't lighted. The door locks, otherwise it bakes fine. I wonder if it is really cleaning?
Feb 16, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn Air JJW8530C stopped working
can you hear audible tones form the machine when trying to set?? and just hte display has dimmed( amore normal complaint). all functions are working just the clock/display has dimmed to non readable state. if thats the issue youll need to replace the display part number 71003424 retails for about $165
Nov 04, 2008 | Jenn-Air JJW8530C Expressions Collection...
WW30430
lower oven gives Fr code when turned on
Jun 23, 2008 | Jenn-Air JJW8527C Expressions Collection...
Jenn Air W241 bake element not working
Most ovens are relatively simple; an element and a switch/thermostat. Usually it's one or the other that goes bad. If you have a good Volt/Ohm meter you can test the parts saving you un-needed expense.
A Volt/Ohm meter will pay for itself in parts and safety.
A service manual with circuit diagram will go a long way in saving you time and money. Most service manuals are available online for free as a PDF file.
Happy baking. Photo is a pizza baked at 300 o F with Pizzacraft brand pizzeria flour purchased online.
Dec 15, 2017 | Ovens
 Grubhead
Grubhead
