Question about Acer Aspire Computers & Internet
How to reset thermal over load relay
Computer turns on then turns its self right back off after the acer screen comes on.i took out the battery and drained the power then hooked the ac power supply back to the pc without the battery in the unit but still the same results. turns on for a few seconds and right after the acer screen pops up it shuts back off.
    Master:
  • 663 Answers
Are there any error messages on the screen?
It could be a software problem or overheating. To isolate the problem, then try the following:
1. Restart the computer and tap F8 until you see the options to boot to safe mode.
2. Highlight safe mode using the arrow keys and hit enter.
If it goes in without any problem, then do a system restore.
Start > Programs > Accessories > System Tools > System Restore
Select a restore point. Make sure that it's a date when you had no problem yet.
If the computer does not go into safe mode, then it's a sure overheating issue. It just need some cleaning. Bring it to a technician to make sure that there are no defects with its fans.
If you have any questions, please drop me a line.
David
Support Engineer @ RadarSync.com
Posted on May 07, 2013
Testimonial: "The fan starts up and the sytem makes it to the recovery manager screen then turns itself back off."
  • jonathan abney May 07, 2013
    the fan starts up and the system makes to the system manager screen then shuts off.
5 Suggested Answers
Bogdan
  • 198 Answers
SOURCE: My PC won't run with ac /dc power!
Hello. There is a hardware failure with the laptop not the AC charger. AC chargers have some range of protections of their own. If the power requirements of the laptop are bigger then what the charger can handle, the charger will turn off. Also other parameters can bring the charger offline. In your case, you have a problem with a small chip, the battery charge controller unit, witch regulates the amount of current required to propperly charge the battery. When this thing fails, the charging requirements for the battery are reported rong and the AC charger is forced to give more power then necesary. This results in disconnection of the AC charger ( an internal fail safe of the AC charger) and the laptop to swich back to battery power. When the laptop is turned off, it can charge the battery because the power requirements are low, having all processor, main board, hard disk etc turned off. Therefore the AC charger can handle the load. However you will need to have it checked by a service center as it is a hardware fault. Both AC charger and laptop needs that check. The charge controll circuit needs to be replaced probably. It will be a somewhat expensive repair. Don't buy any other battery untill you have the laptop checked. For more aditional info please post back. PS. Sorry for my bad english, I am from Romania, it is pretty hard for me to explain tehnical stuff in english.
Posted on Feb 16, 2007
SOURCE: Toshiba Satellite M65-S909 laptop will not start
I had the same thing happen when I was fiddling with the 9092 monitor refresh rate. The video circuit had a few episodes of video switching and the system shut down never to wake again. I figured it was connected to this circuit but I couldn't fix it. I bought a new one but I haven't tried to recreate the problem:-|
Posted on Aug 30, 2008
eagle338
  • 4889 Answers
SOURCE: Acer Aspire 7720 shut down, no power light,
The laptop's AC power jack is probably damaged. All you have to do is put the fork aside :D, unsolder the old power jack and solder the new one in. If you are not good at soldering you can get it done by a qualified professional. Its a 5 minute Job and a pretty inexpensive repair.
Regards,
Sai.
Posted on Oct 24, 2009
Jack_Dawson
  • 287 Answers
SOURCE: Acer Asipre 5315 laptop wont charge or turn on via
Check ur Laptop Charger (replace it)!
tell me if it helps...! :)
Posted on Jan 02, 2010
I recently took my good battery out of my 04 gsxr 1000 and tried crank another bike with it.. The bike wouldn't crank.. So I put it back in my gsxr and it would turn over but no fire then after turning it...
The electrical problem of the other bike could've very easily fried your battery, too. It could have enough to turn over but that's it. Take your battery out, take it to a car parts store, have them load test it. It could just need a reconditioning and charged up.
May 05, 2017 | Cars & Trucks
How do I reset or replace the thermostat in a whirlpool accubake oven
you don't have a thermostat that you turn,you have a computer board or clock assy. unfortunately you can't get parts for this oven because it's to old and they stopped making parts for it.when you use the self clean the oven gets up to 1000 degrees and this can damage the electronics in the unit and it sounds like it took out the computer board,there's also a thermal fuse inside that could have popped but common problems with self cleaning is the board gets damaged.you might be able to have a tech come in remove the board if that's the problem and he'll make a diagram for the board,then you send the board out to have it rebuilt,you can google this to find a company that does this,when it comes back rebuilt the tech will rewire it and this should take care of your problem but like i say you can't get parts for this anymore so do you want to sink 3 to 400 dollars into it.also when ever a holiday is coming up don't ever self clean your oven,people do this right before the holidays and then something like this happens and the parts have to be ordered and it could take up to 2 weeks or more to have it repaired,i would never use self clean do it by hand and with easy off.hope this helps you out and good luck with your oven
Oct 08, 2017 | Whirlpool RBS275PD Electric Single Oven
I'm locked or freeze on one page no matter what if turn it off or reset it it goes right back to the same page. Can't do anything Even took battery out for a few mins and still back to same page
shut off and when you turn it back on toggle the f8 button when it comes up click on go to last good configureation try that if that dont work you may have to restore the system
Aug 14, 2013 | Acer Aspire 5750Z-4885 : 2.2GHz Pentium...
Hi is any one over there? I have Acer Aspire 4736 with XP pro OS, but I forgot my bios password. Can you help
in my experience, the best way to reset a bios password is to open it up, pull out the cmos battery for 3 min, and boot it up. it should say "password disabled". turn it off, put the cmos batt. back in, and boot. it should work now.
Jan 13, 2011 | Computers & Internet
0xd000001e and subsequent black screen
The easiest way is to hit F10 right after the Acer splash screen. This will take you into recovery mode on the laptop. Then just do the Reset to Factory Default. This will put everything back to the way it was when you purchase the laptop. It does this from the recovery partition.
Jun 02, 2009 | Acer Aspire 3680 PC Notebook
Black screen before log on computer wont load
take the battery out and put it in again
Jun 02, 2009 | Acer Aspire 5315 Notebook
Acer monitor AL1916W
start up windows in safe mode and see if you still get the problem. did you use the same vga cable???
Aug 26, 2008 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
