Question about Garden
Toro wheel horse 15-44hxl wont start
Cannot get the mower to start, we cleaned the carb and replaced the spark plug. Tried starting with starter fluid but did not fire. When you try to start the mower the engine cycles 1 time then it takes a minute before you can get it to do it again. There is a tight spot when you spin the motor and thats where it normally stops. Also battery is new.
    Novelist:
    Scholar:
  • 80 Answers
What motor do you have. Briggs & Stratton motors are notorious for the valves getting out of adjustment. When this happens they frequently develop a tight spot that is very hard for the small batteries and starters to push past. This often results in this sort of condition. Sometimes you can help it by jumping it off another battery to boost the cranking power, however it's best to get the valves into proper adjustment. If you have good connections and have ensure that your starter is getting enough power, make sure you have spark by pulling your plug (the motor should crank well even if valves are out for a spark test, it shouldn't hurt anything doing it). If you have spark and all else is well, check the valves. If they are right, you may need to re-clean the carb if you still can't get it to fire, focus on making sure the idle jet is clean. Also make sure it hasn't fallen out. These jets are tiny and can EASILY fall out of the carb and disappear unnoticed when you remove the fuel bowl to clean it. (speaking from painful, embarrassing experience)
Posted on Nov 15, 2013
  • 3 Answers
SOURCE: engine drags while trying to start
It may be a problem with the camshaft-compression release. Some of the Briggs & Stratton models had a weak spring on the compression release whis is parts of the camshaft. you may also want tocheck that all wires are clean and tight. Also if it's a over head valve model check the valve clearance.
Posted on Jan 26, 2009
  • 86 Answers
SOURCE: I have a Toro LX425 riding mower with a new
Your most likely talking new starter,never jump start a lawnmower with car,to much amps.fries your starter resulting in like low battery condition,If interested can give you a place you can get a resonable price ,Most places will shock you over 120 dollers.
Posted on May 12, 2009
  • 153 Answers
SOURCE: Ride on will not start. B&S motor.
Logic would dictate that the starter motor is burning out, drawing far too much current, and that the current overheated the solenoid and toasted it. Now the starter is almost a short circuit and while it spins it has no power. A spendy part to be sure. Perhaps you can find a used one from your friendly neighborhood repair guy.
A compression release is found on old diesel's, but not on gas engines.
Starters can fail from cranking on them for extended periods. They are designed to handle short periods of use, maybe 20 seconds on followed by several minutes (like 15) off. If you have had starting problems and kept cranking to get it going that would explain the fried starter.
Posted on May 14, 2009
smartr10U
  • 1305 Answers
SOURCE: Craftsman mower with 20hp B&S Intek won't start/run
That throttle cable issue sounds like it may be the culprit. the cable housing (the outer casing for the wire throttle cable) may not be anchored correctly. Which may be allowing you to move the throttle without any change at the butterfly control on the carb. make sure the cable housing is anchored at both ends.. by the throttle control and at the carb area.. That may be your problem... hope it is that simple...
K
Posted on Jul 23, 2009
  • 1129 Answers
SOURCE: My riding lawn mower won't start. New battery
Spray starting fluid into the air box if it starts and dies out there is a fuel delivery problem if the mower has a petcock fuel shut of valve disconnect the fuel line after the petcock and hold a container under the hose turn on the valve to ensure gas flow to carb if there is no petcock valve I would still check the line to carb make sure gas flows through the hose to carb.
Toro Mower wont start
take sand paper and shine up the magnetio with is on the flywheel shine them up and put you hood back on it it will start
May 12, 2013 | Toro Garden
Oil in the gas tank
Not a big deal. Im assuming this is a 4-stroke push mower and not a leaf blower.
Remove the air box cover, air filter, and air box back plate. Careful there is a gasket on the back of the backplate that if damaged the primer bulb wont work, part # 272653. Remove the fuel line from the carb and drain the tank. Using a 1/2 inch wrench remove the bowl nut from the float bowl on the carb, hold the bowl to the carb as to not break the gasket seal, drain the bowl and replace the bowl nut. If you tried to run the unit and oil is in the cylinder remove the spark plug ( clean the spark plug) and spray some carb cleaner in the hole and pull the starter rope several times to purge the cylinder. Reinstall the spark plug, reattatch the fuel line, install the air box back plate ( leave the air filter and cover off for now), add fresh fuel.
Take unit outside and start, you may need to give it a shot of carb cleaner in the throat of the carb to help it start. It may smoke, it may blow oil out the muffler. Let it run until it quits smoking ( usually around 5 minutes) . Shut it off and complete assembly. It should be fine.
Oct 05, 2012 | Toro Lawn Mower With Toro Power Tools
Toro ride on wont start
Battery required? Charge battery or replace. Replace air filter and spark plug. Dump out old oil and replace with 30w oil. Electric start may have a fuse blown. Dump out old gas fill with new with Stabile always added to gas. Try spraying starter spray in carb at air cleaner with filter removed. All mowers have a low oil sensor to prevent starting on low oil. Remove bowl from carb, should be full of gas. Pinch off fuel line with pliers or turn fuel valve off. Check float should be hanging down allowing fuel flow. Float up stops fuel flow.
Sep 19, 2012 | Toro Power Lawn Mower
Toro Electric Start Problem
Remove spark plug and observe condition. Fouled with oil, bad motor. With plug removed pull rope several times to blow out cylinder. Spray WD40 in spark plug hole, pull rope several times see if oil blows out. Spray a lot of starter fluid in spark plug hole, replace plug. Spray starter fluid in air cleaner area of carb, try to start. Replace spark plug, try to start. Ensure oil is full, all mowers have a low oil sensor now. 30w oil. Always use Stabile in gas.
Jul 04, 2012 | Toro Garden
Toro 6.5 tecumseh won't start
replace your spark plug. it takes a Champion J19LM. If you left fuel in your tank over the winter then drain your tank and your float bowl. Add clean fresh fuel and it should go if not you need to clean your carb
May 17, 2012 | Toro Power Lawn Mower
My toro 17 horse wont start the battery is fully charged
If it is getting fuel ( Crank and pull the plug) the plug will be wet with gas. That means no spark. Check all kill wires going to coil. Some switches stick. If all else fails check and clean the fly wheel (CLEAN ALL RUST OFF) Rust will conduct to ground and you will not start.
Mike
Jul 11, 2009 | Garden
Toro Lawn mower running rough/usually won't start/backfires
You need to check a few things. The spark first, you need to check if it is running correctly, does it have spark, by doing this: take out the spark, put it against a metal surface and pull the pull start if it spark, your good if not you need a new spark plug. Clean out your airfiilter it migth help too. Buy some carb and choke cleaner squirt it up theough the airfilter hole, and start the engine, this will clen the carb. yOU MIGHT NEED TO TAKE OUT THE CARB AND CLENA I OUT THROUGHOULY!!! Try that and it whould work after all these steps!
IN your problem it might also be for some reasons like the crankshaft is bent, that damages the motor internally and cannot be fixed, hppens on older mowers. and is caused by when you run over twigs and branches andything hard!
Jul 04, 2009 | Toro Lawn Mower With Toro Power Tools
Toro mower won't start. No sound when I turn key.
definately connection some where i would use a volt meter and make sure where power is and make sure it is getting too where you need it, if its getting too the soliniod or not then too the starter.
May 08, 2009 | Toro Lawn Mower With Toro Power Tools
Mower will not start
Hi
Take the spark plug out and pour a little bit of oil in the cylinder and crank it over without the spark plug in. Make sure ground wire is clean on both ends.
Apr 13, 2009 | Garden
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
