Question about KitchenAid KBFA20ER Bottom Freezer French Door Refrigerator
Defrost timer location kitchenaid french. - KitchenAid KBFA20ER Bottom Freezer French Door Refrigerator
2 Suggested Answers
VtToolMan
  • 704 Answers
SOURCE: How to set the defrost timer on a KitchenAid Side-by-side frig?
It doesn't and shouldn't matter as all fridges with a mechanical defrost timer will run through a complete refridgeration and defrost cycle according to the manufacturer's factory design.
It doesn't have to correlate to your local time, since all defrost cycles for self-defrosting units operate based on the manufacturer's specs for how often the unit needs to go into a defrost cycle to prevent ice build up in the freezer.
Your fridge will adjust properly, once it gets cold enough and begins the specified operation and pre-determined cooling and defrost cycling.
Posted on Jul 28, 2009
Defrost timer location on a kenmore refridgerator model 10645492400
I don't think your model number is correct in most cases your defrost timer or adaptive defrost board is located wherever your temperature controls are.
Feb 28, 2014 | KitchenAid Refrigerators
I have a Kitchenaid refrigerator model kbra22klss01.
Try turning the=> 8170840 Defrost Timer clockwise slowly. It may be stuck in the defrost lobe and the timer is so weak it cannot turn to get out of defrost,. Sea Breeze
Dec 01, 2013 | Jenn-Air JFC2089HE French Door...
I have a kitchenaid side by side refrigerator model #KSSC42MFS05 and the freezer isn't getting cold enough to freeze ice cream and the ice maker isn't working.
Look at the rear wall of the freezer for a layer of frost building on the outside of that panel. If yes the refrigerator may be missing defrost. That would explain why the feezer temperatures are warming. If the ice maker is above 5 degrees F it will not be able to make ice. Things to check are the=> 2162044 Defrost Timer
The=> 2000631 Defrost Heater
and the=> 4387499 Defrost Thermostat
I would like you to locate the defrost timer and turn the center with a flathead screwdriver slowly clockwise until compressor and fans turn off. Leave like this up to 30 minutes. This will cause the defrost to begin. If timer does not restart the compressor an fans after 30 minutes simply turn the timer again slowly clockwise until the compressor and fans restart. If the timer need to be turned like this then this would indicate that the defrost timer is defective and will need replaced. Let me know if you have questions Thanks Sea Breeze
Sep 25, 2012 | KitchenAid Refrigerators
My fridge isnt working but the freezer is still on and running fine. Before I call a repair man any suggestions??
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 07, 2010 | KitchenAid KBFA25ER Bottom Freezer French...
FRIDGE AND FREEZER QUIT COOLING
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid KBRS22KG black bottom freezer not working
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
Aug 13, 2009 | KitchenAid KBRS22KG
Refrigerator side not cold
if you have frost build up on rear wall of freezer section then your unit is not going through defrost. its either defrost heater, defrost thermostat (which are both located on evaporator) or defrost timer
Jun 24, 2009 | KitchenAid Superba 21.6 cu. ft. Top...
Cooling sometimes, freezer leaking water when it stops freezing
It is probably the defrost thermostat located on upper condenser coil to the left of the fan in the freezer compartment. If not, it could be the defrost timer located near the thermostat in the refrigerator under the plastic dome where the light is. If the defost thermostat or defrost timer is not cycling the defroster heater element on and off correctly... an ice dam forms clogging the drain tube which freezes and blocks water (from the the defroster) to draining down and into the evaporator pan located on top of the compressor in the rear of the unit near the floor.
Mar 31, 2009 | KitchenAid Refrigerators
KitchenAid KBFA20ER Bottom Freezer French Door Refrigerator Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
