Question about Samsung SyncMaster 245BW Monitor
Samsung Syncmaster 245BW sync problem
This unit will NOT handle 1920 X 1080p correctly...it pushes the res to 1920 X 1200p whcih is a problem for us(strnage things on the bottom of the screen) Thanks
  • Anonymous Apr 27, 2008
    Can not stop the flickering (see the rtrace lines) Vista 32 bit using NVIDIA
If you are plugged into a NVIDIA graphics card, use the NVIDIA control panel scaling option to "do not scale" then set the resolution to 1920x1080. This monitor is a 16:10 aspect ratio instead of 16:9 like HD TV's, so it is necessary to turn of scaling from the software and thus give black bars.
Posted on Jun 19, 2008
SOURCE:
Samsung syncmaster 245bw powers on but there is no display.
check your rgb chord found at the back of your monitor, i think it is color blue chord that connects through cpu and monitor..push it tight and it will display again..
i hope it can help you
Jul 25, 2011 | Samsung SyncMaster 245BW Monitor
Samsung Syncmaster 245BW displays no image. Unit receives power and the blue LED on the power button is lit but the screen is not illuminated. I can't tell if the pixels are changing at all, but there...
laqbot7000, If you have opened unit, what is the brand name of capacitors (electrolytic's) printed on them. CapXon, Elite, Jun-Fu, are some you don't want to find on the smps board. Are any of the rubber seals pushed out of the bottoms of any capacitors? Is fuse still ok? Did you use a magnifying glass or low power "inspection" microscope(5x - 20x) to possibly find any "thinner than hair" fractured solder connections to component leads soldered to the copper foil circuit traces?? Also "visual" the black bodies of all solid state (transistors, bipolar, mosfet) devices for "burns" and "distortion" from overheating. 12fixlouie
Sep 21, 2010 | Samsung SyncMaster 245BW Monitor
Samsung syncmaster 245bw menu buttons don't work
It is a hardware problem. you can repaired it from service center.
Nov 13, 2009 | Samsung SyncMaster 245BW Monitor
My samsung syncmaster 2233sw shows multiple displayes when i take it to its max res. i use win xp sp2 and have nvidia 8600gt gfx card. the monitor works well on lower res but only shows this problem when i...
Typically this is a driver issue on the host (PC) side. DVI or VGA connection? Update the video driver. Some video drivers (especially older laptops) can't correctly send that resolution.
Jun 04, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Samsung 245B
Call Samsung. The unit sounds faulty.
Dec 14, 2007 | Samsung SyncMaster 245BW Monitor
Syncmaster 245bw monitor resolution screen and resolution issues
These two devices are not compatible, you may need to read the information on this LCD MONITOR to see if the resolutions are compatible, this often times happen when monitors are purchased!
Nov 25, 2007 | Samsung SyncMaster 245BW Monitor
Samsung Syncmaster 245BW, can't get it up and running !
Most of the time when this happens it is due to a bad monitor, if you have another pc try to hook this monitor up to that one to see if it actually works, these monitors sometimes get damaged during shipment!
Jul 25, 2007 | Samsung SyncMaster 245BW Monitor
Samsung SyncMaster 245BW Monitor Logo
310 people viewed this question
Top Samsung Computers & Internet Experts
asber
Stormi  Paulk
Stormi Paulk
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
