Question about Dishwashers
Kenmore Dishwasher model 665.13293k112
I cannot get the machine to start on any cycle.
markevans
  • 148 Answers
SOURCE: Kenmore dishwasher locks. after cycle, can't open door
bad solenoid or controller
Posted on Dec 21, 2007
SOURCE: dishwasher kenmore elite model 8530899
yes
u go by quick wash its take 28 minutes
Posted on Apr 18, 2008
IFIXALL
  • 868 Answers
SOURCE: Kenmore dishwasher skips the wash
Replace the electronic control board.Its located under the panel you select cycles from.
Posted on May 21, 2008
SOURCE: Washing light flashes a short
Problem was the live side contact on the door switch, with the door shut the neutral side (white wires) were shorted but the live side (black wires) were open. I removed the complete module and discovered that the actual contacts were removable, lift a single catch and slide out. Contacts were cleaned with abrasive and now all is OK. However, this is a short term fix only, already damaged contacts will continue to degrade and give trouble. Does anybody know if the contacts can be purchased or do you have to buy the complete door latch module?
Tim
Posted on Dec 07, 2008
  • 572 Answers
SOURCE: kenmore ultraclean \dishwasher\model 655.16033402
if it blinks 7 times. there is too cold coming in. if not ur heater is faulty. theres a heater kit for this problem that comes with a board.
Posted on Feb 06, 2010
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
We just installed a new kenmore dishwasher yesterday. Model 13242 It has been running for almost2 hours and is still on the washing cycle--no water in it however--is this normal? I'm in a bit of a panic as...
THAT IS NOT NORMAL!!!!!!! A normal wash and dry cycle will take approx. 2 hours in length including drying cycle.
You should see that water has been present in the machine within the first 2 minutes of the start of the wash cycle, you should also be able to hear the water entering the wash tub.
The fill valve or water supply seems to be the issue, if the water doesn't enter the tub then the controller won't proceed witht the wash cycle. Double check your water supply tube / hose to make sure there is water present at the connection to the dishwasher.
GOOD LUCK !
Aug 08, 2010 | Kenmore Dishwashers
Two Green Lights Flash Mid Cycle.
It's possible that there's a fault in the drying heater coil, but I couldn't tell you for sure without looking up your machine. If you could locate the model number tag on your machine and write down the exact model number and serial number, then I could likely give you a more informative answer. ;)
Aug 08, 2007 | Kenmore 24 in. 15252 / 15254 / 15259...
Start flashes and will not begin wash cycle
My dishwasher Model is 665 15891790 and the serie #FG3907905. After programing my dishwasher and pressing the start button, it fills with water, but when it is due to start the sensing light comes on. I have notice that the ring under the watering arm on the bottom of the machine seams to be cracked. Could that be the problem for the machine not starting its' cycle. Thank you.
Jul 01, 2006 | Kenmore 24 in. 16293 Built-in Dishwasher
Dishwashers Logo
307 people viewed this question
Top Dishwashers Experts
