Question about Cook's Essentials CEMB10TC
Broken latch on coffee grind lid
The latch that holds the lid down over the coffee grounds broke. Where do I get a replacement.
  • 3 more comments
  • Anonymous Jan 13, 2008
    I tested to see if the coffee filter was in correctly; however my lid is no longer staying down. I have to hold the lid down to make the grinder and cofee brew.
    Because of the steam, it is a good idea to grab a hot pad and a book to read.
  • Dogtip2 Jan 13, 2008
    I have the same problem. I checked if the coffee filter was in correctly.
    The only way I can make the coffee grinder and coffee brew is to hold the lid down. Because of the steam, I use a hot pad and to keep from being bored, I read.
  • ezpc Feb 22, 2008
    i used a weight for a while then i used velcro!
  • Mike Daughtrey
    Mike Daughtrey Apr 16, 2008
    Well I tape mine down, I sure would love to find a repacement top. I also would like to repace the Grinder/Basket. I thought this unit was manufactured by Melina but they say they have no association with the product, I am at a loss~~~~~
  • kim3kim3 Nov 26, 2008
    I lost the cover of the pot during a move could I get a replacement
I have drilled a small hole where the latch was and put a screw in. The screw serves as a latch and has worked fine for years.
Posted on Apr 25, 2009
I have the same problem but you can buy tha replacement part by calling 1-800-233-9054 and the part number you need for the broken lid is:30636B. Hope this helps everyone out..good luck
Posted on Sep 18, 2008
I used a large rubberband too!
Posted on Apr 19, 2008
I use 2 small window decor suction cups with elastic bands. It really does the trick.
Where can I find a replacement water reservoir lid?
Look on eBay.... then AMAZON...
or construct a search line for the internet for spares/parts...
My QUICK eBay search got this for $14 (USD)..
Cuisinart DGB 600CL Thermal Carafe Lid Black New eBay
(looks like what you said)...
Happy hunting
Carnac the Magnificent
Dec 01, 2017 | Cuisinart DGB-600BC 10-Cup Coffee Maker
How do I clean my burr mill (Models BMX3, BMX4, BMX5 and BMX6)?
Clean your burr mill before using it for the first time. Then, to ensure optimal mill function and durability, clean it regularly following these simple steps.
  1. Always unplug your burr mill after use and before cleaning.
  2. Open the hopper lid. Empty any whole beans from the hopper. Remove the top burr mill by rotating it clockwise. For better results hold the grind setting button while rotating the burr mill clockwise. This will allow you to clean the grinding wheel and the grinding compartment.
  3. Clean the interior recesses with a soft brush. Note: Never use water or liquid for cleaning the lower grinding section of this appliance. BRUSH NOT INCLUDED.
  4. Wipe the whole bean hopper, its lid and the mill exterior with a damp cloth.
  5. The ground coffee chamber and lid can be washed in mild detergent and water. They both are top rack dishwasher safe. Do not immerse the mill or the whole bean hopper in water or any other liquid or place in dishwasher. Use only non-abrasive cleaners to remove stains.
  6. After completely drying the whole bean hopper and top burr mill, replace the burr mill in position by aligning snaps with receptacle and rotating counterclockwise to lock it in position. For better results, hold the grind setting button while rotating the burr mill counterclockwise. Once the burr mill is in position, pull gently to check it is properly locked in position. If the burr mill comes out, repeat this step again.
  7. Replace the ground coffee chamber and lid, making sure both snap securely into place.
  8. Fill the hopper with whole beans.
Sep 02, 2011 | Bunn NHB Coffee Maker
How do I clean my burr mill (Models BM1 and BM3)?
  1. Turn the whole bean chamber to the right until it can be lifted off the base. This will allow you to clean the grinding wheel. NOTE: Never use water or liquid for cleaning the lower grinding section of this appliance.
  2. Clean interior recesses with a soft brush (not provided).
  3. Wash the whole bean chamber and lid and the ground coffee chamber and lid in mild detergent and water. These items are only dishwasher safe on the top rack of your dishwasher. Wipe exterior with a damp cloth. Do not immerse mill in water or any other liquid or place in dishwasher. Use only non-abrasive cleaners to remove stains.
  4. After completely drying, replace whole bean chamber. Important: when replacing whole bean chamber, screw on completely before setting grinding rate. Turn chamber clockwise (as viewed from top), until it will not turn. Fill with whole coffee beans for grinding and replace lid.
  5. Replace ground coffee chamber and lid, making sure it snaps securely into place.
Hello. I have a saeco vienna superautomatic
This happens due to condensation caused by steam developed at the end of the grinding cycle. Make sure that the grinding chamber is completely cleaned and dried before using the grinder.
Aug 02, 2009 | Saeco Vienna De Luxe Espresso Machine
Don't know how to use Mr.Coffee IDS57 coffee grinder
Typically you load in the beans, replace the cover and then either press down on the entire cover or the black knob on the front of the cover. I would hold the lid down with your other hand just to be safe. Grind for about 4-6 seconds depending on how strong you like your coffee (the longer you grind the finer the coffee will be...this means STRONGER)
Jun 09, 2009 | Mr. Coffee IDS57 / IDS55 Electric Blades...
Broken coffee mill/container on Cook's Essentials CEMB10TC
This is the same part as on the Melitta Mill and Brew, notorious for the same problem. They are no longer being made; you can't get the replacement part in any of the "official" channels. Somebody somewhere may have old stock. You always had to replace the entire lid, not just the latch. Most people figured out to use a mall weight to sit on top of the lid so it will work, or just hold it down with your hand until it finishes grinding.  Not a great solution, I know. Sorry. I'm in the same boat!
Dec 24, 2008 | Cook's Essentials CEMB10TC
Filter basket opening during brewing
Push the permanent filter's basket handle all the way down and then reclose the filter basket drawer lid. There is a pretty flimsy piece of plastic holding it in, though - may require replacement.
Sep 06, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
How to disassemble it to fix the start button, which fell into the machine
Just adding to dhelkamp's instructions (which helped me immensely!).
The front quantity knob kan be pulled right out - it's held in place by friction only.
The side knob has 3 latches holding it in place. Releasing 2 is sufficient. Use 2 small flat screwdrivers.
As for the assembly, there are 4 latches in the inner assembly holding it in place. The location of these latches can be seen by looking at the edge of the outer shell. The front latches are just behind the holes for the rubber feet, and the rear latches are just in front of the rear holes. Use a flat screwdriver to release one of the front latches, while pressing down on the outer shell - it should give way 1-2 mm. Repeat on each of the other 3 latches, whilst keeping pressure on the outer shell. The cover should easily slide off the grinder assembly. Beware of getting pinched!
Jul 26, 2008 | Krups GVX2-12 Electric Burr Grinder
I have a cuisinart automatic grind and brew thermal coffee machine. Soemtimes, during brewing, the container holding the grinds pops open and the still brewing coffee pours everywhere.
On mine the door that holds the ground coffee in place at times doesn't latch properly either and then the it will pop loose. I have to close it fairly hard in order to get it to latch and I test the latch by pushing on the door to see if comes open. When properly latched it will only open via the little button on the side, not by jiggling the door.
Jul 07, 2008 | Cuisinart DGB-600 Coffee Maker
Revere Ware old fashioned coffee pot
1) Boil the water you’ll need in another pot.
2) Put 1 tablespoon of ground coffee (drip grind, not percolator grind) in the reduced diameter, perforated bottom of the brewing chamber.
3) Put the grind/water separator (the perforated, flat handled plate with cup markings on the handle) in the Brewing Chamber, over the coffee grounds.
3) Put the Brewing Chamber on top of the Holding Chamber.
4) Pour the appropriate number of cups boiling water into the brewing chamber; put the lid with the black knob on the brewing chamber.
5) Let the water drain through the coffee grinds (5-10 minutes).
6) Remove Brewing Chamber, clean out the coffee grounds, and replace the lid on the holding chamber.
7) Enjoy your coffee! Keep it warm on the stove at LOW heat setting.
for the most information on the Revere cookware lines, go to: http://mysite.verizon.net/vzeoywo4/theshineshop2/id1.html
Charlie
Jun 16, 2008 | Coffee Makers & Espresso Machines
Cook's Essentials CEMB10TC Logo
277 people viewed this question
Top Cook's Essentials Coffee Makers & Espresso Machines Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Robert Plante
Are you a Cook's Essentials Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
