Question about Meade CaptureView VGA Digital Binoculars - CVB1003
My capture view doesn't turn on.
I installed new batteries ,it doesn't work at all.
Camcorder sony hdr-ax2000e turns itself off
hello, does it show any error code before is shuting down?
May 28, 2013 | Sony HDR Video Cameras
Webcam doesn't work the way I want it can't take photos
A webcam supplements communication with family and friends. It's often used for video chatting. But you could use your webcam to take pictures, as well.
Make sure your webcam is connected to the USB port of your computer, installed appropriately, and the computer is on and ready. Navigate to the "Start" menu and type "webcam" (without quotes) in the Search field. If you've previously installed webcam software, the program should appear in the search results. Double-click the selection to launch the webcam application. From the webcam dialog, select the "Quick Capture" icon (the example is for Logitech software, but other applications have similar functions with different Position the camera and person or object that you want to photo capture. Select the desired resolution from the drop-down menu. Click "Take Photo" to take a photograph. Browse to the picture destination to view your photo. Now that your photo is stored on your computer, you can email or print it.
Apr 08, 2013 | Acer TravelMate Computers & Internet
Turn on but remote doesn't work
I would try new batteries first. If that doesn't help then replace the remote with a universal unit that you can program to work with your TV.
Nov 13, 2012 | LG 42LC2D 42 in. LCD HDTV
Sound capturing problem
Webcam doesn't record sound,try a microphone,and make sure that sound recording software is running when you record sound
Aug 27, 2012 | Gateway Computers & Internet
N73 nokia, i have problem in take of the image capturing , in the image capturing mode doesn't key accept for image capture but it has work for video capturing. so plz help me what i do?
Generally the image capturing button should press 1-3 secs to get a picture.If it doesn't works there might be some hardware problem.But first try to Restore the phone by typing *#7780# and capture.If the problem still persist contact mobile repairing shop. The camera switch may damage .Or at least clean the pcb if you can remove the cover ..Thanks for visiting fixya
Mar 18, 2012 | Nokia N73 Cellular Phone
I have a life view and my computer is windows 7 and when i install my old life view it doesn't work i think my life view supports win me or 2000
sounds like a driver issue
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver hope this helps
May 20, 2011 | LifeView FlyTV MCE TV Tuner/Video...
Hi, i 've Olympus CAMEDIA 470 Zoom digital camera. i want to use it as webcam. let me know if it can be used and how? will it really damage zoom or not/
If your has an A/V-out port and a cable that lets you output to a TV, you should be fine. If your computer already has a video input-many do, particularly ones marketed as media PCs-then you're all set: You can just plug the camera into your computer and turn on the camera.
If your computer doesn't have a video input, you can buy an inexpensive USB capture device for $5 to $10 on eBay, or a brand new EasyCap Video Capture Adapter for $15. The same device can let you watch TV on your computer, too, since the encoding hardware is the same-look for a TV-tuner-plus-video-capture USB adapter for $30 to $50 instead. You'll need to install the driver that comes with the device, but not the video-editing software. Simply run your favorite IM client; with the capture device's driver installed; the IM client should find your camera and let you use it as your webcam for video conferences.
I hooked up my Canon PowerShot to a desktop PC using a $15 video-capture dongle and simply ran iChat, selecting the video device as my input. I was videoconferencing within minutes.
With some cameras the audio will be sent along with the video. If that's not the case with yours, set your computer's audio input to its microphone.
May 07, 2011 | Olympus Camedia D-590 / C-470 Digital...
Meade CaptureView VGA Digital Binoculars - CVB1003 Logo
35 people viewed this question
Top Meade Optics Experts
Experi
Level 1 Expert
Joe Wright
Level 1 Expert
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Meade Optic Expert? Answer questions, earn points and help others
