Question about Kenmore 41389 Electric Double Oven
GE Built-In Oven model JKP62G
Upper heating element in oven burned out. Can this element be replaced?
  • 4 Answers
SOURCE: message panel keeps flashing F10 error
Code F-10 indicates a temperature runaway. There are two possible problems. 1) The oven temp sensor has failed. This can be checked using a standard multimeter. The sensor is located behind the rear access panel of your oven. The sensor should read about 1100 ohms at room temperature. 2) The oven control board needs to be replaced. There are no FRU's (field replaceable units) on the control board. Check the sensor first. Even a new control board is cheaper than a new oven.
Deepwater
Posted on Apr 30, 2008
  • 10865 Answers
SOURCE: oven will not heat.
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
It bakes poorly Here are two instances of when food "bakes poorly:"
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
    You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
    If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Posted on Jun 02, 2009
  • 8 Answers
SOURCE: Kenmore oven - will not heat on bake / will heat on broil
its your temp sensor. replace it and it should fix ur prob
F2=overheat
is your bottom element connected?
Posted on Jun 24, 2009
  • 127 Answers
SOURCE: kenmore electric range - oven temp low and takes forever to heat
if lower element tests open with continuity meter then it for sure is bad. i would also check the wire ends that connect to the element and/or the control board, they could have loosened allowing a bad connection and low voltage to elementor burnt off.. most ovens do not use the broil element at all during the bake cycle, only during the broil cycle.. some however do utilize the broil element during baking, but at a lower wattage or something..
best of luck,
ttfn
Posted on Oct 25, 2009
dmftrucker
  • 1922 Answers
SOURCE: GE P7 Double Oven, upper ovens heating element not
you have what is called a "Hot-Spot" in the element and it burned thru,now you need to replace the element
Posted on Nov 19, 2009
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
Whirlpool gold double oven model #gbd307pdb. upper oven lower heating element burned out. replace lower element. it does not get hot. upper element heats up. control board works. is this the thermos
You will have to see if there is power to the element. It is possible that the relay contacts burned when the element burned out. There is a fusable link but this would shut down both the top and bottom elements. If the relay is burned out the control board will need replacing or rebuilding.
Oct 28, 2014 | Ovens
SLOW HEATING OVEN
you may want to check your broil element
turn the unit on and wait a few minutes
see if you can feel the heat from the upper broiler elemnet
some model use both elements to preheat
i dont have your productiuon number so i cannot be sure with your model
anyway
14-20 mins is the industry standard for a 350 preheat...
Oct 25, 2009 | GE 30" Built-In Single Electric Wall Oven...
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
Elements in convection oven won't heat
DO you have a model number for that. I'm almost sure it's a thermal fuse in the back of the oven. Usually they go out during or after cleaning but that would shut down both elements. If you have the model (usually by the inside door look all over and up in the cavity) Then if you go to this link
http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
It will show you a breakdown of the oven and where it is. If you give me the model I'll show you what I'm talking about. Good luck.
P.S. if it the fuse it's a cheap fix, little hard to get in back of the oven but cheap!
Mar 04, 2009 | GE Ovens
Electric Oven doen't heat
cdkd, there should be a TC0, on the back of the oven. Thermal cut out. You want to check to see if it is open. You will have to pull the oven out enough that you can remove the back panel cover and check it. The lower and upper oven should have one. It's a very cheap part to replace. If this TCO fails, no heat. Check this first before buying a new board. Catriver..post back.
Nov 17, 2006 | GE Profile JTP56 Electric Double Oven
Kenmore 41389 Electric Double Oven Logo
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
