Question about AT&T Lands Phones
Lg cell phone manual model number lg 280
Phone won't ring when getting calls
  • 43 Answers
SOURCE: Internal Call "Voice Call" and does not ring
You can toggle each individual phone extension as to whether or not it recieves a "voice" call or a "ring-first" call.
At the extension, press "SPEAKER - 60" it will display the mode. Press the * (asterick) key to toggle between the modes. Then press SPEAKER again to set.
Posted on Feb 12, 2008
SOURCE: GE DECT 6.0 GHZ cordless fone (model 28111) don't ring
There is a Do Not Disturb button on the base unit. Press it to turn the feature on and off.
Posted on Jul 09, 2008
SOURCE: LG 830 Vantage Cell phone voice dialling
With the slider up. Hold down the send key. Follow the instructions. The voice asks who you want to call. If you close the slider you can use the speaker phone.
Posted on Nov 19, 2008
  • 16 Answers
SOURCE: how to I forward incoming calls on my phone to a cell phone 3?
Call forward, off-premise is available on the NEC Electra Professional phone system if you have the Level II system (metal cabinet, not plastic) and you have system software level 700 (7.00) or higher. To get your system software level, press <FNC> - 3 from any display telephone when idle. The procedure to forward is (with phone idle): press <FNC> - dial 60, dial trunk access code (usually - 9), dial telephone number, press <FNC>. Additionally, your station class must be set to allow this feature (by default it is not allowed) and you may need trunk-to-trunk capability turned on in system programming (which is also, by default, not allowed). Hope that all helps.
Posted on Dec 31, 2008
SOURCE: user guide for 280 LG cell phone
Try this website. They have the manual in Pdf, etc.
http://ca.lgservice.com/index_b2c.jsp
Posted on Feb 22, 2009
I can call out on my cell phone..BUT it won't ring
The ring signal may be turned off and incoming calls go directly to voicemail
Sep 12, 2012 | Samsung Cell Phones
My phone wont ring everthing is turned up
Turn it off and then on. If no joy, turn off again, take battery out, put back in and turn on. Check your default ring (it could be set to "nothing," then volume won't help). Call your cell provider if they provide this model. They should know quickly what to do. If they don't solve it in 20 minutes, ask to "escalate the call." Don't be surprised if you get transferred (to someone smarter).
Feb 22, 2012 | Samsung Cell Phones
How can I change the number of times the phone rings before the voice mail answers? Model # KX-TG4022
The amount of rings before a call goes to voicemail is setup on the network itself and not the phone. Some mobile providers won't let you modify it and others will depending on your region. You would have to call your mobile provider for the availability of the option and the procedures. Sometimes you dial a number to change it other times it can only be changed manually by the provider.
Jul 15, 2011 | Panasonic Cell Phones
Answering machine Model 25865. Is there any way to turn the answering machine "on" remotely. Example: while away, electrical storm causes machine to turn off. Is there any way to remotely...
The manual for this phone doesn't say you can turn the answering machine on remotely, but every one I've ever seen can do so. Most of them say call your number and let the phone ring...and ring...and ring, and eventually the answering machine will turn on. Ten rings is what I've seen most often. I guess the manufacturers figure most callers will hang up fairly soon if the machine doesn't answer, so they pick a large number. Try it on your phone; worst that can happen is it won't work.
Jul 09, 2011 | Uniden Cordless Phone
I want to block one particular phone number from texting and calling me - how do I do this on the LG GW620
If you don't want to receive text or call from a particular person try this 1. ignore that person don't read his incoming message if only you can do that but make sure you memorize his number or assigned a code so that every time he text you already know who he is..2. If you don't wan to receive calls from that person if you that he is calling don't answer his calls or divert his calls to other number so every time he is calling his calls diverted to other number if you have a police number divert it there..and for the worst 3. Change your number and make sure he will never know again your new number so he won't be able to bother you again.. Hope it can help you..
Jul 06, 2011 | LG GW620 Cell Phone
1. Too many rings before answering. How can I shorten? 2. Because message is short, how do I bring "beep" closer to my message?
You don't say what brand and model phone or answering machine you have, so I can't give you a step-by-step answer. But here is general information.
The number of rings until the answering machine picks up is controlled on some units by a switch. Most of the time you'll find it on the rear or one of the sides. If it's a cordless phone/answering machine combo, the switch will be on the base unit. These usually have positions for 2 or 4 rings. Some have a "TS" position as well. This is for "toll-saver", which extends the number of rings if there are no new messages. If you call to check message while you're away, if the phone rings more than the number of times you selected you know there aren't any new messages. Then you can hang up before the machine answers and you won't be charged for a call. (This is a hold-over from the days where you might need to make a long-distance call to check your messages. Most people have cell phones with national calling plans now and it doesn't really matter.)
Some newer units have a setup menu where you'll find the ring selection. On a cordless phone the menu button may be on either the base unit or the handset. It depends on the make and model.
On most of today's answering machines, the beep tone is added when you're done recording. Usually you press and hold a button to start the recording, make your announcement, then release the button. The beep is recorded when you let go of the button, so there shouldn't be much delay after the message end. If the beep comes a long time after you finish speaking, either you're not releasing the button, or you have a very old style machine with a fixed recording time. The instructions that came with these usually gave suggested messages that would take the time, and typically had you end with "...please wait for the beep and leave a message".
You can usually find manuals for downloading from the phone or answering machine manufacturer's website, or on one of the many other manual sites on the Internet. Try a search for "(insert your brand and model here) owner's manual" as a start. Of course, if all else fails another option is to get a new machine. Basic models aren't expensive, but if what you have can be made to work the way you want, why spend money?
Good luck and thanks for using Fixya!
May 29, 2011 | Lands Phones
Good Day, I lost my manual and have a problem. My phone doesn't ring. The only way I know I'm getting a call is that the screen lights up. I must have hit a key that silences my phone. Is...
hello there.. what model is your celphone? is it motorola? lg? or nokia? or blackberry? i need to know the type so that i can help you..
thanks,
May 19, 2011 | Cell Phones
Group Pickup setup on Strata 280 phone system
Try Googling (Toshiba)(280)(manual) without parens.
Aug 12, 2017 | Toshiba Computers & Internet
User guide for 280 LG cell phone
Dec 18, 2008 | LG Shine KE970 Cellular Phone
Lands Phones Logo
19 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
