i have a sony rdr hx-720. i turned it on one day and the time was ahead an hour and line 3 was no longer available. up to this point i used line 3 to record from my digital box. can i retrieve line 3?
in the manual does it describe how to reset to manufactory defaults and have you got your hook-up to your digi box via a fully wired scart if so this cable is causing double feed back wich means signal is senging info from dig box back to scramble setting use a one way signal scart to recorder this is the lead i use to eleminate settings from being scrambled and a clear signal from dig box this is also updates time automaticly when you get back to settings menu turn off auto clock set this will stop time from going on 1 hour hope this will help
After formatting the RDR-HX710 says 'Disc is dirty' and don't wanna copy. Brand new discs of several...
(More)
After formatting the RDR-HX710 says 'Disc is dirty' and don't wanna copy. Brand new discs of several brands gave the same problem. Yet I don't have a solution.
I can connect my Sony KDL40V4000 tv to my Sony RDR HX710 DVD recorder using scart lead and scart...
(More)
I can connect my Sony KDL40V4000 tv to my Sony RDR HX710 DVD recorder using scart lead and scart socket to record Analogue TV. (Line 1 ON RECORDER) If I change scart sockets on the TV from scart one to scart two, the connection becomes "smartlink" but when I try ro record from Line 1 on the tv, the pictire is blank.
Any suggestions?
My Sony RDR-HX710 don't recognise DVD-RW formatted with Nero. I can use them on the PC but not with...
(More)
My Sony RDR-HX710 don't recognise DVD-RW formatted with Nero. I can use them on the PC but not with the Sony recorder that don't recognise them and so I can' format them. What must I do? I use mainly verbatim 4x DVD+RW but happens the same with all other brands... Carlos jcmat@aeiou.pt
