Question about Miller Electric Mfg Co 903394 Deltaweld 452 MIG Welder, 3- Phase, 15 - 38 V
Miller Deltaweld 452
With the wire feeder connected, I can strike an arc on the CC terminal but not the CE terminal. Any suggestions on solving this problem? DK
4 Suggested Answers
  • 5 Answers
SOURCE: Need Technical manual fro calibration purposes.
what problem are you haveing with it
Posted on Sep 15, 2009
luis_david
  • 407 Answers
SOURCE: My Miller Matic 200 will not arc. I have checked
If everything is connected according to manual, then your problem must be contact box inside the machine. If it is a recent model 2005 or higher then it could be the main pc board. I would start by checking the ground cable and clamp first before send it to a repair shop.
Posted on Jan 02, 2011
SOURCE: Miller deltaweld 452 power source is reading EEE
Replace the digital meter board, its function is to also control the voltage to the unit and read the amps.
Posted on Dec 12, 2011
Miller welder problem
the current setting is not working correctly
indicates that the amp setting for the wire is too low or if it is an inverter , the volts setting is far too low
Jul 26, 2017 | Welding Tools
I have miller deltaweld 302 lead stays hot all time what is th problem
Hi:
The problem could reside on the contactor, this part due to the heat and constant contact (that is the noice you hear everytime you strike an arc) sometimes it remains close. Check your owners manual and it is the numbered 21 on the part list.
Good luck
Jul 12, 2011 | Miller Electric Manufacturing Electric...
Miller deltaweld 452 power source is reading EEE code in the voltage slot ???
Jun 15, 2011 | Miller Electric Mfg Co 903394 Deltaweld...
I own a Miller "Sidkick" MIG welder. It has been
Hi:
If everything works but there is no arc; you should check your ground clamp, make sure it is not loose or dirty including terminals and replace your gun's contact tip.
Believe it or not this is a simple one.
If this was useful to you please vote. Thanks
Feb 25, 2011 | Miller Electric Mfg Co 903394 Deltaweld...
What size breaker and wire is required to operate the miller 452
You can tell by the plug configuration. The shape of the prongs. No Manual?
May 18, 2010 | Miller Electric Mfg Co 903394 Deltaweld...
Miller S-54D 115V digital wire feeder that does not weld right.
Hi Kevin,
Causes of poor penetration: Travel speed too fast, welding current too low,
poor joint design / and or preparation, electrode diameter too large,
wrong type of electrode, excessively long arc length.
Solutions: Decrease travel speed, increase welding current, increase root
opening or decrease rootface, use smaller electrode, use electrode with deeper
penetration characteristics, reduce arc length.
Mar 24, 2010 | Miller Welding Tools
CP 302 wlder
Trigger the wirefeeder while listening for the contactor on the CP302 to close, if it does start looking for loose, bad or missing ground connections to the work, then look for the power connection from the CP302 to the wirefeeder to be bad. If the CP302 contactor doesn't close look at the control cable between the wirefeeder and the CP302, try a different one if possible. If you hear the contactor close, and everything else is good, check the voltage at the CP302 output terminals to see if you may have a bad contactor.
Oct 29, 2008 | Miller Electric Mfg Co 903376 Deltaweld...
Miller Electric Mfg Co 903394 Deltaweld 452 MIG Welder, 3- Phase, 15 - 38 V Logo
80 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Jose Velazquez
Jose Velazquez
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
