Question about Emerson SB350 13 in. TV/DVD Combo
Emerson sb350 ( spongebob dvd combo )
Hello, very recently this tv combo started asking for a parental code when attempting to play any dvd. I went through the menu on the tv and tried to turn off the parental code but could not find how to. I also tried to change or set the code but since i didnt know the factory code it wont let me change it. I cant find my manual for this tv combo. I appreciate any help you could provide. Thanks, Sockman522 [email protected]
  • 4 Answers
I had the same problem.I fixed it by unpluging the tv.Then while holding in the power button I plugged it back in,still holding in the power button for twenty seconds.That fixed it.I read somewhere you could reset a Sony that way so I gave it a try and it worked.I also put a cd cleaning disk in it because it was saying "wrong disk" and that fixed that problem.Good Luck
Posted on Sep 18, 2007
SOURCE:
I don't know the parental code to this Apex Dvd/TV combo
For the full instructions on how to resolve this problem with Apex TVs please see this FixYa Tip.
Please leave a vote for the information if it helps. Thanks.
Mar 14, 2010 | Apex Digital GT2715DV 27 in. TV/DVD Combo
Parental controls
try giving the reset ...........
Jun 29, 2008 | Sansui DTV2760 27" TV
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Jun 28, 2008 | Sansui DTV2760 27" TV
Need the code for parental control.
I found the default password for the RCA DVD/TV combo player - if your model is 20F510TD - the default password is 8888. Hope this helps!
Dec 21, 2008 | RCA 20F510TD 20 in. TV/DVD Combo
Unlock codes
Found the code on another posting:
1,2,3,4
When the parental block comes up hit play, enter the code, then hit play again...
Jul 02, 2008 | Disney Princess TV/DVD Combo
Unable to get some NR movies to play even though I have unblocked NR material
The parental code is :
1,2,3,4
When the parental block comes up hit play, then type in the code and hit play again.  It should be all set.
Mar 28, 2008 | Disney Princess TV/DVD Combo
Wont Play DVD
any remote should work but i suggest a name brand like sony logitech or phillips because you dont want to have to replace this for a while and namebrands offer more functions than generics.
As for the dvd not playing dvds it appears the parental lock may be enabled preventing movies from starting after previews .
after you obtain the new remote and have programmed it scroll through the tvs set up menu to see if parental lock function is on if not drop me a line so we can narrow things down also try to push enter button on new remote if the play button doesnt start movie.
Jan 16, 2008 | Apex Digital GT1417DV 14 in. TV/DVD Combo
Parental cotrols
I had the same problem and all I did was : when it asked for a parental code i put in 6688 and that fixed mine.
May 27, 2007 | Apex Digital GT2715DV 27 in. TV/DVD Combo
Emerson SB350 13 in. TV/DVD Combo Logo
280 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
