Panasonic kx e4020
When I type nothing types out until I hit enter. I tried to reset as instructed but does not correct problem
  • 5 Answers
SOURCE: hdd master password
PLEASE REPLACE UR MOTHER BOARD BATTERY. I GUESS UR BATTERY MODEL WILL BE CR3212... PLEASE CHAGE IT AND TRY IT AGAIN. NOT YOUR LAPTOPS BATTERY... THIS IS A BATTERY ON THE MOTHER BOARD. PLEASE TAKE IT TO UR NEAREST DEALER AND GET IT DONE.. PLEASE DO NOT OPEN IT WITH ANY KNOWLEDGE.
CHEERS
AVI
Posted on Nov 05, 2007
  • 19 Answers
SOURCE: BROTHER ML100
Ok,there could be two possibilities ,1, The daisy wheel may not be seated in properly. Of course I assume that the print side of the daisy wheel is facing the platen and that when the typewriter is switched on the print unit makes its customary re-setting motion and that the daisy wheel spins around at the same time. if this does not happen make sure that the lock-in lever for the daisy wheel is pushed home.. I am sure that you do all these elementary things so the only other possibility is the the hammer seleniod is not fully functioning and would have to be re-placed....Good luck!
Posted on Nov 15, 2007
SOURCE: Random letters/correction tape
Hit Alt Operate Return - It worked for the same problem! : )
Posted on Aug 12, 2008
andyroid85
  • 7 Answers
SOURCE: Panasonic model CT-36SL13G TV
Your problem is most likely the thermistor , or degausser, is going bad. It is a little black box with pins and says D1R5M on it. It can be found by following the wire from the degaussing coil around the picture tube. The location number is CF803( i think)the Panasonic partnumber is D4DF1R50001. Also, I believe your fuse is 6.3A not 3.6A.
Posted on Sep 02, 2008
JUSTOLDJIM
  • 478 Answers
SOURCE: No Characters Typing
could be the ribbon is not lifting, do you see an image on the ribbon, also may be twisted inside the cartridge the shiny side has to be facing the keyboard.
Posted on Nov 06, 2008
I'm trying to sign in to my account and I can't remember password so it asks for email address I put it in and hit submit but it won't do anything, please help
Look in your other email's inbox (the one you entered). You should have received an email giving instructions on how to reset your password. If it's not in your inbox, check the junk mail folder.
Nov 16, 2014 | Computers & Internet
Panasonic kx e4020
In what editor/word processor?
Jul 11, 2013 | Office Equipment & Supplies
I have a panasonic electric typewriter R330 and it only types about in inch then stops how can i fix it?
The right margin is probably set. Hit margin release( MR) and see if it types, if so reset your right margin. Also something could me binding or caught in the path. maybe a correction ribbon or something is blocking it.
May 30, 2012 | Panasonic Refurbished Kx-r330 Typewriter...
I typed 192.168.0.1 in the bar thingy but the table thing keeps coming up gray, even if I go to quick start to set it up. Why?
You might be entering a wrong IP address. To confirm you are entering the correct address please press windows key + r (Win+r) you will get the run bar. In this run bar type CMD and hit enter. You will get the command prompt. In the command prompt type IPCONFIG and hit enter. You will see a list of details. Make a note of the Default gateway and enter it in the address bar of your internet explorer or any browser. Even after entering if its not working then try resetting the router and try again.
Hope this helped.!
Feb 25, 2011 | D-Link Computers & Internet
Configure my linksys wrt120n with the cd but can't found the internet all wiring are okay
1.Powercycle your equipment (unplug) Modem and Router
2.To ensure it is setup correctly the Ethernet cable should be plugged into the Internet port of the router
3.Wait 15 seconds and plug equipment back in
4.Check Firewalls Win XP: Start/Control Panel/Firewall/Turn off not recommended and try the internet
5.XP: Go to Start/Run/Type ncpa.cpl this will bring you to Network Connections/Double Click on Connection ensure the it is assigned by DHCP and it has a valid ip address it should start with 192.168.
Vista/7 Go to Start/Search Bar/Type ncpa.cpl and hit enter, right click on connection and hit properties. Uncheck Internet Protocol Version 6 and Click on Internet Protocol Version 4 and hit Properties. Ensure that Obtain and ipaddress automatically is checked as well as Obtain a DNS service automatically and hit ok.
6.Restart computer and Try to get online
7.Go to command prompt Win XP:Start/Run/Type cmd and hit ok Vista/7 Start/All Programs/Accessories/Right click on Command Prompt and hit run as administrator.
8.Type ipconfig /release and hit enter
Then type ipconfig /renew
9. Minimize command prompt and try browser
10. If still unable to access the internet open command prompt again and type:
1.netsh int ip reset reset.log
2.netsh int ip delete arpcache
3.netsh winsock reset
4.ipconfig /flushdns and restart computer
Oct 02, 2010 | Linksys WRT120N Router
Can not get connected
Powercycle (unplug power) all your equipment, Modem/Router waite 15 seconds then plug back in. If you are having an issue with the ip address not valid you can try these steps
(win xp) Start/Run/Type ncpa.cpl hit ok, You will see wireless connection double click wireless connection this will bring you to the properties. ensure that the connection is assigned by DHCP also check to see if you have a valid ip address
Win Vista/7 Start/Search Bar/Type ncpa.cpl Right click on wireless connection and hit properties. Uncheck Internet protocol version 6 and click on Internet Protocol Version 4 and hit properties/Ensure that obtain ip address automatically is checked as well as obtain dns server automatically. hit ok close out.
Go to command prompt Win XP Start/Run/Type CMD hit ok
Win Vista or 7 Start/all programs/accessories/ right click on command prompt and hit run as administrator.
At command prompt type;
netsh int ip reset reset.log hit enter
netsh int ip delete arpcache hit enter
netsh winsock reset hit enter
ip config /flushdns hit enter and restart computer this will reset the ip address hope this helps good luck
Oct 01, 2010 | Computers & Internet
Forgot password to ibook
If you're running Jaguar, and you know your short user name (the same as your home folder name) you can do the following.
1) boot into single user mode (boot holding Apple + S)
2) type "fsck -y" and hit enter/return
3) repeat step 2 until it says that "The volume [your hard drive name] appears to be OK"
4) type "mount -uw /" and hit enter/return (this mounts the hard drive)
5) type "SystemStarter" and hit enter/return (this will start up quite a bit, including NetInfo, which is what you need)
6) type "passwd YOURUSERNAME" and hit enter, where YOURUSERNAME is your short user name
7) enter your password, and hit enter (you won't see it typing)
8) verify your password, and hit enter (again, you won't see it being typed)
9) type "reboot" and hit enter
Your password will now be what you just set it to. Depending on how your friend changed your password, you may have trouble getting into your keychain, because it will still be what he/she changed it to, but at least you'll have access to your computer.
May 08, 2010 | Apple iBook G4 Mac Notebook
Unlocking a bb storm
It's instructions of http://blackberrymep.com , it may help you
1. Insert any sim card
2. Turn off all of the wireless connections
3. Go to Options
4. Select Advanced Options
5. Select SIM Card
6. Hit menu select show keyboard (where needed)
7. Type MEPPD or MEPD (you will not be able to see the typed info)
8. Enter MEP2 or MEPP2
9. Now it will say enter network mep code
10. Enter Unlock Code
Feb 17, 2010 | RIM BlackBerry Storm 9530 Smartphone
Need owners manual for panasonic KX-TG6412M Phone
HI there, I'm sorry, the closest I can come to finding your manual is on this page http://service.us.panasonic.com/operman/findmanual.aspx?model=KXTG
I followed the instructions at the Panasonic Manuals page to locate these several links. This link may may not take you directly to the results I received.
The instructions at the Panasonic site said to enter the model number. If nothing was found, to enter only the first several letters or digits until I found something. I couldn't find the exact match so I backed off the numbers until I got the hit.
Good luck, I hope this helps.
As an alternative, you may wish to take a look ata www.archive.org - a mammoth data base of instructions and manuals
Thanks for using FixYa.com
Please vote
thanks
a
Dec 06, 2009 | Washing Machines
75 people viewed this question
k24674
jasbo
jasbo
