Question about Acer Computers & Internet
Thermal switch overload - Acer Computers & Internet
  • Acer Master
  • 32,281 Answers
When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Posted on May 07, 2013
Does 6509-31 sawzall have thermal overloads
No the 6509 does not have a thermal overload.
Start by checking the brushes & brush springs then test the switch & cord
It is possible you burnt the armature out but brushes, switch, or cord is more likely.
Mar 07, 2015 | MILWAUKEE ELECTRIC TOOL CORP Milwaukee...
Will not start...where is the motor thermal overload switch
A motor thermal overload is usually mounted internally in the motor and is not replaceable. You might have a problem with your door switch though, because if the door switch is not making proper contact, the dryer thinks that the door is still open and it will not start. I would start with that and go from there. That will also be a less expensive repair. Hope this helps!
Feb 15, 2015 | Dryers
Reset thermal
I think the question is thermal overload on a three phase motor. If a motor has a thermal overload that must be manually reset then there should be a button on the motor, often red. While the motor is de-energized (power plug removed) , push the reset button by hand.
Jan 04, 2014 | Dryers
Tip-over switch location
It will be inline with the power entering, meaning probably by the thermal overload, it may not be equipped with that , but rely on a thermal overload as the oil units surface temps are no way near the point of combustion if it does touch aything as curtains or rugs etc.
Feb 24, 2012 | Honeywell HZ-709 Oil Filled Radiator...
Fan oven heats up then whole oven turns off, including timer.
It sounds like the thermal overload switch which is located in the oven cavity is operating and cutting the power. Does the power come back on once the oven has cooled down or is the power off indefinitely. Some thermal overloads are automatic reset and some are manual.
Feb 17, 2011 | Smeg Ovens
I am trying to find the thermal overlaod switch with no luck . Where is it exactly?
The motor has a manual reset thermal overload protector switch. If the motor overheats for any reason, the overload protector will shut off the motor. The motor must be allowed to cool down before resetting the overload switch and restarting. It is located on the motor housing on the side opposite where the pump and hose connections are. The reason this switch shuts off is because of low voltage problems caused by either a too low amp rating on the circuit it's plugged into or by using an extension cord. It is always safer and better for the motor to run longer air hoses than to use extension cords.
Jan 09, 2011 | Makita MAC700 2 HP Air Compressor (Hot...
HOW DO YOU REPLACE A START RELAY SWITCH ON A FRIGIDAIRE SIDE BY SIDE MODLE FRU26SA
Power off i.e unplugged
Open the back
Remove retaining clip on wiring side of compressor plastic cover.
NOTE wiring connections to terminals on the OLD relay. 1, 2 4 4 ect... make a simple wite color to terminal number sketch.
PULL off PTC relay WITH terminals by pulling HORIZONTALLY (Usually to the left / 9 O'clock position)
NOTE the thermal overload comes off WITH the PTC relay.
Remove wire from Thermal overload terminal and transfer the thermal overload to the new PTC relay.
Slide NEW PTC relay onto compressor terminals
Transfer remaining wires from OLD PTC to the correct terminal on the new PTC relay.
TEST compressor start before installing cover... PLUG in unit
After the test unplug the unit... reinstall the plastic cover and wire clip.
Reinstall back panel
Return unit to service.
Thanks for choosing FixYa
Kelly
NOTE the thermal overload will s akl
Sep 19, 2010 | Frigidaire Side by Side 26.0 Cubic Foot...
What is a thermal overload switch? We had a storm and lost power in the house. The fuse did not blow but the next day the pump would not work. We changed the fuse as a precaution. I believe the thermal...
A TOC is a bi-metal strip in a canister , they are normally placed on the motor windings and in most cases are auto-resetting.
All they do is sense the temperature of the windings and when they exceed the limit of the TOC (Which is set by the motor maker) they flip the Bi-Metal strip and open circuit the supply.
Normally once the motor has cooled down the strip relaxes back to the original position and the supply is restored.
It is not a standard practice to have a push button re-set however on that will depend on the makers whims
What you may have is a Thermal Fuse which melts if the motor gets too hot and you then need to strip the unit down to both check it and if possible replace it.
By looking at the rating plate on the motor you may find the manufacturer and approach them for a data sheet
Aug 23, 2009 | Kitchen Appliances - Others
ELECTROLUX C101H JUST SHUT OFFWHILE WIFE WAS VACUUMING, DOES THIS HAVE AN INTERNAL THERMAL OVERLOAD SWITCH ? HOW TO OPEN UP CANISTER TO SERVICE ??
it does have an internal thermal overload device you need to put the vacuum into the shop they should be able to fix it in a few days
Aug 01, 2009 | Electrolux Guardian Bagged Canister Vacuum
Motor will not start
I had the same problem and the solution was to manually press the thermal overload button. The button is located under the tool box next the motor head. I do not believe I tripped the thermal overload during use, but I suppose anything is possible. I’ve been using the compressor in sub 40 deg F. temperatures. I found the following in the Owner’s Manual, but had to look at the part manual to locate the switch.
MOTOR THERMAL OVERLOAD
PROTECTOR: The electric motor
has a manual thermal overload
protector. If the motor overheats
for any reason, the thermal
the motor. Turn pressure switch
to the “off” position and wait for
unit to cool before pushing the
reset button and restarting the
compressor.
Good Luck!
Dec 14, 2008 | Makita MAC5200 Electric Powered Air...
Computers & Internet Logo
18 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
