Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Mitsubishi ws 55513 rear projection HDTV
Comment by techworm, posted on Aug 10, 2007 For a WS-55513 Mitsubishi tv REplace the four caps in the tuner still getting flashing green LED,checked all three 4A 125v fuzeses (I checked for communty on fuzes got it). Now when a applly power to the tv set, I hear a chirping sound like (chirp then nothing). Where do I go from here? Need help bad Thankyou advance techworm
  • Tony Clayton
    Tony Clayton Aug 13, 2007
    Yes I still need help with this problem
    Genius:
  • 1,153 Answers
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB. 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT
Posted on Aug 17, 2007
Is it okay to run a Playstation game system on a ws 55315 Mitsubishi HDtv
Yes,this tv it is a projection tv,will not have burn in pictures as easily as a plasma tvs or some LCD tvs.
Jun 07, 2011 | Mitsubishi WS-55513 55" Rear Projection...
I bought a used mitsubishi ws 55513 and when i turn the tv on is says 480i stretch. How do i use the 1080?
U don't get to chose modes.480,720 and 1080 it chose by the tv show itself.Want more 1080 must have HD package from cable or satalite compannies.
Jan 26, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55513 55 in. - Picture to latge for scheen
Change your Display Format (widescreen mode) . You're using ZOOM. Press FORMAT on the TV remote control to cycle through the available display formats.
Feb 09, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55513 won't power on.
there is an electronic problem inside the tv you shoud go to an authorized service because the power supply to this tv it is in protect mode somehthing hapened inside and need to be repair
Dec 11, 2008 | Mitsubishi WS-55513 55" Rear Projection...
I got a Mitsubishi WS-55513 55 in and the guy said i have to replace a fuse do you know anything about a fuse and the cost
What does the set do when you try to turn it on? What does the led light on the front of the set do?
let me know so i can help
Tim Nolan
Sep 17, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Blinking light no power
Same here Once I plug the tv WS-55513 to 120 volts the green blinking timer blinks endlessly
Jun 24, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Wavy picture
This EXACT thing just started happening with my WS-48513. Anyone have any ideas?
May 18, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Blue Scrren
have you tried changing cables or running setup from "Device" menu? Keep me posted....
May 17, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Onscreen menu appears greenish
call tech and suggest to balance your screens ..they will know the procedure.
Nov 02, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
252 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
