I understand your frustration. It sounds like your GE washing machine is having some problems. Resetting the washer may help to fix the issue. Here are the steps on how to reset a GE washing machine WPDH8900J1WW:
1. Unplug the washer from the power outlet.
2. Wait for 2 minutes.
3. Plug the washer back in.
4. Turn on the washer.
5. Select a cycle and press the start button.
If the washer still does not work, you can try resetting the drum motor. To do this, follow these steps:
2. Wait for 1 minute.
4. Open and close the lid of the washer 6 times within 12 seconds.
5. Close the lid and press the start button.
If the washer still does not work after resetting the drum motor, you may need to contact a qualified appliance repair technician.
Here are some other things you can try before resetting the washer:
* Make sure that the washer is properly leveled.
* Check the water supply hoses for leaks.
* Clean the lint trap.
* Check the detergent dispenser for clogs.
I hope this helps!
How do I reset my Maytag washer to factory settings?
The easiest way to reset a Maytag washer is to disconnect the power to the washing machine for three minutes. Disconnecting the power allows the electrical charge to dissipate from the washing machine, which allows it to reset. If the reset fails, unplug the washer again, this time leaving it unplugged for ten minutes
Unplug it overnight to fully dissipate power from the control board memory.
The easiest way to reset a Maytag washer is to disconnect the power to the washing machine for three minutes. Disconnecting the power allows the electrical charge to dissipate from the washing machine, which allows it to reset. If the reset fails, unplug the washer again, this time leaving it unplugged for ten minutes.
Dec 2, 2021
This is a very nice commercial washer. I don't see anything in the manual (230S) that suggests it has a password. The last link is to the maker. Ask them direct.
Find commercial Wascomat EXSM230C washer replacement or repair parts fast at PWS Laundry, the largest worldwide supplier of Wascomat commercial laundry ...
Missing: reset ‎' Must include: reset
Wascomat EXSM 230 S Manual Online: Error Code Cause. 01E Water level not reached within set time. Take necessary action. Press START again.
THIS IS A EXCELLENT WORKING WASCOMAT EXSM230C WASHER. ... LAUNDRY MAT DRY CLEANER PASS THROUGH WASHER WITH HOOD. $3,999.99. + shipping+ shipping+ shipping.
US$4,500.00 · ‎In stock
Our washers are built to last 30,000 cycles and we keep our promise. Years of experience have provided us with knowledge and skills to produce high quality ...
