Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
Jvc av56wp74 blue shadow
Noticed a blue shadow on the screen, especially around letters. Performed auto converg. and noticed blue cross three times thicker than red or green. Went to manual converg. and could not get it adjusted out. A day or so later the convergance went way out as to have wavy lines and distorted picture. I replaced the convergance chips (purchaced directly from panasonic) thinking this would fix all. I ohmed out all low ohm resistors while board was out. All checked very close or right on value. Capacitors looked OK. After converg. board re-installed , did auto converg...took care of wavy / distorted picture but blue shadow still there. Cleaned lens on guns and looked at fluid and appeared clear. Tried to adjust focus of gun by rotating it...no luck. It is as if the blue gun is being over driven. I looked at the second level of service menu but do not know if it is adjustable from the menu or even If I should try it from this angle. Is it possible to swapp the green and blue gun leads on the converg. board to see if the problem moves? Will this hurt anything? Any suggestions , help, PRINTS...anything would be appricated Thanks Gmann
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
My suggestion would be...to replace the focus block..john
Posted on Sep 11, 2007
SOURCE:
Where is the auto convergence button
Hello
From it menu option, suf through and come to automatic convergence display option and press Ok button on the remote control.
The List & Labels part of the setup lets you edit your channel list and choose or create a
personal six-character label for each channel.
Note: Changing List and Labels can be time consuming. You can change these at a later time by accessing the
Setup menu.
1. Press the left or right arrow to scroll through the available channels and choose the
channel you want to edit.
2. Press the down arrow to highlight the In channel list option. Press the left or right arrow
button to add (the box is checked) or remove (the box is unchecked) the channel from the
list.
3. Press the down arrow to highlight the Channel label option. Press the left or right arrow
button to scroll through the available list of 25 most common labels. The last option in
the list allows you to create your own six-character label for the channel (the first letter of
the label is highlighted).
4. Press the 1 or 2 number button to change the first letter of the label.
5. Press the right arrow to highlight the second letter, then press the 1 or 2 number button
to change the second letter, etc...
6. When you are finished creating your label, press OK. For model D34W20, your TV tunes to
the last channel available in your channel list. For models D40W20 and D52W20 only, the
Auto Convergence menu appears next.
Auto Convergence (for models D40W20 and D52W20 only)
Your TV's picture tubes might have been disturbed during delivery or after you moved the TV,
causing the color in your TV to be out of alignment. The colors adjust by starting auto
convergence.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu appears. The
cross in the middle of the screen should be yellow. If it is not, use the arrow buttons to
move the red cross to overlap the green cross. Press OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle of the screen. If
it is not, use the arrow buttons to move the blue cross to overlap the green cross. Press OK
(the TV tunes to the last available channel in the channel list).
Ok
Mar 16, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
There is a blue shadow (especially around on screen graphics, lettering etc.) when in HD mode. I attempted to align the colors through the color convergence but the blue alignment did not work. I also...
No.This tv have a convergence problems,it dead.The tv have R,G,B colors lines mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board,must be repaired by repacling 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board,to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Feb 14, 2011 | Mitsubishi WS-65807 65" Rear Projection...
Cannot reset vertical convergance
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 16, 2009 | Mitsubishi WT-42311 42" Rear Projection...
Panasonic PT-60LC14 Convergence Issue
Projection TV sets have two very common problems listed below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
Problem #2 - Another common problem is dull or washed out video.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 06, 2008 | Panasonic PT-60LC14 60" Rear Projection...
JVC AV-48WP30: CONVERGENCE PROBLEM!!! HELP!!!
U have convergence board issues. Sometimes over time the solder joints on the board go bad or develop minute breaks. U might try removing the board and resoldering every thing you can get it. U can also consider baking the board in an oven at around 270 degrees for about 8 minutes to melt all of the connections on the bottom of board.
Then remove, allow to cool, cross your fingers and see what happens.
May 05, 2017 | JVC AV-48WP74 48" Rear Projection...
No blue auto convergence when performed by menu buttons
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 31, 2008 | RCA HD52W59 HDTV Projection Television
Jvc av56wp74 rear projection tv
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 18, 2008 | JVC AV-56WP74 56" Rear Projection...
Blue shadow
colored shadows indicate to me a convergence or focus issue. convergence issues can occur on one part of screen. and most recognizable around letters. this might could be adjusted by a technician
Dec 07, 2007 | Hitachi 57F500 57" Rear Projection...
Jvc av56pw74 blue shadow
You are going to need a full convergance alignment to rectify this issue.
Aug 09, 2007 | JVC AV-27720 27" TV
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
227 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
