Question about Farberware Blenders
Need a replacement gasket for farberware blender
I can't seem to find the replacement plastic o-ring for the blender. Farberware's website directs me to a customer service email, that gets returned as an invalid emal. I don't know where to find the replacement part.
4 Suggested Answers
SOURCE: Kenmore KMB048 Blender
1800KENMORE
Posted on Aug 22, 2008
  • 1739 Answers
SOURCE: where can I get replacement
Available replacement parts for your blender are normally available online at the following site:
http://www.directpartsandproducts.com/blenders-fbl500ss-c-61_171_884_885_888.html
Unfortunately I do not see that a blade unit is available. I would recommend you contact this supplier directly to inquire whether a compatible blade is available.
Contact information can be found here:
http://www.directpartsandproducts.com/contact_us.php
Trust this is helpful. Thank you for using FixYa!
Posted on Aug 15, 2011
SOURCE: GE single serve blender 898679--need replacement
I had the same issue. i took the gasket from the other blade to use with the blade i use everyday. one trick is, don't remove that gasket to clean it but make sure it stays in there. Just soak it and scrub it good, to make sure it stays seated in there.
If the gasket comes loose while you are grinding, the lid will come loose in the base and sometimes causes you to not be able to get the jar from the base. you have to turn the jar the opposite direction to get the lid to tighten up, then you can remove the jar from the base.
I am trying to get replacement jars since those plastic nobbies that run the blender have broken off. It is down to one of 3 nobbies, so it can't be run anymore. I mght just have to buy a brand new blender but it seems so wasteful.
Posted on Jan 28, 2012
Farberware 103742. Where can I get replacement blades?
Check with a local appliance parts supplier.
Feb 13, 2016 | Blenders
Where can I get replacement blade unit for Farberware/Salton blender model FBL500SS??
Jul 12, 2011 | Salton FBL500SS 3-Speed Blender
How do I fix or replace my kitchenaid blender blade KSB560BF (Polycarb Jar)? It's leaked thru the blade assembly.
Make sure the blade assembly is put together in the correct order. The blade needs to go through the gasket so that the order is pitcher glass, gasket, and metal blade base. Then the final plastic cap threaded onto the pitcher. If the gasket is not between the pitcher and the metal blade assembly, you will have leaks.
Also, check the gasket to be sure it's not cracked and that it doesn't have residue on it.
I hope this helps. If it does, please come back and rate my suggestion!
Jun 15, 2011 | KitchenAid KSB560 5 Speed Blender
GE single serve blender 898679--need replacement plastic gasket for grinding jar. I am told by Walmart, where I purchased it, that I need to return it. I don't want to return it. The blade chewed up the...
Mar 15, 2011 | GE Blenders
The plastic base the blades are fitted in ,cracked need to order replacement
the part is Black and Decker Blender Base Collar Ring BL5000-11
However these are prone to cracking. I ordered a second after my first cracked, and the second one cracked after just a couple uses.
Jun 09, 2010 | Black & Decker BL1900R Blender
Putting glass and washer together
  1. Place glass container upside down on safe working area.
  2. Place rubber gasket/ring on top of opening first.
  3. Place stirring or mixing blade on top of rubber gasket/ring.
  4. Take the plastic retainer and screw it on over everything previously assemble.
  5. Hand tighten only enough that you can reverse the whole operation when comes cleaning and disassemble time.
Feb 13, 2010 | Elite 072-04-1198 Blender
Blender container leaks even though gasket is in place
Hey, I know this is an old thread but just had the same problem and solved it. With the blender container upside down, place the gasket on the jar hole, put the blade through the hole on top of the gasket, then screw the plastic base on top of that.
The way I had done it before was to pop the blade into the bottom of the plastic base first then screw it onto the gasket and jar but it goes on the gasket, not under the bottom of the base. Hope that helps anyone else in the future.
Also just read the manual instructions like I didn't, clear as day right there but I never bothered to read them ha
Oct 18, 2009 | Cuisinart CB-600 Blender
Plastic pieces on glass jar and base are worn out and shaved down
I did the same thing. Order parts at thegourmetdepotco.com -- This problem is caused when you put the rubber gasket underneath the blade instead of above it. This causes two problems: 1. It lifts the teeth on the jar away from the teeth on the drive gear, which can grind down and break off the teeth, and 2. If the drive gear contacts the rubber gasket, it will melt the rim of the drive gear. In the future, to reassemble the jar after cleaning, first put the rubber gasket on the jar, then the blade, lastly screw on the base ring.
Apr 19, 2009 | Margaritaville Frozen Concoction (DM1000)...
Seal/Gasket missing on Braun Blender
Hi. There's only one common blender made by Braun, which has a triangular jug in either glass or plastic, but the locking ring and gasket are the same. It'd be a 4184, either a MX2000 or MX2050.
Auckland has a Service Centre:
0.gif Key Service Ltd
7D Echelon Place, East Tamaki, Manukau City Auckland
P.O. Box: 38569 Howick
Manukau City
Phone Country Code: +64
Phone: 09-916 0960
Fax: 09-916 0970
Service for: All products
Otherwise, you can locate Service Centres in Australia.
Apr 13, 2009 | Braun MX 2050 PowerMax Work Top Blender
Blenders Logo
650 people viewed this question
Top Farberware Blenders Experts
eyecam
Are you a Farberware Blender Expert? Answer questions, earn points and help others
