Oki es8460 mfp
False paper jams
flopez
  • 161 Answers
SOURCE: Dell 1600 paper jam 1 or no cartridge
Your unit is actually manufactured by Samsung. Most probably you have a bad paper sensor. As a technician, you will find these sensors on the power supply board (SMPS)or main board. If your are receiving tech support from Dell, please illustrate those guys on how to do their job.
Posted on Oct 02, 2007
thumu
  • 69 Answers
SOURCE: False Paper Jam
My name is Vikram Kumar Thumu, from India-Hyderabad. I have seen your message on the issue related to Paper Jam error messages even though there is no paper jam in printer . I would like to provide my suggestions on the issue. I hope that this should work for you and will resolve the issue.
This issue could happen if there is an issue with any small paper jam in the Printer, or due to the communicational issue .
To isolate the issue, I recommend you to perform below steps.
Steps are:
1. Power OFF printer and then please Disconnect the Printer from Computer and then disconnect the Power cable of Printer from wall outlet.
2. Check thoroughly in Printer that there is no small piece of paper in the Printer.
3. Let the Printer be disconnected and idle for 5 minutes.
Meanwhile please perform further steps on Computer.
  Note: The below steps are applicable if you are using WINDOWS 2000/XP/VIsta Operating system in  your PC
  Steps are:
 Perform the below steps to restart the print spooler :
1. Click Start>Run
2. Type services.msc
3. Click OK
4. A Window will pop up with so many services listed.
5. Scroll down to locate "print spooler" in the list, right click on it and click "Restart"
6. Restart the Computer.
Once if you are done with steps, please connect the Printer and then Power ON Printer and check the issue.
This should resolve the issue for you.
 If you need any further assistance on the issue, you can mail me at thumuvikram@rediffmail.com . I'll be glad to help you.
Bye.
Posted on Oct 20, 2007
SOURCE: OKI C5100 printer repeated jams. Usually flashing the code of "380: paper jam" as the message.
I've just cured the same issue.
Inspired by MCS-IT, I fed a sheet of paper into the paper path (printer over the edge of the desk) popped open the front cover and manually drew the paper through by turning the cog wheels. Voi-la (sorry French spelling not a strong point) a small piece of ripped paper was forced out!
Posted on Feb 21, 2009
SOURCE: My Oki B4545 MFP alarm always on
Solution provided by printer manufacturer tech support which worked for me.
1. Open all doors (front & back)
2. Remove tonner
3. Turn off power
4. After 20 secs turn on power
5. Close back door
6. Insert toner
7. Close front door
Fixed now!
Posted on Jul 02, 2009
SOURCE: fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Posted on Feb 25, 2010
ERROR MESSAGES ON HP LASER JET 1536DNF MFP jam in cartridge - there is no jam
Check to see if the paper is feeding, should be feed some what into machine, if not paper is not getting to cartridge and showing a jam... some times clean wheels with water or windex
Mar 28, 2017 | HP Office Equipment & Supplies
How to clear a fake paper jam in oki B6250 printer
The usual cause of "fake" paper jams is a prior "real" paper jam. One of two things occurs.
  1. A small bit of paper tears off the jammed stock and hides from view, but keeps the printer jammed. These can be hard to find and remove, depending upon where they are.
  2. In the process of yanking the jammed paper out of the unit, the sensor(s) become damaged or misaligned and give false jam indications. This usually needs repair or replacement.
Jul 30, 2015 | OKI Office Equipment & Supplies
Why do i have a false jam reading?
I understand that you're receiving what you believe to be a 'false' paper jam on your HP Photosmart C6280 All-in-One Printer. I would like to work with you today with resolving this issue. Paper jams can be real or false. The product might report a paper jam even when there is no jammed paper. A false paper jam may also be the result of having a bad paper jam at a point in time and that bad jam causing a hardware issue to the paper sensor or rollers. I am going to provide you with some additional troubleshooting steps that apply to both real and false paper jams. You did state that you already checked the paper pathway inside the printer and failed to find any evidence of paper being stuck, but please run the step-by-step troubleshooting below, even if you have already run some of the steps.
Here are the steps for clearing the path:
Photosmart c6280 False Paper Jam Messages
Try this blog for alternate clearing ideas for this printer. HP Photosmart C6280 error message Carriage Jam
Jul 02, 2014 | HP Photosmart C6280 Printer
Frequent paper jamming, occasional false paper jam indication, black shade on the right side of the paper in my 10 months old (counter-64000 prints) Kyocera fs-1024 MFP photocopier. Cleaned the glass,...
Myself able to solve the issue, by replacing the drum yesterday. The drum is damaged due to non-removal of waste toner! Misguidance, improper service from Abhishek Enterprises, Shimoga.
Sep 22, 2013 | Office Equipment & Supplies
Put a new toner in, now says "paper jam"
There is little of paper in printer. Take the toner out and with very attention see, it must be in taht place, from where the paper going out, or that place from where taking paper, it can bee small paper.
Oct 12, 2012 | Oki Electric Industry Okidata Okidata...
OKI C5510 - when printing on photo paper, makes goo all over and photo does not print properly??
you must choose the thickest media type possible at the printer and on the pc. your fuser is not fusing properly causing toner to goo on the roller, changing to thick paper increases temp and slows printing to ensure bonding. some coated papers do not work well with OKI printers. you should check mnf website for specs and recommended papers types
Aug 04, 2009 | OKI C5510 MFP All-In-One Led Printer
Fatal error 980 OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
2. Remove tonner
3. Turn off power
5. Close back door
6. Insert toner
7. Close front door
Fixed now!
Jan 25, 2009 | Oki Electric Industry Oki - B4545 MFP...
Oki c5500 gives a false paper jam reading
service the rollers (either clean the pickup with clean alcohol or use sandpaper ) sometimes clean the fluff from the printer with dustoff helps as well
Health and Safety get an engineer to do it for you. if you have warranty call them out. check your total page count and diagnostics via printer status page before you call them out.
May 23, 2008 | OKI C5500n Printer
Paper Jam in OKI B4300 Led Printer
This printer is designed with a dual toner/drum chamber. Do not separate these two parts. Upon opening the lid, you will find the toner/drum assembly right in front of you. Pick it up with both hands and pull straight up. After that, you should be able to take the jammed papers. Know this: once a paper is jammed, printing another paper will NEVER take the first out. Just make sure to remove the complete papers. If they break, make sure you extract all the pieces.
Aug 22, 2007 | OKI B4300 Led Printer
jasbo
jasbo
