Question about Ingersoll Rand TS4N5 Ir Electric Stationary Air Compressor 5HP. 80 Gallon Vertical Two Stage
Pressure asdjustment tank pressure is 150psi, how do I adjust pressure down to 125psi paper manual does not show
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 33 Answers
Open pressure switch an dunscrew main screw/nut inside tthis will reduce the tension on the spring inside and will cause it to cut out earlier
Posted on Oct 16, 2014
K750 partner. What is compression in psi?
good compression would be 125psi-150psi..
Feb 25, 2016 | Garden
Where can I get a new pressure switch for my puma 6060 air compressor
Replace the pressure switch with generic switch available on ebay. You only need the port sizes and pressure cut in/out. If your switch cut out at 150psi or higher, you might consider replacing it with one that cuts out at 125psi to increase the life of the compressor (assuming that you can get by with pressure range of 90 - 125). Good luck
Feb 26, 2015 | Puma Air Air Compressors Puma Air PK6060V...
Air Compressor trips breaker under load. If I remove the belt the motor runs fine, spins freely as does the compressor pump. With the tank pressure empty, the compressor starts and runs fine. When it...
Most people recommend replacing the motor capacitor in this situation, since a faulty cap will reduce the starting torque. But in my case the check valve was the culprit - there was too much back pressure on the head.
Oct 22, 2013 | Campbell Hausfeld VT6290 2.0 HP 20 Gallon...
What should the compression for a 1999 saturn sl2 1.9l 16 valve DOHC be
it should be at least 180psi, 200 is better and it should be within 10% highest to lowest
Oct 03, 2011 | 1999 Saturn SL
Air compressor won't go over 40 psi?
my ace air compressor which is 26 gallon 5 hp will not get over 60psi what is wrong with it please?
Feb 14, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
1999 kAWASAKI LS 650 - Is compression reading of 90 psi to low.
Yes, it is too low. The minimum normal compression is 125psi. The range is from 125psi to 150psi.
Feb 01, 2010 | 1999 Suzuki LS 650 Savage
Compressor runs but won't get past 70 pounds of pressure
The check valve is by passing on the compressor and tank you can replace it to fix the problem it will be between the tank and the compressor. line to the tank. remove and replace or lightly sand with fine sand paper wet or dry 1000 grit. Clean and put back together. If you have your owwners manuel it will show a picture of it.
Sep 30, 2009 | Porter Cable Cable 4.5 Gallons 150PSI Job...
Ingersoll Rand  TS4N5 Ir Electric Stationary Air Compressor 5HP. 80 Gallon Vertical Two Stage  Logo
171 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
