Computer will not boot to c drive. it is reporting that the bootmgris missing or corrupt. consequently i can not do a system restore from the hidden drive . it will not load windows from cddrive either. with vista, it says files are missing on the disk. with xp it says it can not install to that harddrive. with 98 it loads fine until it is finished and reboots. then it says that there is not sufficient memory to load windows. drive is 186 gb and 2 gb ram. does anyone have any suggestions or solutions ?
SOURCE: boot up issues
The only solution to your problem is to consult a nearby repair shop. They have all kinds of CDs needed to bring your computer back to life.
Cheers................
SOURCE: Recovery Disk can not recover system
It could be a hard drive crash. Can you refort the hard drive and see if you get any errors.
Check to see if you have any scratched on the CD.
SOURCE: Windows Failed to load because Kernel file is missing, or corrupt
Are you talking about two problems on one computer? If so, the first problem doesn't matter until the second one is fixed. If you are talking about two different computers, then the problems can be each addressed.
For the hard drive that is not recognized, where did it come from? If you purchased it used, you may be out of luck. It sounds like you have a pretty good idea how computers work, and it also sounds like this hard drive does not work at all.
If these are both the same computer, then replacing the hard drive with a known working hard drive will most likely provide you with a solution.
I wish I had better news for you.
SOURCE: Windows vista ultimate will not boot up
Press enter and submit the changes :) computer should repair itself from a back up file and start as normal.
Regards
SOURCE: cant install OS BOOTMGR is missing
Usually the installer should have a function to allow you to wipe the disk, or delete partitions.
If it doesn't, and you do not care about the hard disk content, and it is acceptable to wipe out the entire hard disk, you can do so in Linux.
(There is a utility which will do everything for you - Darik's Boot and Nuke, you find it at http://www.dban.org/ . I'm also giving you the "manual" instructions below, though).
Boot with Ubuntu Live, open Terminal, become root with 'su'.
Now you need to know how your disk is "seen" by Linux. Since you only have the one disk and nonexistent disks will fail, we can try all the likely hard disk names. The first command that does NOT fail saying "No such device" is the good one:
fdisk /dev/sda
fdisk /dev/hda
fdisk /dev/cciss/c0d0
fdisk /dev/rd/c0d0
fdisk /dev/ida/c0d0
One of these commands (likely the first or second) will give you a menu ending in "Command (m for help)". type "p" and press Enter to list partitions; there should be only one and it should be a Linux type, probably 83. If it isn't, stop - something's wrong. But it should be.
The first column will say something like "/dev/sda3". Note the number at the end, here "3". You'll likely have "1".
Now type, "d" and press Enter. You'll be asked which partition to delete. Type the same number you saw earlier. Type "w" and Enter to save changes and exit. Type "q" and Enter to exit without changes. The partition can still be recovered, but the disk is now "unlocked".
Reboot and install the OS of your choice. The previous hard disk contents will be permanently lost, and you'll get a shiny new empty partition with a working OS.
You can also erase the disk without using fdisk (but you still need to know how it's named, and for that you can use fdisk) by typing
dd if = /dev/zero of = /dev/sda bs=1M count = 12
Here we suppose the disk turned out to be /dev/sda.
This will write twelve megabytes of zeroes to the beginning of the disk, effectively wiping any OS information there could be there. All disk data are as good as lost. The disk is now, to all installing purposes, a perfect blank. Reboot and install the OS of your choice.
Just for the record, omitting "count" will zealously wipe out the whole hard disk surface, all partitions, all data, irretrievably (except using residual hysteresis detection equipment - doubt if even NSA would take the trouble). This can be handy when decommissioning computers.
There are also
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors an outdated BIOS and damaged or loose IDE cables
Anothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a non-bootable source.
This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
make sure there are no disks in cd floppy usb drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
if its a flat ribbon 40 pin IDE it will be the fist to fail
make sure all power and data leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty a computer needs
data and power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error
also make sure you have set it boot from you hard drive in BIOS The latest versions of Windows, including Vista and 7, use the Windows Boot Manager to read the boot configuration files and data in order to load your Windows Desktop. If any of these files are corrupted or damaged, you will see a "BOOTMGR is missing" error. Fortunately, you can use a number of Windows tools to repair or replace the BOOTMGR or any related file that may be the cause of the problem.
Press "F8" repeatedly while the computer boots up.
This command enters the "Advance boot options" screen. Select the "Repair my computer" option and then press "Enter." The System Recovery Options screen opens.
Select the "Startup Repair" option at the top of the list and click "Next."
The utility will scan your system for the cause of the BOOTMGR problem and repair it. Hope this helps
Insert your Windows installation CD disk in your computer's CD drive and restart the computer.
hope this helps
Anothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs data and power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error
hope this helps
hope this helps
the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
hope this helps you
hope this helps you
