Question about Vacuums
Eureka Endeavor NLS loss of suction/brush won't spin
Shortly after I got this vacuum, it stopped working as well as it used to. It hardly vacuums up anything and the brushes won't spin. I have a long-haired dog so I have already gotten in there with a pair of scissors to clip out all the hair tangled around the brush, but even after that this vacuum is difficult to push and won't pick up anything. Anybody have this problem? Any recommendations for a new inexpensive vacuum?
  • 45 Answers
SOURCE: How to for Belt replacement and solution to suction loss
You say it lost its suction, then you also say this is plenty of suction power, seems you cant figure out the prob. Try cleaning the fan on the suction blower. The blades can get chocked with dust which will give you a reduced suction.
Posted on Jan 06, 2008
reddevil6
  • 1673 Answers
SOURCE: beater bar brush stopped working...
Does the power head motor stop, or does the brush roll stop. If it is the brush roll stopping, replace the belt and/or the brush roll. If it is the motor, you may need to clean out around the motor, it may not be getting enough air to cool causing it to overheat and stopping. That the brush roll plate off, take out the screw, and the top will come off, then you can check to see if cleaning is the answer, if not, the motor may be bad.
Posted on Jan 15, 2008
yeroc
  • 397 Answers
SOURCE: Eureka Maxima Bagless brush not spinning in vacuum position
belt doesnt have to be broken, check the metal arm on the vacuum, see if there is build up of old rubber from previous belts, clean the arm that spins the belt and double check to make sure u have the correct belt
Posted on Jan 20, 2008
SOURCE: In Carpet setting, the vacuum brush does not spin
I put 3 turns of electrical tape around the area of the beater bar that meets the vacuum belt. This solved the problem short of replacing the beater bar.
Posted on Jun 26, 2009
VacuumRepair
  • 438 Answers
SOURCE: My Hoover Steam Vac Spin Scrub aw/ Clean Surge
Greetings,
A few more things that you can try on your SteamVac. First remove the dirty water solution tank from the machine completely. You should see where the solution tank was just sitting, a plastic casing with a whole in it. This is actually where the suction from the motor goes into. Turn the machine on and feel the hole there for any suction coming out. Did you feel suction coming from the hole? If yes, then your issue is going to be something with the dirty solution tank, because without the tank it's sucking fine. If you didn't feel any suction from this hole, it may indicate that there is something more serious that needs to be taken care of.
One other place you may look on your machine (as long as the upholstery hose for stairs and furniture is already attached to the machine, and you don't have to hook anything up to the dirty water tank to use the attachments) while the dirty solution tank is out of it, is where the attachment hose makes connection with the vacuum. If you recline the handle down while you have the dirty water tank out, look in the back of the handle housing for a hose that enters the housing 3/4 down the housing. Now follow the hose on the inside of the handle not the outside, follow it up to the point where it goes into the neck, near where the suction hole is. Right at the end of the hose, right before the hose cuff, is this ripped, or damaged here?
Please feel free to request a clarification to this repair if you still need addtional help. If you can leave me the model number exactly that would help me help you, lol. I hope that this was helpful to you. If this was helpful to you, may you please click the helpful Thumbs Up Icon in the lower right hand corner of this repair?
Thank you so much,
Chris J.
Posted on Mar 21, 2010
Can't get the roller to spin
i suggest taking hose off and declogging it by using a water hose to make sure its free of debris. Plus check your belt first take off bottom plate the you'll be able to tell if belt is broken which it sounds like it is.
if belt is good and hose is clear and still brush wont spin then your brush motor needs replacing. hope this helps.
Mar 05, 2013 | Eureka Whirlwind Litespeed 5740 Bagless...
I have a eureka endeavor nls that does not have floor suction anymore although the hose is clear and the roller is working when on. what is going on...i am very frustraited because it is over heating
a vacuum works by sucking in air and passing the filtered air through the motor to keep it cool
if the motor is overheating and there is no suction , then you have a blockage
If you cannot see it take it to a service center to have it cleaned out
Jan 08, 2018 | Eureka Vacuums
Brush doesn't turn all the time
The belt is worn out and you need to replace it. It's slipping and that's what you smell.
Nov 13, 2011 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka Model Whirlwind litespeed. The rotart brush does not turn or rotate. Should it turn or rotate in order to give better suction?
Hello fnintel, yes, if you are using the upright vacuum it should spin, ( the belt likely slipped off, or the brush is clogged with hair and the likes.)
However, if you are using the hose on the vacuum like a shop vac, some models bypass the rotary brush.
Jan 09, 2011 | Eureka Whirlwind Litespeed 5840 Bagless...
Does the vacuum lose suction when in the floor mode if the belt is broken?
To put it simply, no. By floor mode I'm assuming you're stopping the brush roll from turning so that you can clean hard surface floors instead of carpet. When the brush roll doesn't turn you do lose agitation which vibrates the carpet so that the dirt is more easily picked up by the vacuum. But you don't lose suction because the brush is not turning.
May 18, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka 431BX suction stopped working. Roller still goes. Please help! Everything else is working great.
Even though the brush is spinning, you probably need to replace the belt2_bing.gif because it is stretched. It is probably slipping on the beater bar..
Jim
Nov 30, 2009 | Eureka 431BX Bagless Upright Vacuum
Brush stopped rotating and little suction on unit.
Jim
Nov 28, 2009 | Eureka High Filtration s Mighty Mite...
The brush does not spin when making contact with carpeting
I tried the electrical-tape-around-the-wooden-spindle technique. After a minute or so, it's back to functioning normally.
Mar 14, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Low suction on Eureka spinduster vacuum cleaner
The belt has stretch enough so as to not drive the brush roll under load. Try a new belt.
May 10, 2008 | Eureka 2971AV EZ Kleen Bagless Upright...
Smell/suction
The brushroll may spin when looking at it but stops when pressure of the floor is applied. The belts stretch, so they look fine but are not. The smell - if it's a rubber smell - would also be the belt. Some, or most, brushrolls can get hair in the ends that could also cause a smell and belt problem.
Dec 17, 2007 | Eureka 2971AV EZ Kleen Bagless Upright...
Vacuums Logo
171 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
