Question about Haier Refrigerators
Haier hte14waaww 02
I bought this Haier used. I want to fix it because it may be easier that way then to return it. So it does not get cold. I hear the fan running and the pump. But on further inspection I noticed that there has been messed with. The green (ground) was disconnected and a white wire had been cut. Not taped but just simply cut. Can I see a manual that deals with a small black box thats connected to the pump?
4 Suggested Answers
  • 146 Answers
SOURCE: haier htq18jaa fan replace
First make sure your door switch is okay. Other problems could be your defrost timer, evap. thermo. etc.. Make sure that it is your fan before replacing it. To replace it you take everything out of the freezer and remove the rear panel. You should see the fan at that point. You can check for voltage at the fan by disconnecting it and measuring for 125V at the leads. If when the door is closed you have power replace the fan. If not check all other possibilities.
Posted on Dec 26, 2007
  • 13735 Answers
SOURCE: I have a Haier model HTE14WAAWW refrig. with top
check the fan in freezer sounds like it is stuck [iced up ] or needs to b lubed at the back of freezer will see fan feel if fan is blowing or just humming
Posted on Sep 24, 2009
kel1guy2002
  • 3740 Answers
SOURCE: The freezer is cold but
Hi and welcome to FixYa, I am Kelly.
First off inspect the back of the freezer compartment for any signs of ice or frost build up that is larger than you ever noticed before. IF you notice an abundance of ice / frost perform a 2 hour manual defrost with a fan directed at the freezer compartment. Contents of the freezer removed and the unit un-plugged. Then return the unit fo service. Should there be an automatic defrosting system problem the cooling problems will return in 2 to 4 days depending upon how many times the unit was opened. If you still have the problem after the manual defrost session the next suspect would be a problem with air damper / diffuser PN: RF-2190-01 Since this is a manual control of moving a plastic diffuser to control the amount of air to the fresh food compartment I doubt this is the problem.
I really think you have an automatic defrosting problem (
Components that can cause the automatic defrost system no to work properly
HEATER / Item 121 this link: http://www.searspartsdirect.com/partsdirect/part-model/Haier-Parts/Refrigerator-Parts/Model-HTE14WAAWW/3126/0166000/50025348/00001
Defrost themostat PN: RF-7350-63 (not shown)
And the defrost control... not listed or shown. However, you can carry the old part in to most any appliance parts source and get a generic timer that will work. You unit should defrost some where in the following intervals. Once every 6 to 10.35 hours depending on which defrost timer control is installed.
The detached cable your seeing if most likely for an un-installed ice maker water valve. (i.e no ice maker kit installed / nothing to worry about.
Do a manual defrost... and if the unit starts warming up again in 2 - 4 days start troubleshooting the defrost timer, defrost heater and 60 deg bi-metal thermostat.
Thanks for choosing FixYa,
Kelly
Posted on Aug 10, 2011
Haier dishwasher HDW9WHT beeps 5 times and won't wash what is wrong with it can I fix it or should I get someone in
7 results (0.54 seconds) Search Results
    Haier HDW100WH / HDW100SS - ProductReview.com.au
    www.productreview.com.au > ... > Dishwashers > Freestanding > Haier
    Rating: 1.7 - ‎30 votes
    Haier HDW100WH / HDW100SS: 30 customer reviews on Australia's largest ... 1.7 out of 5 stars for Haier HDW100WH / HDW100SS in Freestanding Dishwashers. ... I putthis review in to do my part for what I think is a great consumer service you ... it it keeps beeping 10 times telling me doors open??and won't begin cycle.
    Haier Dishwasher Error Fault Codes - Lights Flashing ...
    removeandreplace.com/.../haier-dishwasher-error-fault-codes-lights-flash...
    Dec 21, 2015 - Haier dishwasher error codes - flashing lights - beeping ...Dishwasher keep filling water and draining at the same time ... Fix Washing Machine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note 5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The Refrigerator ...
    Dishwasher Has Beeping Sounds Blinking Lights - How To ...
    removeandreplace.com/.../dishwasher-has-beeping-sounds-blinking-light...
    Dec 21, 2015 - At times your dishwasher may need to be reset. ... Haier DishwasherError Fault Codes - Lights Flashing Beeping Sounds My Haier ... Fix WashingMachine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The ...
    How to Troubleshoot & Repair a Dishwasher ' HomeTips
    www.hometips.com/repair-fix/dishwasher.html
Jan 19, 2016 | Haier Dishwashers
I bought Air condition today(Haier 8000 BTU) I install my living room but it doesn't cool it,the setting is Cooling and high,please help me before I return it.
I would take it abck. Iknow its not the answer you want to hear but it might save you a lot of heart ache in the future
Jul 19, 2011 | Haier Heating & Cooling
Wine temp on Haier wine cooler BC112G went to LL, opened up and some champagnes frozen, other wines very cold, condensation all over door, how do you fix this error?
The error is likely caused by a bad temperature sensor. The control board may still be Okay.
Replacing both of them is recommended.
Check this link for parts: http://www.partstore.com/Model/HAIER+AMERICA+TRADING/Haier/BC112G.aspx
Dec 31, 2010 | Haier BC112G Wine Cooler
HAIER CPN11XCJ new, doesn't blow cold
There are three settings. If you have it on FAN, it won't blow cold. The raindrop picture is for dehumidifying, and the snowflake picture is the setting for COLD. If you shut the unit off and on too quickly, it takes a minute or two to cycle back to cool.
* Make sure the 'snowflake' setting/picture is selected...
Ours works too good! We sleep with 2 blankets! Nice...
Jul 25, 2010 | Haier Heating & Cooling
I bought it three weeks ago and yesterday it stopped blowing cold air.. any thoughts? or just return it?
mcdevito75 here, Use your warantee return the unit. Also follow the units manual on operation.
Jun 22, 2010 | Haier hwr10xc6 Air Conditioner
I have a Haier model HTE14WAAWW refrig. with top freezer. The refridge humes loudly. The freezer works, but to lower unit does not get very cold. The fan at the bottom, for the compressor does work. Please...
Sep 24, 2009 | Haier Refrigerators
Cold air not coming out. I JUST bought this the other day and it worked the first day just fine but now it will work fine for about 10 minutes and then the cold air will stop coming out. Air will continue...
Need to return this one where you got it. Sounds like compreesor or control problem. Do check outlet voltage to make sure it is not a low voltage problem first. Voltage should not drop below 10% of name plate voltage required. Voltage should be checked with unit running and cooling to see true voltage.
Jun 29, 2009 | Haier ESA306 Air Conditioner
Fridge not cold but freezer working great
I had the same problem, and it turned out to be a cooked fan motor.
I couldn't find a reasonable (less than $150) replacement motor from Haier places, but I just took the motor out and took it to an appliance repair center (in North Denver)
They said it was a standard part, charged me around $22 for a new one and I was all set.
For my replacement motor, it was a reversible design, and was initially set to go the wrong way, so I had to reverse it.
Apr 04, 2009 | Haier HTQ21JABWW Top Freezer Refrigerator
Refrigerators Logo
37 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
