Question about GE JVM1440 Microwave Oven
GE JVM1340WW Operates normally but, oven light comes on and sounds like it starts running again when the door is opened.
  • otto09 Dec 07, 2008
    oven fan continues to run with door open. won't run unless you put a napkin between the door and frame, even then you have to play with to get the right gap. any ideas?
  • GE Master
  • 9,156 Answers
One of the door switches may be sticking due to grease or carbon buildup. Or you may have a loose door switch mount. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Posted on Sep 28, 2007
My GE Microwave Convection Oven model JE 1390WV runs whenever the door is open. It microwaves on the normal settings, but when the door is opened it turns on and runs.
DO NOT USE IT!!!! THERE IS A SWITCH IN THE DOOR LATCH THAT NEEDS TO BE REPLACED.
AGAIN DO NOT USE IT!!!! IF ITS RUNNING WITH THE DOOR OPEN YOU COULD DO SERIOUS DAMAGE TO YOUR HAND OR ARM IF IT IS NEAR THE OPEN DOOR
Sep 19, 2017 | GE Microwave Ovens
Troubleshooting Ge Microwave that is acting bizarrely
Sounds like the main control board, but further testing should be done to rule out other possible causes. One thing I would do is to check to make sure it is plugged into a grounded outlet that is actually grounded. Bizarre behavior can be caused on some ovens because of a lack of a ground connection.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Oct 13, 2016 | GE Microwave Ovens
Fan runs when microwave door opened
-You're already answer yourself.
Good luck
Mai
Jan 22, 2018 | GE JVM1650 1000 Watts Microwave Oven
GE microwave fan turns on when door opened
The problem is caused by one or two bad door switches.
Apr 27, 2012 | Microwave Ovens
Problem with GE microwave-JES738WJ02
The problem is one or two door switches are malfunctioning or the keypad control board has failed.
Apr 23, 2012 | GE Microwave Ovens
Occasionally, and more frequently now, micro starts to run when the door is opened and stops when the door is closed. it will still operate normally but when you go to take food out, it starts running...
Door switches
If one of the door interlock switches is not switching properly or there is a condensation problem on the sensor control panel, either can cause the turntable/light/oven to come on even though the "Starts" button has not been depressed due to the wiring of the switches.
Check for faulty door switches and/or contaminated actuators.
I hope that helps.
Feb 13, 2011 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
Ge profile microwave oven runs when door is open
Good way to cook yourself! It has to be a stuck door interlock switch--the case needs to be removed to get at the switch. It could be either the mechanism that operates the switch or the switch itself is bad. The switch normally makes a click when the button is pressed. Unplug the unit when the case is removed.
Jul 16, 2009 | Microwave Ovens
Microwave oven stays on continuously and won't heat food.
Spacemakers have had problems with there magnatron, part is around 170.00. Depending on the year it is covered under a warranty however the labor is not. I have replaced 3 spacesavers for people already due to this issue. Unit runs but will not heat.
Jan 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE XL 1800 touchpad motor sound
that sound comes from fan motor, please replace or service fan motor ..
Sep 25, 2007 | GE XL1800 1100 Watts Microwave Oven
GE JVM1440 Microwave Oven Logo
309 people viewed this question
Top GE Microwave Ovens Experts
vince
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
