Question about Breville JK73 Cordless Electric Kettle
Kettle lights up but does not boil water - Breville JK73 Cordless Electric Kettle
5 Suggested Answers
  • 134 Answers
SOURCE: Siemens porsche kettle on/off switch problem
Hi
Make sure that the lid is securely on. Otherwise its the replacement of the auto bi metalic strip which turns the kettle off
Posted on Feb 14, 2009
SOURCE: light switch on Breville SK500-XL Kettle
e mail askus@brevilleUSA.com
Send them model number
PDC code (on bottom of kettle)
your name and address
where and when device was purchased
They can send you a part or send you a FEDEX label for a warranty repair.
This is a very common problem
Posted on Feb 21, 2009
  • 4 Answers
SOURCE: Automatic switch off not working when water reached boiling.
There is no do it yourself fix for this problem. However, placing a folded cloth on top of the kettle (covering the spout) will cause it to switch off quicker, as it increases the pressure inside the kettle.
Posted on May 04, 2009
  • 188 Answers
SOURCE: I have a cook works
Hi,the element must have blown best to replace kettle
Posted on Jul 23, 2011
How do i get rid of a taste when making a brew
Water and white vinegar will descale your kettle which may be causing the taste. Follow these instructions:
http://www.topcleaningsecrets.com/house/kitchen/how-to-clean-an-electric-kettle.html
Jan 19, 2015 | Kitchen Appliances - Others
Does not boil water
Our kettle light comes on but not boiling water
Jan 08, 2014 | Morphy Richards 43072 Cordless Electric...
My kettle suddenly stopped working, it still shows a red light when you go to boil the water but the water does not boil. its only a few months old so what would cause this problem
sounds as if you have a lose wire in the base or else you element has failed. Undo the bottom of the kettle and check all wires are connected to the element. If all the wires are connect i would say your element has blown.
Apr 18, 2011 | DeLonghi KBO3001 Cordless Electric Kettle
When filled with water & put on to boil it start's boiling as normal then after 10 or 20 secs.the lights inside flicker off and the kettle ceases to boil then the lights flicker back on and boiling...
I think you would only solve this problem by cleaning the thermostat contacts, or replacing the thermostat which wouldn't be worthwhile as it's likely to be cheaper to buy a new kettle.
Besides this , just getting into the kettle needs special 3 tongue screwdriver and then a certain technique to open it up without damaging the plastic parts. Im'e afraid its a throw-away world now and its not good .
Jun 28, 2010 | Russell Hobbs 14339 Cordless Electric...
Why does the water boiled in this kettle smell and taste chemically? Any boiled in a plastic kettle in my home is fine.
hello,
the chemical taste of smell from your kettle means that the element in the kettle which provide heat to boiled the water has gone bad due to over heating
this occur when there is shortage of water level in the kettle when the power supply is on
to fix up this problem of smell and chemical taste in your boiled water you will have to make a change of the element (heater)because it has gone bad you can get a replacement of it in the store .
thank you and thanks for using fixya.
Jun 01, 2010 | Morphy Richards 43072 Cordless Electric...
Kettle doesn't turn off
Our first Smart Kettle was great and worked well for years, finally died so we bought another. Right from the first boil it seemed to boil for about 2 or 3 minutes before turning off and then either didn't boil or made beeping sounds when not being used so after a couple of weeks we returned it and it was replaced. Great. But now this new one seems to boil and boil before turning off so maybe they are just faulty now. Any suggestions?
Jul 04, 2009 | Breville "Ikon" Tea Kettle Electric Kettle
Water kettle does not boil water
I had the exact same problem. The kettle would warm water but not boil. I bet you have hard water - try putting 1/2 vinegar and 1/2 water mix and turning it on. I did this, fixed the problem!
Nov 29, 2008 | Kitchen Appliances - Others
Light switch on Breville SK500-XL Kettle
Jul 24, 2008 | Breville SK500-XL Stainless Steel Cordless...
Sediment in my electric tea kettle
it is very hard to get rid off ass the sediment comes from the tap water untill you boil the water you dont see this sediment and take it for granted that the water is clean but as soon as you put it in a electric kettle this sediment builds up on the element then it brakes off and floats around in the kettle most new kettles have a filter near the spout so when you pour the water out it traps it in the filter then this can be removed and cleaned but the sediment floating in the kettle is hard to get out you can clean the element and descale it and then just keep pouring water in and out of kettle till its all out but it will soon build up again there are two ways to stop sediment one is filter all the water before putting in kettle but this can be slow process so not worth doing or the best sollution is buy a kettle that has a filter by the spout of the kettle and clean this regularly hope this is some help to you............................................
Nov 17, 2007 | Bodum (5600-01USA) CURL Electric Kettle
Breville JK73 Cordless Electric Kettle Logo
22 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
