Question about Maytag Heating & Cooling
Add freon window unit
I have a m3x05f2f-b model and it's not blowing cold air. I think I should add Freon. How do I do that? Thank you!
22yooper
  • 828 Answers
SOURCE: Recharge My AC Unit
The system needs to be accessed through what is call a tap valve. After a tap valve is in place a high vacuum should be pulled on the system down to 500 microns to remove air and non condensible gases along with any moisture from the system. Then the charge should be weight into the system according to the name plate with the proper type of refrigerant, generally Refrigerant 22. An alternate method is to charge the system by superheat of the gas returning to the compressor. Ambient temperature determines how high or low the superheat should be.
Posted on Jun 20, 2008
  • 56 Answers
SOURCE: air conditioner needs freon
If the system runs you will first need to add freon to the system (make sure it the right freon) Just enough to find leak. After you find leak and repair evacuate the entire system and weigh in charge. Hope this helps.
Posted on Feb 12, 2009
  • 38 Answers
SOURCE: AC is not blowing cold air. How do I add freon?
What you will be looking for (in your engine compartment) looks almost like a large valve stem that you would see on a tire. It will probably have some kind of plastic cap on it.
It shouldn't be that difficult to find. You may want to search for an engine compartment diagram for your make/model/year vehicle.
Posted on Mar 19, 2009
localwonder
  • 6784 Answers
SOURCE: not blowing cold air
Your in house core could have frozen over. check the core inside the indoor blower unit. it may have frozen over. this will interrupt the cold air function.
Posted on May 28, 2009
jasperoni
  • 203 Answers
SOURCE: My air conditioner won't blow cold air. It just blows air.
Hello I'm a M.B. tech. 1st you need to know why the freon is low. Hopefully it just needs to be serviced. There is a component located in the lf of the engine compartment called a receiver drier. It soaks up the moisture in the freon so the gases can work the way they are supposed to. On this unit there should be 2 switches(I believe they were combined into one switch in 98. 1 switch is a temp switch that operates your electric fans, the other is a compressor cutoff switch. Assuming the compressor is not coming on-take a fused wire and bridge the 2 contacts- If the compressor does not come on at all there is another problem(it is not low on freon. On the condenser there is a high side port(it is the bigger of the 2)By the brake master Cyl.(lf of the engine compartment thereshould be a smaller low side valve in line with the fuel cooler hose. Usually you can hook up a machine to the low port and **** freon in through that port. Assuming you do not have a refrigerant machine. It is very self explanatory on the bottle of r 134a refrigerant which can be purchased at your local auto supply store. I would start with 1 lbs. and add dye with the freon in case there is a big leak. If the system is overcharged it will not cool properly. I believe the system capacity is approx. 2 lbs. Add a few ounces after the first pound until a/c system is cooling properly and the electric fans are also coming on when the system gets to high. If you get a can with a good Gage set on it you should see the high side between 150 and 2000 psi(fan coming on at max. press.) also the low side should read about 35. It is about the temp of the evaporator which is i=located in the dash and the blower blows through this component out through the vents. Hopefully I have been helpful.
How do you add more freon?
Make sure the thermostat sensing tube is in it's place first. The thestat can be faulty too. The likely hood of Freon leaking is remote but possible. You need a whole bunch of special equipment to find the leak, repair it and recharge the system.
Aug 27, 2014 | LG LP1111WXR Portable Air...
The ac on my 1999 nissan sentra blows air but not cold should i add freon
check freon level also check to make sure compressor working first before adding
Aug 28, 2012 | Air Conditioning and Heat for Nissan...
On my 2004 gmc sierra 1500 the compressor cycles on and off. i tried to add more freon but it would not take the freon so i changed the low pressure switch but still doing the same thing. could the orfice...
When the compressor kicks on, is the air from the vents blowing cold? If the air isn't blowing cold, then your problem could be that you may have water in the system. I had a '93 Chevy Z71 that wouldn't blow cold and thats what my problem was. System needs to be evacuated and refilled. Good luck bro.
Aug 14, 2012 | 2004 GMC Sierra
I have central air and I was wondering how do you put freon in it because its not blowing out cool air
Is the compressor starting? On the outdoor unit you will see a large copper pipe and a small copper pipe. Is the larger of the two cold to the touch? wet? Just because a central air system is not blowing cool air does not mean it needs freon. If you have clogged filters it cannot do an air exchange. So, I would recommend checking the easiest things first before adding Freon.Most people make the mistake of adding Freon and overcharge their system. In a low load situation you can slug the compressor with liquid and your system is ruined. If you do have to add Freon it indicates that you have a leak. An AC System is a closed system and if it is working properly you should not have to add Freon.
Aug 03, 2011 | Whirlwind FH-778 Air Conditioner
My 2000 buick lesbre doesn't blow cold air like it
Hi bennysosiris...
If your compressor is starting and stopping regularly and it is not blowing cool as it one did then I would say:
Yes you need to add some freon to your system...depending what kind of freon it takes if would be better to take it in to have a professional install your freon to the proper pressure and volume.
Please take time to rate me
Aug 03, 2011 | Air Tools & Compressors
I have a fedders ac unit that does not put out cold air only for a couple of minutes. model # A2Q06F2BG-D can i add freon
Hello, you can add freon by installing a piercing valve on the low side of the system. Before adding freon I would check and make sure the air filter and both coils are clean. If everything is clean then most likey the unit has a leak and is low on freon.
May 26, 2011 | Fedders D Chassis AED24E7E Air Conditioner
Ice on the evaporator
Make sure the coils are not dirty,if they are not dirty,add freon to the system,not much,feel the evaporator,when the evaporator is cool all over,and the condenser is warm all over,there is enough freon,add very little at a time,this system does not hold much freon,if this was helpful,at all,please rate,thank you.
Jul 06, 2010 | Fedders A6Y12F2D Thru-Wall/Window Air...
Turbo air not blowing cold air
10 minutes?? So he added the gas and jumped in his truck and left?? WHAT COULD REALLY HAVE HAPPENED?
Feb 23, 2018 | Turboair TAS-24H Split System Air...
Window unit haier a/c (sorry, not sure model type, but it has a remote) isn't blowing cold (cool, but not cold) air and it sounds like the motor is just running in a 'fan' capacity. what can i do to get...
have your unit cleaned first, if it is cleaned and still the trouble persist. check if the compressor works. if not check the running capacitor for leak. if all are working fine have your unit system reprocess.
Aug 01, 2009 | Heating & Cooling
Can i add freon 2 my whirlpool window air condition unit myself if so how
NO........EPA VIOLATION AND YOU CAN GET IN ALOT OF TROUBLE
IF ITS NOT BLOWING COLD OR FREEZING UP TRY TO TAKE IT APART AND CLEAN IT WINDOW UNITS VERY VERY RARELY NEED FREON
Jul 22, 2008 | Whirlpool Heating & Cooling
Heating & Cooling Logo
24 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
