Question about Garden
Mcculloch 610 chainsaw won't start, has gas and spark
5 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: my McCulloch chainsaw 3200 internal fuel line in
Try your friendly neighborhood chainsaw seller/mechanic. Take a piece of the old hose with you.
Fuel Line Replacement
SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
Routing runs from fuel tank to carburetor, (if equipped) through carburetor to primer bulb, bulb returns excess to fuel tank.
Posted on Oct 13, 2009
rollercam351
SOURCE: Have a McCulloch 3818 chainsaw.
Had this problem with my saw (3818) there are two adjustment screws on the side of the carb there is a hole in the plastic to get to them just fwd of the choke slide, not the idle adjustment which is farther fwd of the other. take a 1/8" flat head screwdriver, get the saw running and turn them ever so slightly till you can get a good idle, they only have a 1/2 turn of adjustment each, it doesnt take much
Posted on Jan 14, 2010
SOURCE: NEED INSTRUCTION MANUAL FOR MCCULLOCH 838 AS CHAINSAW
Found it at
http://www.mcculloch.biz/int/support/owners-manuals/?query=MAC+838&types=O
Posted on Apr 16, 2010
Testimonial: "Thanks exactly what i was after,thanks again."
hunter19_46m
  • 7482 Answers
SOURCE: McCulloch Mac 110 chainsaw
Hi Connie
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Also be sure to check and clean your spark arrestor in the exaust,if you have one installed on your engine.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw or weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.
If the chainsaw/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indention in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Apr 05, 2013
How do I change the molded fuel line on my Mcculloch 605 chainsaw? Can I replace it with an unmolded type?
Yes, or you can just order the correct one using the resources below:
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Apr 25, 2014 | McCulloch Timber Bear / 605/610 Saw Molded...
Need new spark plug and gap pro mac 610
For spark plug and gap information, please refer to your owners manual.
Contact us
User manuals
McCulloch Service
Sep 04, 2013 | McCulloch Pro Mac 605 610 645 650 655...
Mccullock pro max 610 spark plug gap
Please refer to your owners manual.
Contact us
User manuals
McCulloch Service
Feb 27, 2013 | McCulloch Pro Mac 605 610 645 650 655...
McCulloch mcc1635a chainsaw won't run. Acts like it is starving for fuel.
take off the muffler and try it there is a screen inside that get plugged up with carbon you can open the muffler to clean it
Jun 03, 2012 | McCulloch Mcc1635a 16-inch 35cc 2-cycle...
Oil,gas mixture for a McCulloch 610 chain saw
Always use good quaility two stroke oil designed for use in chainsaws ( not out board motors ) and mix at 40-1, oil quaility has moved on greatly so it is acceptable to use less oil than was once needed.
Nov 10, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Mcculloch chain saw,pro-mac 610, with electronic ignition, no spark at plug
If there is no spark with a new plug, and the earth cut out wire not connected, then it will require a new ignition unit, the old unit is not servicable.
Oct 28, 2011 | McCulloch Garden
McCulloch 320 chainsaw, won't start, removed spark plug, it was saturated in gas mix, how do I fix it? Guess I should ask if it's worth fixing first, lol...Thanks
If the saw had been sitting a while, especially without fuel stabilizer in the pre-mix,. change out the fuel and try a few more times.. it si a goof idea to allways use fuel stabilizer fro all the small engines..
Best regards
Ck
Sep 09, 2011 | McCulloch Garden
14" Mac Cat gas engine won't start. Changed spark
Check tank fuel filter. safe way, put hose on end of filter blow through hose, fuel should come out of filter easily.
Sep 04, 2011 | McCulloch Garden
Garden Logo
224 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
