Question about Electrical Supplies
Ryobi generator rg 2700
My generator keeps blowing out the capacitor after about 10 min of use i have changed the cap now 7 times and this machine is still new.
SOURCE: 91 stealth dohc, w/o turbo.
The main computer (ECU) is directly behind the radio console. Pull carpet back on left and right sides of console. It is not the 'box' lying flat (trans comp). You should be able to take the ECU out w/o removing the radio.
Posted on Aug 14, 2008
  • 447 Answers
SOURCE: t rg fiesta front wipers fuse keeps blowing
Are you replacing it with the correct amp fuse? Buy a couple of the RIGHT fuses and try this.Your wiper motor may be bad, or the wiper mechanism is binding, causing the motor to over amp and blow the fuse. Try lubricating, if you get to it, the arm mechanism, and make sure it is not hitting anything while it is in motoion. Not familiar with this cars set up. Remove wiper blades, or stand them up and see if it still blows tyhe fuse
Posted on Feb 03, 2010
SOURCE: A friend living in the country bought a Ryobi
It's best to run all electronics through a UPS and surge protector. Small generators like the RG-950 are really for small power tools and lighting. The Ryobi RG-950 is only rated 650 watts which really means about 450 watts (70%) for continuous use. In general, a basic desktop or a laptop should be OK. A TV up to 25 inches and a 100w lamp, should be OK. If you try doing both at the same time, expect smoke followed by lights out. A UPS and Surge Protector are a must on small generators due to their poor voltage and frequency regulation. The UPS should be a good quality one that deals with Brownout, Overvoltage, and frequency deviation. ALWAYS USE A SURGE PROTECTOR!
Posted on Oct 25, 2010
  • 22 Answers
SOURCE: i just puechased a ryobi
The RG-6900 Ryobi generator does not have (or need) a battery. It is a manual type with cord start. Voltages and specifications may differ slightly depending on which country the unit is intended for (110V vs 220V). The same applies to warranty and servicing agents.
Send your email address to eggie-at-scheffler-dot-co-dot-za and I will mail you the manual in pdf format (820kb). Substitute "at" and "dot" with the usual symbols to mail me.
i just puechased a ryobi rg 6900 generator and it does not hahe a battery or operators manual. I need to know how to operate it and what size battery to buy
Posted on Mar 22, 2011
hercules946
SOURCE: I have a Ryobi RG6900 Generator,how do i connect it from the generator to the distribution board.
I use a COBRA. It is a lead with a plug at either end. Plug one end into the generator (output) and the other into any household plug outlet. (Set to the ON position)
Before doing so ensure that no outside power can enter through your DB board (switch the Mains Switch to the "off" position) Also switch off (at the DB board) any circuits that may cause a demand of more than 21 Amps (Stove, Geyser, Swimming Pool Pump etc)
Start the 6900 and wha-la you have power to all circuits not switched off at the DB Board.
I typically leave the light circuits, one of the plug circuits (to run the TV, Decoder etc) Security Circuit,and Garage Door opener switched on.
When mains power returns First stop & disconnect the 6900, remove the COBRA and then switch on the Mains and other circuits.
Posted on Jan 31, 2013
Why does my Kohler 7.3 generator start and runs great for about 5 min. then shuts downRestarts fine but shuts down seconds later. Upon removing rad cap, fluid is seen moving upon warm up. How do I...
change the oil to the correct specification first. As the engine runs the heat changes the viscosity and overheats or trips the oil alert switch. If its over 10 years old change the oil alet magnetic switch
Jun 12, 2014 | Kohler Electrical Supplies
My washing machine keeps burning out the capacitor
Does your machine have a start cap. and a run cap? It could be that the run cap is failing because the start cap is not engaging. The purpose of a start cap. is to provide the additional boost to get the motor turning, it then drops out and the run cap. takes over to keep the motor turning. Run caps. typically are not big enough to start the motor and will fail over a period of time.
Nov 09, 2013 | Whirlpool Washing Machines
What type of oil to use in RYOBI RG-6900K
Good day
Can you tell me what kind the oil using the generator
ryobi rg7900k.
Thanks
Oct 23, 2012 | Electrical Supplies
I just puechased a ryobi rg 6900 generator and it does not hahe a battery or operators manual. I need to know how to operate it and what size battery to buy
Feb 27, 2011 | Garden
A friend living in the country bought a Ryobi RG-950 generator. She wants to run 1 of her 2 computers or a TV 1 light at night and asked my advice. I told her that running any electronic equipment off a...
Sep 05, 2010 | Winco 5500 Watt TriFuel Power System w/...
My samsung lnt4065f quit working we took back off and found two capacitors are swelled, is this easy to fix it myself?
Yes it is easy to fix...the capacitors can be found at your local radio shack. Remember when replacing electrolytic capacitors, if you cannot find the exact uf and v specs, you can go higher in both uf and v specs, never go lower as you might blow the caps again. I have done several samsung lcd monitors and i replace all the electrolytic caps on the power supply board, exception being the 1 or 2 high voltage caps (200v or 400v). Make sure you keep notes as you remove the board, so that you can put it back together correctly. In my experience, it's only the caps needs replacement! Good Luck!
Aug 21, 2009 | Televison & Video
Am2 keeps blowing up
Its most likely the capacitor on the distributor. Remove the distributor cap and rotor. Under the coil on the right hand side is a cylindrical capacitor about 1/4 length of a AA battery. remove and replace. It's about a $5 part and an easy fix. If you go to NAPA AUTO PARTS, the part # is: RC102. The UPC # is 7-0739090352-1. The description is Distributor Capacitor and Terminal.
Nov 23, 2008 | Toyota Starlet Cars & Trucks
DISWASHER KEEPS BLOWING THE MAINS TRIP
FOUND SOLUTION...THE LITTLE CAPACITOR THING THAT SMOOTHS OUT THE FLOW OF ELECTRICITY TO MACHINE WAS BROKE. COST £5.00 FOR GENUINE HOOVER PART. FIXED EASILY TAKES ABOUT 3 MINS.....SORTED
Mar 25, 2008 | Hoover 24 in. HD83M Free-standing...
Electrical Supplies Logo
53 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
