Shinco fault code e2 - Heating & Cooling
    New Friend:
I recently had the E2 error code on 2 units a KFR-35GW/BMVE and KFR-50GW/BMVE. I recommend checking the refrigerant. Our's was extremely low and having it filled/charged resolved the issue. In all of the Googling, this solution never came up.
Initially the error code would come on and flipping the breaker off for 10 mins or so would reset it and it would work. Probably did this about 10 times every so often (like over weeks). Eventually this did not work and researching online led us to believe that either the indoor pipe sensor or indoor PCB was bad. Spent lots of time online trying to find these replacement parts to no avail. Was finally able to get a friend of a friend that is an A/C person to check them out and discovered the Freon was too low. Hope this helps someone else out there stuck with these "unserviceable" units.
Posted on Apr 13, 2017
What does E2 -F 1- mean?
It helps to know make and model in such questions.
Whirlpool Oven...what does E2 F1 mean on the clock/control panel ...
https://www.shopyourway.com/questions/1183452
Aug 27, 2012 - The "E1 F1" fault code indicates an Electronic control board malfunction. This means that the control board will need to replaced. I'm not able to provide a part number because there was not a model number submitted.I added an image of from the technical data sheet in reference to the "E1-F1" fault code. Whirlpool Gold Oven Error Code F1 E2
25 Jun 2013
Whirlpool Oven (GBS307PDQ0) Fault Code E3 (amber ...
17 Sep 2012
What does error code F1 mean on my Whirlpool ...
1 answer
14 May 2010
What does E2 F1 mean on a Kenmore electric range ...
1 answer
25 Mar 2009
More results from www.shopyourway.com
Whirlpool Oven...what does E2 F1 mean on the ... - Shop Your Way
https://www.shopyourway.com/m/questions/1183452 Aug 28, 2012 - Control panel for Whirlpool Gold double oven. 2 answers. whirlpool range, clock/oven control goes into alarm. 4 answers. Whirlpool Gold Oven Error Code F1 E2.
Whirlpool Gold Oven Error Code F1 E2 ' Shop Your Way: Online ...
https://www.shopyourway.com/m/questions/1218462 The F1 E2 error code indicates an oven control failure. Try disconnecting power to the range for 20-30 minutes, then restore the power. If this does not help, I suspect that the oven control will need to be replaced.
Whirlpool Appliance Fault Codes ' PartSelect.com
https://www.partselect.com/JustForFun/Whirlpool-Appliance-Fault-Codes.aspx Whirpool Oven/Range/Stove Fault Codes (Including 2 and 4 digit codes). Note: Depending upon the brand of appliance, there can be many different names for the 'clock' component. Electronic Range Control, ERC, Electronic Oven Control, EOC, control board, and clock all refer to the same part. 4 Digit Fault Codes. F1-E0 ...
Mar 24, 2018 | Whirlpool Ovens
What does the fault code e2 mean?
Kenmore e2 code Washing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > e2 code > Washing Machines
Kenmore washing machines e2 code related questions and answers. Ask yourKenmore questions. Get free help from washing machine experts.
Jul 26, 2015 | Washing Machines
Our dishwasher gas fault e2 we have had alook and nothing seems to be different
What do you mean "gas fault e2"? Your dishwasher is powered by electricity; not gas. Or maybe you meant to type "has fault e2" - well, now, that's quite a different story. Still we would need to know the model number of your dishwasher to be able to look up what that error code means.
Mar 08, 2015 | Samsung Dishwashers
Whirlpool GR396LXGQ oven comes on by itself & goes into clean cycle, code reads E2 -F3-
Whirlpool F3 faults relate to temperature problems in the oven. In the case of the error E2-F3, F3 is the general fault code and E2 is the specific error code. An E0-F3 error indicates that the oven's temperature sensor is open; E1-F3, that the temperature sensor is shorted; E2-F3, that the oven temperature has exceeded the maximum rated 575 degrees Fahrenheit in "Cook" mode; and E3-F3, that the oven temperature has exceeded the maximum rated 950 degrees Fahrenheit in the clean mode. Here is the probe to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 07, 2012 | Whirlpool Ovens
Error code E2 A.C. AUX
Disply E2 error Coming
Jul 23, 2010 | Heating & Cooling
Air conditoner won't go on and receiving E2 message on panel
E2 code is 24 volts loss. Check transformer and control voltage should be 24 volts.
Jun 05, 2009 | Carrier 38CKC036 Air Conditioner
Shinco Portable DVD SDP-1731A - Sound not working.
I have had a couple of these with the same problem , and in 2 out of the three cases the cure was the same .. Earphone socket fault ?
Ear phone sockets are designed to dissconect the speakers on insertion but with the constant use and pulling they get on a mobile system they sometimes lock open and do not reconnect the speakers you could check that ..
The other one I had was diffrent that one the sound output chip was faulty and had to be replaced as did the speaker output capacitors , one had failed causing the chip to overheat .. hope this helps Regards Vortash
May 12, 2009 | Shinco SDP-1730 Portable DVD Player
I have a whirlpool self cleaning oven and have an error code F1 E2
Hi Headcl
F1 E2 fault code is an error on the control board of the stove. By disconnecting the power from the unit for about 0.5 to 1 minute and then reconnecting the fault may go away after a minute or two (reset). Otherwise the clock (ERC) has to be replaced.
Regards
Nov 16, 2008 | Maytag Kitchen Ranges
Error codes
Hello raco1
Welcome
I need your model number to look up the fault code !!!!
You said , you see fault codes, FD F3 and E2 F3 is showing up on display pane
Looks like this may be your problem
F3 - E2 - Oven to hot -Replace oven temperature sensor
Waiting for your response.
When responding send me this whole communication . Not just your answer!
Thank you Huuum.
Oct 03, 2008 | Whirlpool RBD305PD Electric Double Oven
Heating & Cooling Logo
592 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
