Question about Kodak EasyShare DX7630 Digital Camera
Error #e21 I've got a kodak easyshare v610, which is RUBBISH!!!, but apart from that at least I was really looking forward to make some simple photos on it, but after half a year of using it ERROR E21 appeared on the screen! It's switching off or freezing and showing photos in many different colours saying "error e21" constantly! I don't have any warranty on it. What should I do? Chuck it away? I've paid for it £350 + SD memory card £50, I know, now new one is worth no more than £120...
    Genius:
  • 2,985 Answers
Having had it for half a year - how come no warranty? If you acquired it through regular means and still have purchase documentation then back to the retailer it goes. The problems you mention are definite - firm ware errors and seller/manufacturer responsibility. Suggest you also contact Support on Kodak website to discuss the problem - you do no have to discuss source if that is an embarrassment.
Posted on Aug 31, 2007
SOURCE:
Camera opens with optical zoom in mid range. Will not move to W..
HI! I HAVE A PROBLEM WITH MY CAMERA KODAK V610. WHEN I OPEN IT, THE LCD SCREEN APPEARED (CAMERA ERROR # E45 AND SEE USER'S GUIDE...PLEASE HELP ME HOW TO FIX IT...I LOVE MY CAMERA SO MUCH...I HAVE SOMETHING SENTIMENTAL VALUE FOR MYSELF....I KEEP IT FOR HOW MANY YEARS...I DON'T WHAT TO DO???? I LOOK FOR THE USER GUIDE IT WASN'T THERE...HOPE TO HEAR YOU SOON. THANKS
Aug 21, 2013 | Kodak EasyShare V610 Digital Camera
KODAK V610 MEMORY CARD STUCK
Try going into your setting and check the "QUALITY" settings. It may have defaulted to the maximum 6.1mp for images, and Quicktime for video. Also, you should have the option of formatting the SD card in the camera. Try these and see if it gives you a few more photos. With a card that size, you may have to take a step down in image quality to gain a higher number of stored photos.
Oct 23, 2017 | Kodak EasyShare V610 Digital Camera
I have a kodak easyshare v610 but the LCD was broken is it fixable?
Yes, it is easily fixable. Buy another camera sold for parts through ebay. Usually if you look for it you can get it very cheap. Change the lcd yourself. Only thing you need a screwdriver set, which you can get for $1 from dollar store.
Mar 21, 2011 | Kodak EasyShare V610 Digital Camera
Kodak EasyShare V610 "Camera Error
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Dec 13, 2010 | Kodak EasyShare V610 Digital Camera
Error message E45 comes up on camera - What can I do to fix it? Kodak easyshare V610. Message comes up when camera turned on. Batttery charged etc.
Is the lens extended? If so, try hitting the lens a couple of times with the palm of your hand and then turning off the camera. Turn it back on and let me know what happens. Sounds crazy I know, but those things are notorious for that error and that problem. You can also try taking out the SD card and see if the error goes away. Let me know what happens. Thanks.
Jeff
Nov 23, 2010 | Kodak EasyShare V610 Digital Camera
My camera error # e 45
This is a lens fault and unfortunantly the cam. needs a repair.
In order to arrange the repair: Pls. contact your dealer or KODAK directly:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=4248
Sep 27, 2009 | Kodak EasyShare V610 Digital Camera
Camera blanks out with message- error 45 and its not coming on
Fixing your problem could be as simple as cleaning the battery contacts in the camera, or the solution could be a lot more complex and expensive. Here's a link to the Kodak Help Center - it provides a simple Q&A format to diagnose the problem and propose a solution.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Aug 02, 2009 | Kodak EasyShare V610 Digital Camera
V610 KODAK ERROR E45
This problem is frequently due to weak/worn out batteries or corroded battery terminals inside the camera. If charging/replacing the batteries does not clear the problem, remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
It uses a simple Q&A format to diagnose problems and propose solutions.
Dec 04, 2008 | Kodak EasyShare V610 Digital Camera
My screen reads "camera error # E21"
On my LS 743 Kodak Camera, that error refers to a lens mechanism problem. I was able to fix it by removing my front cover which had be come dented inward and short circuited some wiring. Re-shaping the cover fixed the problem. This will probably void your warranty...
Oct 03, 2006 | Kodak EasyShare DX7630 Digital Camera
Kodak EasyShare DX7630 Digital Camera Logo
591 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
