Dayton 3ug91 How to connect the black and red wires in and out of the thermostat?
SOURCE: Wiring a Dayton Greenhouse Thermostat to control an exhaust fan
aAAA
Posted on Mar 26, 2008
  • 108 Answers
SOURCE: Wiring diagram for a Dayton thermostat
Contact Dayton on the internet for this problem. The diagram should be available on their site. Or they will give you a number for customer care. They can give you step-by-step instructions. I am a technician and this is what I would do as their are millions of wiring diagrams. Many are noy up to date.
Ray
Posted on Dec 07, 2008
  • 71 Answers
SOURCE: Help - I am trying to install a honeywell RLV4300A
You will have to have schematics from the old wiring diagram. Then you will have to confirm its consistency with actual old wiring before you can be sure that the wires run to the proper places on the old heater and a/c system. This sounds like a gas furnace and is simpler than a heatpump. Once you know what distinguishes the wires with the same color, you should label them and then you may call them a different color if they were wired with wrong wire colors. You may be in luck if you go to the furnace control box an look at the terminals.. They are usually labeled with a R for Red and W for white and Bl for Blue and B or Black. If you have other colors on these then it sounds that it was wired with wire spare wire by someone who knew what they were doing but neglected to leave a path for someone else follow.
You may be able to use a continuity tester of circuit tester to id these wires that are in question...
ie, once indintified, you can match with the requirements of the new stat.
Posted on Jan 13, 2009
  • 221 Answers
SOURCE: I have a Dayton 3UG73D heater that I need to hook
Here is your manual: http://www.air-n-water.com/manuals/G73.pdf
Posted on Jan 24, 2010
  • 86 Answers
SOURCE: Im hooking up a base board heater for the first
Hello there
It sound alright but You should draw out a wiring diagram on paper first before you tackle the job that way you know you're doing it right.
Good luck Dickson
Posted on Nov 04, 2010
Wire a dayton 4lz94a thermostat for turning on a gas fired heating unit?
If the unit has a switch that does fire it up when turned on. using the same gage wire, you can make an addaptor with an extention cord buy cutting just the black wire ing the extention cord and hooking the black wire from the male plug side to the line in side of the thermostat and the black wire from the female side to the load side of the thermostat..
Feb 12, 2015 | Dayton Heating & Cooling
WIRING DIAGRAM FOR A DAYTON EXH. FAN FOR A GREENHOUSE. tHE FAN GOES TO A THERMOSTAT THEN TO ELECTEICAL BOX
So far, I cannot locate a wiring diagram for an installation. However, this is a single phase "shaded pole" motor.
For a single speed, shaded pole motor, there are only two power wires. For a dual speed motor, a third wire provides a second speed. One wire will be one side of the motor coil(s)...connected to the white power wire. The other wires are the opposite side of one or two motor coils, connected to the black power wire or through a thermostat. A thermostat is simply a temperature operated switch. An additional wire may (should) be a green "grounding" wire.
Specification Sheet from Grainger.
http://www.grainger.com/product/DAYTON-Exhaust-Fan-4C361
Installation manual.
ftp://207.99.53.68/array1/pacs/AS-BUILT/D1112-50-GLOBAL-Terminal&Container(15KV_ARC-RES-Swgr_Outdoor)/D1112-50-O&M/D1112-50%20Global/BM%20%23%20549%20Exhaust%20Fan.d20100210-u113426.pdf
Mar 23, 2014 | Dryers
Installed dayton nat gas hanging furnace in garage and have 2 wires dont know where they go one came from the back side of the transformer it was twisted with the other wire
Hopefully there is a wiring diagram glued to one of the panels to verify but on the transformer you will have 2, 110 volt wires. One is the power coming in (usually black wire) and the other is a common (white wire) and will be connected to other common leads. On the low voltage side of the transformer one wire will go to the thermostat then from the thermostat to the gas valve. The other side will connect to the gas valve. When the thermostat calls for heat it completes the circuit from transformer to gas valve back to transformer.
Dec 11, 2009 | Dayton Gas Furnace Heater
How do i hookup a thermostat to a dayton unvented radiant heater modle be132c
Hi, If you are hooking up a programmable stat, the connections on it would be RC, RH, with a jumper connected to both, Y, W, and G. If you only had 2 wires before, red to RH and white to W. For cooling,Red to RC, and W to Y. Do not remove the jumper.
Shastalaker7
Nov 29, 2009 | Honeywell Programmable Thermostat Heater
Where do i connect load wires to 240 volt baseboard heater
this is tricky to some you must connect heater to the load side of thermostat must will have a black set and a red set wires look at the directions to find the line side which you hook wires from panel to them I will tell you some switches are different so with out seeing the schmatics its hard to tell you email me a picof thomastat and i can tell you hope this helps
Oct 27, 2009 | Dayton Electric Heater
I have a 3ug73d heater I would like to put a real thermastat on it.How do i wire it.
is this a baseboard unit? the thermostat kit has four wires - a black and a red, a black and a red. for 240 volt operation, both line wires go on the two blacks and the heater load goes on the red wires
Oct 13, 2009 | Dayton Heating & Cooling
How do you wire a dayton electric unit heater? Model-3e030,watts-15000, phase-3, motor amps-22, motor volts-120, heater volts-480, listed air heater-492b, cycles-60 ac.You have a...
red, white, and black will be your high voltage. Green will probably be for ground and yellow and orange go to the thermostat. I can confirm on Monday when I have access to manuals.
Oct 04, 2009 | Dayton Electric Heater
Dayton G73 wire hook up with 10/3 NM-B wire
Red wire is not needed. Be certain 208 volts is read across black and white. Cap off the red.
Jul 04, 2008 | Dayton Electric Heater
Heating & Cooling Logo
48 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
