Amiko hd8300 stb all channels scrambled
Was working fine. now all channels scrambled
2 Suggested Answers
  • 12650 Answers
SOURCE: I have a Amiko Micro HD box. Most of the channels have a $ sign on them, also says scrambled. Is there anything I can do Thank you
the channels with the $ sign are channels that you have to pay additional for either call or go online to the service provider to find out what package you have
Posted on Jul 04, 2016
Connecting rca tv model#F20352SF to a tv converter box
  • Connect ANTENNA OUT of STB to antenna terminal on rear of TV OR, for better picture, connect 3-wire cable to color coded L AUDIO, R AUDIO, and video outputs on rear of STB and connect other ends to L AUDIO, R AUDIO, and video inputs on rear of TV.
  • If STB connected to antenna terminal of TV, set CH 3/4 switch on rear to whichever channel is NOT used in your area.
  • Connect antenna to ANTENNA IN of STB
  • Connect STB to power and use STB remote to turn on
  • Turn on TV
  • If STB connected to antenna terminal of TV, use TV remote to select channel 3 (or 4).
  • Use STB remote to select SETUP and perform channel search.
  • Use STB remote to change channels.
Oct 23, 2016 | RCA Televison & Video
Jul 04, 2016 | Computers & Internet
Wont receive digital channels after scan non found
Hi Patrick,
You must have a UHF / VHF antenna connected to the antenna input of the TV to scan for digital channels. Most new TV's have a threaded, round 75 ohm coax cable connection for this - but yours might even have connection consisting of 2 small screws to connect a 300 ohm twin lead antenna cable instead. Use which ever yours has.
If you are using this input for the input of a cable TV "set top box" (STB), satellite STB, or similar, you will likely only find a single analog channel (Ch3 or Ch4) after a scan as the scan will only find the output of the STB - which is usually on Ch3 or Ch4 - and not be able to scan the STB channels.
Additionally, the antenna input of the TV will only provide a standard definition picture if connected via coax cable from the STB. It will only provide a high definition picture if connected to a UHF / VHF antenna and a broadcaster is close enough for its signal to be received by the antenna. The way to obtain the best possible picture (high definition) when using an STB for tuning channels is to use an HDMI cable between the STB and TV. An HDMI cable will provide the very best picture and audio signals from the STB to the TV; all over a single cable and is the recommended practice.
I hope this helps!
Dec 26, 2014 | Televison & Video
Amiko mini channels scrambled
my nick channel has scrambled how i fix it
Jan 27, 2014 | Computers & Internet
Some channels are not working, says scrambled or bad channel
hi pinkzz you must delete the channels that are bad/scrambled before you rescan because the box allready sees that the channel allready exists
Apr 21, 2010 | StarTech.com StarView SV431USB 4-port KVM...
Unable to rescan channels AWA STB 262 set top box.Need to scan for lates channels. Menu button not working. AWA HD Digital Terrestrial Receiver Model STB 262
These STB262 box remotes won't work if they are not hooked up with the 720dpi option (Use HDMI Cable) -
Cheers - compac
Sep 01, 2009 | Televison & Video
Tv guide listings at wrong time
Check the time zone setting in the STB. If after the power cut the STB settings got scrambled they could have defaulted to the wrong timezone. This would make the program guide times wrong.
Jun 21, 2009 | Sony DHG-HDD250 200-Hours Video Recorder
Tv listings clock at wrong time and recording the wrong show
Check the time zone setting in the STB. If after the power cut the STB settings got scrambled they could have defaulted to the wronge timezone. This would make the program guide times wrong.
Mitsubishi WS-55809 Upconvert Stopped working
your problem is the 2hdw board is located in the signal board.
Feb 02, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WE-52525
. Suspect the FMT PCB part # 930B924002 when set is warm.
Jul 31, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Computers & Internet Logo
186 people viewed this question
David Payne
David Payne
