Question about Konica Minolta DiALTA Di200 Copier
C500 error konica minolta DI470 How I can cancel (c-0500) error code in konica minolta DI470?! I replace Fuser roll And finger just .
  • 214 Answers
SOURCE: Konica Minolta bizhub 350 Error c0500
did you do a trouble reset ?
Posted on May 11, 2008
SOURCE: konica minolta EP2010 error code c05
I have a Konica Minolta CSPRO EP1054 (in the Middle East)
I accidentally plugged the EP1054 copier into a 110V outlet instead of the 220V. Immediately the malfunction code (error code) of "C05" appeared along with the "Call Tec Rep" indicator light (wrench).
I followed the instructions posted by "Soul Visitor" ... i.e., I found the "Trouble Reset Switch" (not shown in the user manual) by opening the upper back panel and pressing the small black button in the lower right hand corner of the middle circuit board (green).
It worked perfectly!7df26b9.tif
Posted on Jan 16, 2009
SOURCE: error code F-46-11 in my photocopier konica minolta 7035
I do appreciate your effort to help me sir,but if I do accept your offer which is the premium plan which I understand I have to pay,my problem is I do not know how to pay you,if through credit card I don't have it.So what I did was to brought my machine to the dealer where I bought this unit and their technician fix it.What went wrong was that the A/D conversion board has something wrong in it, so the tech'n. took up a working conversion board from a good unit and replaced it with the faulty one.Tried it and ok. They charged me for that conversion board with 95 dollars.So what's your comment on that sir? May I know soon?Thanks anyway.
Posted on Feb 11, 2009
  • 14 Answers
A 46-11 code indicates a communication failure between the A/D converter board and the main control board. Likely a bad or poorly seated ribbon cable. Try to reset the machine by turning off the main power switch on the side of the machine for 10 seconds and re-powering up. If the problem persists you will need to call a technician.
Posted on Feb 15, 2009
SOURCE: Konica Minolta Di470 With Pi4700e Password
miltfunction dedected code
Posted on Nov 10, 2009
What is the utility key when trying to reset a fuser abnormality code on my konica minolta pro c500
Sir,
TO reset that code on C500 is not done with the utility button.
1. First power off the machine.
2. Hold down the 2 and 5 button and power on the machine.
3. Wait for screen then select Soft switch settings.
4. See a new screen, in the first box on your left put a 3
5 in the second box put a 1
6. In the third box you are going to change the 1 to a 0.
Exit. power off the machine. Wait ten seconds power on. If the code comes back have a technician look at the machine do NOT RESET again you are resetting the codes for the Fusing unit the Hot part could CATCH on FIRE!!!!!!!! or do more damage to circuit boards.
Sep 11, 2014 | Konica Minolta bizhub Office Equipment &...
Why am i still getting error code 0500 i bought a new fuser unit.
You need to reset the machine, the new fuser does not reset the machine.
May 03, 2014 | Konica Minolta magicolor 1690MF All-In-One...
Trouble shoot konica minolta error code 0500
need to know model number
most konica minolta 0500 codes is fuser related and a tech has to reset it
Aug 22, 2013 | Konica Minolta bizhub Office Equipment &...
(C-0500) error code konica di 470
There is a trouble rest button inside the front door above the fuser unit. There is a small panel with one screw in it, remove the cover and you will see a PCB with two black switch's on it. One is the trouble rest button, have the copier ON and press the trouble rest button and close the door and you are done... If it will not rest, check what you did and make sure it is put back correctly.
May 06, 2013 | Konica Minolta Minolta Di450 Di470 Di550...
How to fix C-0500 error for BIZHUB C350 konica minolta printer
Open the front door with the machine on, get down on the floor and look up on the right side of open area there is a slanted section in that slated section is a small hole you will not see it standing! With a small screwdrive gentle push the small switch located in side the hole that will reset the code if it comes back DO NOT RESET the copier is telling you something is wrong with the FUSER UNIT the HOT part continued reset might catch the machine on fire and that would ruin a perfectly good day. Have a qualified Tech look at it from Konica Minolta.Check this web site out for a rough idea of cost to replace the fuser.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jan 31, 2012 | Minolta Office Equipment & Supplies
Err c 0500
This error code is a fuser problem and maybe in my experience a morning problem.
Try to clear the error the error with this procedure:
Hold down utility counter for 3 seconds and in the screen will appear a trouble reset, then touch it and turn off and on the main, it will clear the error code.
If it does not see if you have fuser problems with the termisotrs and also check the power.
Jul 21, 2010 | Konica Minolta Bizhub 222 Black and White...
How 2 unlock c 0500
on a c350:
1.leave the machine on and open the front door
2. locate a small rectangular hole inside the front dooron the bottom right side corner
3. insert a small object such as a small ball point pen to actuate a switch that resets the error code the screen will indicate door open when the error is reset.this is a fuser error code so if the error keeps coming back the fuser will have to be replaced
Nov 14, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta Pagepro 5650 "fuser error 0500"
You have to call a tech, to remove the fusing unit and try to fix it. In the worst case scenario, you have to replace the fusing unit, which is not very cheap.
May 14, 2009 | Konica Minolta PagePro 5650EN - Printer -...
Konica Minolta DiALTA Di200 Copier Logo
138 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
