Str gx50es My Sony SRE GX59ES has a constant low low volume buss everything else including volume work fine. I moved to a different power source with different speakers.
sapperj
  • 70 Answers
SOURCE: Buzzing from speakers
First, let's distinguish a buzz from a hum. A hum is a clean, 60 cycle signal that sound like a tone. A buzz is 60 cycle noise created when the power filtering circuit is not doing it's job. This is basically a 60 cycle hum, but because of the way the faulty filter reacts, it "distorts" the signal slighly and is a buzz. Trust me on this if you don't want a full electronic explanation. If you are curious and would like one, email me seperately.
If it is a buzz, chances it is the filter capacitors, but lets not jump to that conclusion yet, this can only be fixed by a professional, so let's try the free fixes first!
You might have 1) a ground loop, 2) faulty house AC. What is the age of your house? Are you using any three prong to two prong adapter? If so get ride of them.
But the first obvious thing is to look inside the unit and see how dusty it is. UNPLUG FROM WALL before opening. Use a can of compressed air if necessary. Now try. Dust build-up causes static electricity with can play havoc with electronic componenets, but normally not 60Hz, but it's worth a try.
Before I get into the ground loop, do you have any flouescent lights in the area? These use transformers which tend to put a 60Hz buzz through wiring it is directly attached to, but only when on.
Check if this buzz is consistant with any selected device (DVD, CD, Radio, etc.). If it is true of all, continue on, if of one, disconnect that particular device and see if it stops. Just turning off a device still keeps it in the elctrical loop...
A ground loop can be caused by a broken wire. It is important that every compnent be grounded to a single point. With a broken wire this can cause multiple paths to ground. disconnect everything, all components from the receiver, antennas, any cable running to another component, etc Just leave the main speakers hooked to the receiver and turn it on. Hopefully you have "audio snow" but no buzz. This method is called isolating the problem. If the buzz disappears skip to the 2nd paragraph. If you still have a buzz: unplug unit from wall, try a 3-2adapter into the wall. If this works, you have a faulty ground. Bring receiver into another room and try. Same result with buzz? (with or without 3-2). Go to a hardware store and purchase a ground fault indicator and make sure your house wiring is OK. Very inexpensive part. You simply plug it in a the lights tell the story. Usually two yellow lights and one red. Both yellow on indicate everything is fine.
Up until this point I am taking it for granted tht the power cord from the receiveris three pronged. If it is NOT, try running a thin wire from the outlet (attach using the center screw that hold the outlet cover in place) to a screw on the receiver. It would not hurt to try this even if it is a three pronged connector in case there is a broken ground within the unit.
Hook up and test each component until you hit the one the causes the buzz. When this happens, try using a different cable as this one is probably broken. If it doesn't stop, try what we tried for the receiver, if it is a three prong electrical plug, use a 3-2 adapter, still buzzing, now try adding the extra thin wire between the two compnents.If it a two prong, add the ground wire from the component to the receiver.
If all else fails it needs to go into the shop. But I will say this. Compare the cost of getting an estimate/repair with purchasing a new unit. It might actually be less...
Hope this helps,
Jeff
Posted on Jan 14, 2008
gman63b
  • 9 Answers
SOURCE: Sony STR-DE635 Receiver-no sound at all
Turn your volume down,press the tape monitor button.then turn up?
Posted on Mar 21, 2008
  • 4234 Answers
SOURCE: Low volume on left channel of Sony STR-GX4ES
The headphone is tapped before the final stage of the amp, so knowing that those work properly helps to isolate the problem. I think that this model uses an IC for the voltage amp section prior to the final amp stage. That being said, the IC is probably an UPC2598 (if memory serves). I'll confirm tonight. Try resoldering any connections that appear to be grainy or have rings. Let me know what you find.
Dan
Posted on May 08, 2008
linswad
  • 258 Answers
SOURCE: Right speaker is distorted with low volume, left
There is something wrong with the right channel amplifier, you need to get this equipment serviced.
Posted on Mar 26, 2010
smarthome2
  • 1114 Answers
SOURCE: Sony STR-GX800ES receiver "protector" blinking - no sound
The most common problem found on FixYa for Audio Video2_bing.gif Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Posted on Jun 13, 2010
Str-gx800es sony receiver problem- right channel speaker sound is 'static', low and distorted. I have checked checked all speaker and output/input source cable connections with no luck. All left channel...
If you have checked the speakers and wiring, the right channel has a audio driver or output problem, which explains the low volume, static, and distortion. A service technician will be required to fix the receiver so it will balance the left side.
Jan 10, 2011 | Sony STR-GX800ES Receiver
I need to turn the volume knob to the MAXIMUM on my Sony STR-GX50ES receiver to get just a whisper of sound.
Possible that the preamp is faulty and so the power amp is not able to deliver the sound.
it will be good to check the input through to the power amplifier with a audio signal test, you can now confirm where the missing amplification is ,even start from power amp will be good enough.
Sep 28, 2010 | Audio Players & Recorders
Right speaker is distorted with low volume, left side is fine. Swapped speakers no difference (ie it isn't a speaker problem). Using the balance knob, full left sounds fine, full right is very distorted...
Possibly one of the power transisitors has gone out. They are typically used in pairs, and if one went out, this is likely what you would experience.
Open the unit and look for the power transistors. The have 3 leads and should be connected directly to a heat sync. If one burnt out, it will likely be obvious by just looking at it. Power transistors are cheap (>$10) and there are many online sources to by them from. With a litle soldering skill, shouldn't be too bad.
Mar 26, 2010 | Sony STR-DE705 Receiver
Low sound at high volume. has worked fine until recently
Hi..
You need to replace the Volume control, the volume control is faulty already
Good luck !!!
Regards
PCmania
Jul 04, 2009 | Sony STR-DG1100 Receiver
THe problem is with the variable resistor present behind your volume control knob, try replacing the volume controls variable resistor, this must work fine... this is a common prblem for all the music equipment that has knob control for the volume....
This resistor can be replaced with your product warranty, contact your seller for the details regarding warranty...No need to woory about this, this is a sommon problem for most of recievers
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Constant Buzz coming from SX-255r
Power source harmonics. Or its power supply regulation. Check also if input line is touching something.
Apr 03, 2009 | Pioneer SX-255R Receiver
I have an old onkyo a-8067 reciever and only the left side speakers work. A while back the right side was fading and now it doesn't work at all. I also have a sony STR D1015 home theater receiver that has...
Fixed the Onkyo. Took apart the balance adjuster and rebent the feather-like things inside so they made contact. Clamped it back together and it works fine.
Nov 26, 2008 | Audio Players & Recorders
I have low volume on two channels of my STR DE975 receiver
I been replied you in chat thread, please check and feel free to ask any question.
Aug 20, 2008 | Sony STR-DE975 Receiver
High volume low sound
check the volume output from your components, and make sure they are not set too low
Dec 08, 2007 | Sony STR-DG510 Receiver
No output on main speakers
I have experienced a similar problem with my Sony STR-GX57ES and took it to a certified tech only to find it needed the power supply replaced. I opted to hunt down a compatible power supply but have been unsucessful thus far. That being said I picked up an STR-D665 for next to nothing and found the power supplies to be quite different (you would hope so any, with the ES meaning Elivated Standard and all) but with the D665 working flawlessly I'd rather have something working than nothing. Good luck!
Dec 06, 2006 | Sony STR-D665 Receiver
42 people viewed this question
 Grubhead
Grubhead
