Question about Refrigerators
Bosch KGU30605GB/02 Fridge Freezer not freezing
My KGU30605GB/02 is not working right. The fridge is alright, it works as per the temperature set and the fun works. But the problem is on the freezer. Sometimes it freezes and sometimes not. I have it set up at -20 and put a thermometer inside. It doesn't cope if plenty of food and temperature rises. Now is almost empty and temperatures move from 3 degrees to -14 with no rule at all. I've checked the fan in the freezer and it seems well for me (working when the magnet on the top of the door activates the magnetic switch). I've taken the panel that holds the fun and the evaporator is cold and without ice. I put the freezer in SUPER mode but there are no changes. It's like if the compressor couldn't cope with the freezer. The compressor is all time working and the left bottom side of the freezer is quite hot outside. The compressor is hot too. As the fridge is ok, Do you think it could be the use valve or it has lost some gas?
  • 61 Answers
SOURCE: Amana XRSS287BB side by side fridge freezer (3 years old)
you may try hard restart by shuting the fridge off and unplugging it from the wall . plug in back in and after 5 min turn it back on . close both doors and wait one hour . check the temp. if the unit still will not respond calll the local woranty amana repairman only. hope this helps you
Posted on Oct 20, 2008
bobicehouse
  • 1524 Answers
SOURCE: gegss20IEP does not get cold in top of freezer, food side warmer
Call him back. He needs to check the sealed system.
Posted on May 13, 2009
jeffbvegas1
  • 520 Answers
SOURCE: LG French door fridge freezer not freezing
hopefully you looked out back ...rear lower panel and checked little white condenser fan running...it really needs too to keep temp stable across the condenser coils and no overheat condition to the compressor.hopefully you wont need the $300 circuit board like I just bought
Posted on Jun 26, 2009
heatman101
  • 43501 Answers
SOURCE: Fridge side is getting warm.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jan 17, 2011
  • 5370 Answers
SOURCE: Maytag MTB2156GEW series 20, top
If the refrigerator is on, and keeping the door open, then it will damage the compressor and all other working parts.Because all parts will run more harder to cool the refrigerator, but because door ios open the cooling will be lost out. ----------- The compressor is approx $220 for part . --------- Click this link to see and order compressor and its related parts:--- http://www.repairclinic.com/Model-MTB2156GEW-ID-564067-Compressor-Or-Sealed-System-Components-Parts -----------
Again recharging the Freon is possible, but the cost for that recharging is approx the cost of new compressor.So its always advisable to get compressor replaced.Because new compressor has warranty for few years.. --------- This should help.Thanks.Helpmech.
Posted on Aug 29, 2011
My 18 year old refrigerator GE model TFX24FG freezer side is not keeping food frozen. Refrigerator side seems to be working normally.
The refrigerator side is at present working properly , but slowly slowly, it will also loose its cooling.This will happen because, freezer side is the side which cools first, then the refrigerator side ( also called as fridge side)., gets cooled.If freezer side is not cooling / freezing properly then fridge side will also loose its cooling ability.------------ And later on both section will loose its cooling.----------- As per the present situation, it indicates problem with compressor or problem with freezer side door not closing properly.---------- Or the temperature in freezer section is not set to proper cooling/ freezing.--------- So first inspect temperature, is it set right? If ok, then check the freezer door , is it properly closed? If ok, then its compressor problem.? The compressor is running non stop, this is indication of compressor problem.---------- Click this link below for more help:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html ----------- Later on both section will loose its cooling. -------- This will help.Thanks.Helpmech.
Aug 19, 2011 | Refrigerators
I have a double door fridge, at the bottom is the deep freeze and top the fridge, the fridge is not working at all no matter what temp i set it on, but the deepfreeze is working, what could be the...
If the deep freeze is working it only means that your problem is on the thermo switch on the the fridge section. Try to check the temperature setting panel if its possible open it and look for the thermo sensors that switches the temperature in the fridge.
Nov 08, 2010 | Bosch KGU66920 Side by Side Refrigerator
Temperature setting
The fridge should be just above freezing, maybe 2 or 3 degrees celsius. The freezer should be around -15 degrees celsius. The outside temp doesn't matter as far as the settings go.
Sep 09, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Fridge compartment is not cooling down to set temperature
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 08, 2009 | Refrigerators
How to use temperature settings on Bosch Classixx fridge freezer
You can find most user manauls at, www.managemyhome.com, on the right side of the page. You will need the model number off the product information label affixed to the unit.
Jul 05, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Bosch classixx fridge freezer. Freezer working fine, fridge not reaching a decent cool temperature. slighlty cool only.
Defrost fridge, remove product from freezer and store temporarily in another freezer, defrost at least o/night, then try again.
Nov 04, 2008 | Bosch Refrigerators
Bosch Fridge Freezer Classixx
This button is the winter/summer setting.
If you switch it on so as the red mark shows this is set for the summer setting.
What it does is allows the interior light to come on very dimly when you shut the door.
The fridge then thinks it is too warm and starts to cool down more, designed for when the ambient temperature is high.
Hope this helps
Deep diver
Dec 22, 2007 | Refrigerators
Refrigerators Logo
101 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
